Jump to content
mexykanu
Aducem piese OEM / AFTERMARKET / CONSUMABILE la comanda
Recommended Posts
Salut,
Avem in stoc si la comanda urmatoarele categorii de piese:
Cabluri si conducte de frana sport marca VENHILL
+Cabluri ambreiaj, acceleratie, frana
+Kit cabluri universale: ambreiaj, acceleratie
+Componente cabluri: Capete de cablu, cablu otel interior diverse dimensiuni, suruburi ajustare
+Conducte frana: fata, spate
+Componente conducte de frana: Conector T, adaptoare, protectii (Spirowrap), Banjo (capat de conducta, furtune 150mm lungime etc
Descriere conducte frana VENHILL:
* Venhill road brake lines use smooth bore DuPont Teflon hose for better heat resistance.
* Marine grade stainless braiding eliminates expansion so that all the braking force is transmitted to the brake.
* Corrosion-free 303 stainless steel swivel unions allow perfect twist-free alignment.
* Dome-head banjo bolts for clean look and easier work on cramped modern machines.
* PVC jacket from a range of colours protects the braided hose and paintwork.
* End fittings available in stainless steel or high quality chrome.
* All brake line kits include banjo bolts with copper washers and installation guide.
* Every Venhill hose is built to meet or exceed DOT and TUV requirements.
Electrice
+Baterii: Yuasa, JMT
+Bujii: NGK
+Fisa si lulea (cablu fisa): NGK
+Semnale si sticla semnal: JMT
Filtre
+Filtre ulei HIFLOFILTRO
+Filtre aer HIFLOFILTRO
+Filtre aer sport PIPERCROSS
Frane
+Discuri de frana fata,spate: NG
+Placute de frana fata,spate : CARBONE LORAINE, GOLDFREN, GOLDFREN RACING
+Saboti de frana: LUCAS TRW
Lubrifianti
+Uleiuri 2T, 4T : BEL-RAY, YACCO
+Ulei furca: BEL-RAY, YACCO
+Lichid de frana: BEL-RAY
+Spray de lant sport, offroad: BEL-RAY, YACCO
+Contact cleaner: BEL-RAY, YACCO
+Degresant frane: BEL-RAY, YACCO
+Spray multifunctional - curata, lubrefiaza, protejeaza impotriva coroziunii, reduce frecarea, inlatura umezeala : BEL-RAY
+Lubrefiant pentru asamblare : BEL-RAY
+Vaselina cu rezistenta sporita la umezeala : BEL-RAY
Transmisie
+Lanturi transmisie: EK
+Pinioane fata: JT Sprockets
+Pinioane spate aluminiu sau otel-carbon: JT Sprockets
+Curele de transmisie: ATHENA
+Kit role variator: ATHENA
+Role de lant: ALLBALLS
Manete
+Manete ambreiaj, frana: JMT
+Manete pliabile: UFO, WRP
Motor
+Ambreiaj: arcuri, discuri frictiune, discuri metalice: LUCAS TRW
+Oale ambreiaj: AOK
+Garnituri motor: ATHENA, TOURMAX
+Kituri biela 2T, 4T: AOK
+Kituri piston forjat, 2T, 4T: ATHENA, AOK
+Lanturi distributie: MORSE
+Rulmenti arbore cotit: ALLBALLS
Oglinzi - aproape toate tipurile de motocicleta
Rulmenti ALLBALS
+Rulmenti de roata, bascula, jug
+Distantieri roata
Ghidoane EASTON si ACCOSATO
+Ghidoane EASTON si ACCOSATO
+Mansoane ghidon EASTON
Evacuari MIVV si STORM
+ evacuari omologate MIVV si STORM
Furca racing K-TECH
+Furca racing K-TECH
+Diverse unelte pentru suspensiile K-TECH
Oferte speciale la:
- baterii JMT, YUASA
- lubrifianti YACCO
- placute de frana CARBONE LORRAINE si GOLDFREN
- filtre de ulei HIFLOFILTRO
- Plus MULTE ALTELE
CELE MAI MICI PRETURI !
Exemple preturi:
- Pentru Yamaha R6 2004
* Filtru ulei HF303 HIFLOFILTRO : 28 lei
* Baterie YT9B-BS JMT: 250 lei
* Baterie YT9B-BS YUASA: 335 lei
* placute frana fata CARBONE LORRAINE 2361A3+ : 115 lei
* placute frana spate CARBONE LORRAINE 2296RX3 : 85 lei
- Pentru Honda CBR600F4i 2001
* Filtru ulei HF204 HIFLOFILTRO : 27 lei
* Baterie YTZ10S JMT: 185 lei
* Baterie YTZ10S YUASA : 480 lei
* placute frana fata CARBONE LORRAINE 2711A3+ : 115 lei
- Pentru Honda Transalp XL650V 2002
* Baterie YTZ12S GEL JMT : 300 lei
* Baterie YTZ12S YUASA : 520 lei
* placute frana fata CARBONE LORRAINE 2300A3+ : 111 lei
* placute frana spate CARBONE LORRAINE 2298RX3 : 85 lei
- Pentru Suzuki Intruder c800 2006
* Filtru ulei HF138 HIFLOFILTRO : 28 lei
* Baterie YTX12-BS JMT : 165 lei
* Baterie YTX12-BS YUASA : 220 lei
* placute frana fata CARBONE LORRAINE 2384A3+ : 120 lei
* saboti frana spate LUCAS TRW MCS 959 : 146 lei
Contact:
+ mail comenzi: mexykanu@gmail.com
+ telefon: 0741095483
Share this post
Link to post
Share on other sites
Achizitionat : Baterie YTZ10S JMT
Am fast placut surprins ca mi-a oferit si garantie 1 an :bounce:
Share this post
Link to post
Multumesc :).
Se ofera si factura pentu cei interesati.
Gama completa la uleiuri YACCO, la cele mai bune preturi de pe piata:
*Ulei 4Timpi: ulei competitie, sintetic, semi-sintetic, mineral
*Ulei 2Timpi: ulei competitie, sintetic, semi-sintetic, mineral
*Ulei Scuter: ulei 2 timpi si ulei 4 timpi
*Ulei Transmisie mecanica: sintetic, semisintetic, mineral, ulei ulei pentru motoare in 2 timpi
*Ulei Transmisie automata: lichid pentru transmisii hidraulice, cutii viteza automate sau semiautomate
*Ulei de Furca: ulei de furca MIDDLE, LIGHT, EXTRA LIGHT
*Spray Lant: spray OFF ROAD si spray RACING (aderenta sporita)
*Ulei filtru aer: lubrifiant filtru aer
*Ulei pentru aviatie usoara: ulei semi-sintetic pentru 4 Timpi, Ulei semi-sintetic pentru motoare in 2 Timpi
*Lichid de frana: DOT4 si DOT5
*Vaseline: vaselina pentru temperaturi scazute, vaselita pentru presiuni extreme, vaselina spray
*Toata gama de intretinere, protectie si curatare: contact cleaner, degripant, degresant de frane, spray de geam, curatator de plastic lucios, curatator de plastic mat, lichid etansare radiator, gel pentru curatat mainile, pasta antigripanta, detartrant radiator, MECAPROP (degresant heavy duty pentru piese motor), lichid racire.
Datele de contact in primul post.
Edited by mexykanu
Share this post
Link to post
Cumparat: baterie, ulei yacco si filtre.
Si eu am primit garantie, tot 1 an(la baterie).
Recomand!
Share this post
Link to post
Se adauga:
* Comenzi de mansoane, ghidoane, faruri sport, chopper, enduro - diverse modele.
* Timp de livrare: 3-4 saptamani
* Tara de origine: USA, Uniunea Europeana (UK, Germania), Australia plus altele
Voi adauga poze in 3 saptamani, cand ajunge prima comanda de mansoane + capac filtru aer pentru chopper.
Imi rezerv dreptul de a cere avans in cazul comenzilor mari datorita numarului mare de persoane neserioase.
Ca de obicei, rog si ofer seriozitate maxima.
Share this post
Link to post
salut!
zi-mi te rog ce placute de frana se gasesc pentru suzuki bandit600 '04 si kawasaki zephyr 550 '97 - ambele seturi complete (fata-spate).
as mai vrea si 7 litri de 10w40 + filtrele de ulei pentru ambele motoare.
mersi! :cheers:
Share this post
Link to post
salut!
mersi! :cheers:
Salut,
Pentru Bandit600 '04:
Placute frana CARBONE LORRAINE:
fata [b]2383A3+ si 2384A3+: 240 lei setul[/b]
spate [b]2282RX3 : 115 lei[/b]
Placute frana GOLDFREN
fata - [b]104AD si 124AD[/b] - [b]140 lei setul stanga+dreapta[/b]
spate [b]016AD[/b]- [b]70 lei[/b]
Filtru ulei HIFLOFILTRO
HF138 - 27 lei
Pentru Zephyr550 '97:
fata [b]2304A3+ : 120 lei [/b]
spate [b]2381RX3 : 115 lei[/b]
fata - [b]013 AD[/b] - [b]70 lei[/b]
spate [b]093 S3[/b]- [b]80 lei[/b]
HF401  - 18.8 lei
Ulei YACCO MVX 500 10w40 - 1 litru - 30 lei
Ulei YACCO MVX 500 10w40 - 4 litri - 92 lei
Share this post
Link to post
Buna ziua,
Aducem orice piesa OEM sau accesoriu custom (spre exemplu: mansoane, scarite, faruri, stopuri, capace de claxon, suruburi de carene, tobe, xenon, anti-furt de disc etc).
Putem asigura si montaj, contra cost (unde se aplica).
Timpul de livrare poate varia intre 1 si 4 saptamani (am primit un releu de incarcare in 1 saptamana din Marea Britanie si in 3 saptamani o piesa de metal din Finlanda).
Preturi de importator.
Vom adauga, in curand, poze cu accesoriile pe care le-am comandat pana in momentul de fata - montate si demontate.
O zi buna !
Share this post
Link to post
Undertail pentru 929 2000-01 gasim ? daca da la ce pret si ce modele?
Share this post
Link to post
Salut,
Va pot aduce din SUA, material fibra de sticla, culori Alb, Galben, Rosu sau Negru - la pretul de 450 ron - cu livrare EXPRESS.
Este modelul cu 2 semnale de stop.
Timp de livrare 1-2 saptamani.
O zi buna!
Edited by mexykanu
Share this post
Link to post
Salut,
m-ar interesa urmatoarele, pentru un Kawasaki zx-6r, an 2001 (ZX600JJ):
Placute Frana fata si spate si baterie Yuasa YTX9-BS. Bateriile sunt originale Yuasa?
Multumesc.
Share this post
Link to post
Salut, ai PM cu preturile.
Bateriile sunt YUASA, nu Toplite sau altceva.
Share this post
Link to post
salut. ma intereseaza pretul la evacuare MIVV ( suono, GP - carbon / inox) pentru un ducati monster 695 din 2006
Share this post
Link to post
Salut,
Ti-am trimis PM.
Numai bine.
Share this post
Link to post
Salut,
m-ar interesa si pe mine un pret pentru niste placute de frana Carbone Lorraine 1083XBK5 si unde ne putem intalni daca ma hotarasc sa le cumpar.
Multumesc,
Share this post
Link to post
un intinzator distributie gsxr750 srad inj din 98 se gaseste?
daca da la ce pret?
Share this post
Link to post
Salut,
Multumesc,
Salut,
Placutele costa 137 lei / set , ne putem intalni in zona Titan, Bucuresti.
O zi buna !
daca da la ce pret?
Salut,
Iti pot face comanda, costa 130 lei.
O zi buna !
Edited by mexykanu
Share this post
Link to post
Din partea mea CUVINTE DE BINE! Desi nu am cumparat eu piesa - prietenul pt care am facut legatura este foarte multumit de componenta primita! Om serios! Recomand! Bafta :grinbandit:
Share this post
Link to post
Salut,
Ma intereseaza un set placute spate pentru o Honda Hornet-600cmc,an fabr.2000.Care este pretul?.Se poate trimite prin posta romana?.
Merci fain!
Share this post
Link to post
Salut,
Merci fain!
Salut,
Avem urmatoarele placute frana spate pentru Hornet an 2000:
CARBONE LORRAINE (CL Brake Pads) - 2296RX3 - 82 lei
GOLDFREN - 021S3 - 77 lei
Se poate livra prin orice curier doriti.
O zi buna !
Multumesc !:D
NOU ! Avem in stoc ghidoane WRP.
Edited by mexykanu
Share this post
Link to post
recomand! :cheers:
Share this post
Link to post
recomand! :cheers:
Multumesc :friends:
Edited by mexykanu
Share this post
Link to post
Salut,
O zi buna!
un rezervor pt r1 din 99?
Share this post
Link to post
Super user, super piese/produse, super preturi! Apelati cu toata increderea!
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
