Jump to content
Sign in to follow this
serbumi
Vand Beta Alp 4.0 (Motor Suzuki DR)
Recommended Posts
Vand motocicleta Beta Alp 4.0, an 2005, km 900. Motocicleta a fost cumparata anul trecut dintr-o galerie/coletie unde a stat din 2005. La cumparare i-a fost facuta revizia completa (baterie noua Varta Gel, schimb ulei/filtre, schimb lichid frana - inclusiv curatat instalatie, curatat rezervor benzina, curatat carburator, schimbat bujie, inlocuit furtune alimentare). ITP valabil pana in Iunie 2020, ofer fiscal pe loc.
Motocicleta se poate vedea in Alba Iulia.
Pret 2800 Eur (negociabil la fata locului).
Tel: 0724591592
Motocicleta:
ENGINE:
 Producer: SUZUKI Single cilinder, 4 stroke, air cooled, camshaft
 Displacement 349 cc
 Compression ratio 9,5:1
 Carburetor Mikuni BST 33
 Feeding Unleaded gasoline
 Starter Electric
 Lubrification system forced lubrication with pump
 Valves 4
 Ignition Electronic
 Spark plug NGK CR9EK - DENSO U27ETR
 Clutch Multiple disc clutch in oil bath
 Primary trasmission 15/48
 Gear Box 6 speed
FRAME:
 Frame iron double closed cradle
 Wheel base mm:  1410
 Overall length mm:  2185
 Overall width mm:  860
 Overall height mm:  1230
 Seat height mm:   865
 Ground clearance mm:   300
 Footrest height mm:    350
 Mass kg:  133
 Fuel capacity lt:      10,5
 Reserve lt.      3,0
 Front fork Hydraulic fork, 46 mm tubes
 Rear suspension single shock with adjustable spring
 Shock absorber stroke mm:    83
 Front wheel travel mm:  210
 Rear wheel travel mm:  200
 Front brake disk  o mm  260
 Rear brake disk o mm   220
 Front rim  1,85 x 21
 Rear rim  3,00 x 18
S-a vandut, se poate inchide. Succes noului proprietar.
Multumesc user Christian 1 pt recomandare.
Share this post
Link to post
Share on other sites
Placerea a fost de partea mea si ma bucur ca ne-am cunoscut! :)
Share this post
Link to post
Guest
This topic is now closed to further replies.
  • Create New...
