Jump to content
Delimitare Suzuki GS500FU
Recommended Posts
Salut. Am un suzuki gs500fu. Acel “u” din nume vine de la faptul ca din fabrica e produs la 25kw. Acum problema e ca vreau sa ajunga la 35, cum sunt modelele fara “u”. Nu am gasit suficiente informatii pe net despre asta. As vrea sa stiu daca este cineva care cunoaste diferenta dintre cele 2 modele si ce piese nu corespund astfel incat sa le pot schimba ca sa ajunga la puterea dorita. Multumesc
Link to comment
Share on other sites
The FU`s were low powered versions built in the factory to comply with the various learner laws that are in place in certain European countries, they are not full power versions with restricter kits fitted......they are just low power versions that have never seen more than 30 or so hp.
The carbs differ in the way of jetting and slide design, the exhausts are more restrictive and the ignition timing is slightly different so I would guess if you replace your carbs, exhaust system and the ignition advancer from a full fat GS500 you might see some gains
Sfantu gogu.
Link to comment
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
