Albert Johnnson Posted December 28, 2022 Share Posted December 28, 2022 Riding a bike to work every day is a great way to stay active and reduce my environmental impact. chain wax and bicycle chain lube, which one is effective at lubricating bike's chain and improving its performance. Can anyone suggest some good bike chain lube and methods to use it? Quote Link to comment Share on other sites More sharing options...
PzKpfW Posted December 28, 2022 Share Posted December 28, 2022 I think asking a "performance improvement" from a chain lubricant is a rather tall order. I personally never lube my chains with anything and they are just fine, but I almost always ride in sunny weather. If you use your motorcycle daily, it might be a good idea to lubricate your chain, as otherwise it might get rusty and that might affect its lifespan. For simplicity's sake, just use dedicated motorcycle chain lubricants, not bicycle ones: they are not thick and sticky enough and will rapidly splatter out. I will not recommend any brand in particular, just know that the more expensive ones are usually more sticky and thick: that's a good thing for chain lubrication but a bad thing when cleaning dirty lube out of your chain/bike. Compromises. Some might also recommend gear oil/grease (that's the thing in which chains come smeared on from the factory), but that sounds a bit messy to me. Quote Link to comment Share on other sites More sharing options...
Speedy.K Posted December 28, 2022 Share Posted December 28, 2022 https://motorex.com/en-us/bike-line/bike-line-assortment--5772 PS Pe de alta parte eu inca ma intreb daca profilul asta este real sau nu. Quote Link to comment Share on other sites More sharing options...
Leon Posted December 28, 2022 Share Posted December 28, 2022 I use cheap car oil. I am very satisfied with the result Quote Link to comment Share on other sites More sharing options...
ENEOS Posted December 28, 2022 Share Posted December 28, 2022 Quote Link to comment Share on other sites More sharing options...
Recommended Posts
