Cagiva W8 De 125cc
Ma intereseaza si pe mine ceva date tehnice despre acest motor. sunt chiar incepator si nu stiu la ce trebuie sa ma uit. nu stiu cat de fiabile sunt. Poate sa ma ajute cineva si pe mine sa stiu ce imi cumpar? pls :crack:
Editat de jymmy5
Uite aici niste date,sper sati fie de folos:
General information
Model: Cagiva W8
Year: 1998
Category: Enduro / offroad
Rating: 69.2 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 125.00 ccm (7.63 cubic inches)
Engine type: Single cylinder
Stroke: 2
Power: 15.00 HP (10.9 kW)) @ 9500 RPM
Torque: 17.00 Nm (1.7 kgf-m or 12.5 ft.lbs) @ 9200 RPM
Cooling system: Air
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 115.0 kg (253.5 pounds)
Seat height: 870 mm (34.3 inches) If adjustable, lowest setting.
Chassis and dimensions
Front brakes: Single disc
Rear brakes: Single disc
Speed and acceleration
Power/weight ratio: 0.1304 HP/kg
Other specifications
Further information
Parts and accessories Check out parts and accessories from our partners.
Ask questions Join the 98 Cagiva W8 discussion group
Insurance, loans, tests Search the web for dealers, loan and insurance costs, tests, customizing, etc.
Related bikes List related bikes for comparison of specs
ma poti ajuta poate si cu niste date despre un kawasaki kmx tot de 125. care sa il aleg. e bine sau e rau ca nu are racire pe lichid? si cam cum e cu schimbul de consumabile la ele ulei etc. amandoua sunt la acelasi pret. unul e din 97 (kawasaki) dar momentan am inteles ca trebuie sa schimbe un pinion in cutia de viteze, iar celalalt din 99.
Jymmy uite,ai aici datele si la KMX:
General information
Model: Kawasaki KMX 125
Year: 1997
Rating: 72.3 out of 100.
Stroke: 2
Power: 15.00 HP (10.9 kW)) @ 8500 RPM
Torque: 13.00 Nm (1.3 kgf-m or 9.6 ft.lbs) @ 6600 RPM
Cooling system: Liquid
Gearbox: 5-speed
Transmission type
final drive: Chain
More details Consult a Kawasaki repair manual.
Physical measures
Dry weight: 96.0 kg (211.6 pounds)
Seat height: 865 mm (34.1 inches) If adjustable, lowest setting.
Power/weight ratio: 0.1563 HP/kg
Daca as fi in locul tau mai degraba as alege kawasakiul pentru ca gasesti piese,si e un model mai cunoscut.Ai putea specifica pretul celor doua motociclete??
1500 euro fiecare dar dupa cum am spus la kawasaki trebuie sa schimbe pinionul de la viteza a 4-a e asta vreo problema care sa ma urmareasca in timp. se mai poate strica repede ?
sincer,habar nam,dar nu cred.Oricum alegerea este a ta.Dupa mine Cagiva arata mai bine.Taicamio are o cagiva T4 350 E(4 timpi)si nu a avut niciunfel de probleme,motocicleta fiind din 1990.
aaaa si inca ceva.Uitate si la cati km au fiecare.
