bhairava Postat Decembrie 17, 2004 Share Postat Decembrie 17, 2004 Warning: Before you read this article you should know that it will create more questions than it will answer. Consider yourself forewarned. Reality Check For the cornering enthusiast, there are at least 48 different aspects in riding a single corner. Riders observe, record and scrutinize these points, usually without being aware of doing it at all. A while back I started out with a list of 14 things riders monitor in turns. I never imagined it would become so extensive. During its development, I mainly used the list to help racers identify and clarify aspects of their riding skills. Now, weâre starting to use parts of it in our Level IV School sessions. Several interesting things have come to light while quizzing riders using these lists. 1. As expected, each rider relates to the 48 points on the list a little differently. 2. As above, it was discovered that awareness (on many of the points) was low or even subconscious. Many were lumped together with other points of riding and never before isolated as separate and individual aspects of cornering. 3. Once each point was discussed, clarified and understood the riders were then able to grade themselves on how well they felt they executed them. 4. Even professional riders had no names or even slang type racer-expressions for most of the points covered. As it turns out, there is great deal of awareness of a great many things while riding. These can be recalled once the riderâs attention is directed to them. Apparently, each of these points occupy some corner of a riderâs attentionâthey wouldnât know what they are otherwise. Even the absence of terms that describe these perceptions is valuable data. That fact brings us closer to understanding why some riders excel at the sport. The better the rider the easier time they have isolating and grasping the points. Their ability to translate them into real world actions showed me they were more aware of the points than other, less skilled riders. I see riders, and youâve seen it too, struggling with this lack of descriptive terminology all the time. Without the descriptive words what do we do? We use hand gestures and facial expressions when describing different riding situations! The Name Game What Iâm saying is that inherent in the problem of rider improvement is the lack of names for these often flimsy and fragile perceptions. If you donât have a name for a problem it makes it hard to discuss. If it canât easily be communicated it is difficult to solve. Example, if you canât easily communicate what the front-end feels like when you lose it (within an acceptable range) how would a rider recognize it when it happens? How would he know whether it meant an impending crash or if it was just good feedback on the traction limits from his front-end? You can say âI was pushing the front-end in turn_______.â, but where does his imagination take him if he hasnât done that? Unless you figure out a way for riders to easily experience this or develop the words to describe it, your communication on the subject would go nowhere. No matter how many hand gestures you make. This points directly to the heart of the matter of rider improvement and one of its major pitfalls; communicating what things feel like. Having a name for things helps. Short of having a good descriptive name for something there is the building of fundamental skills that keep the rider out of trouble and in control. That is what we do in our levels at the schools. Now we have another tool. The list of 48 has given us forward motion in helping to bridge the communication and experience gap. Categories and Solutions For 25 years Iâve been evaluating and re-evaluating the schoolâs curriculum; adding and subtracting things as we see fit. As this list started to shape up I began an inventory of what techniques we coach at CSS to see if the 48 points were covered. Our current arsenal of drills and exercises numbers around 20 so how could we be covering all of these points? At first I was a little deflated. However, as I looked closer it became apparent that the 48 points could be grouped into categories. Examples of the categories are: traction, lean angle, stability, speed, corner entry, corner exits and lines. Looking Deeper From the perspective of an educator you have to design something that communicates and that brings another interesting problem, itâs one of those âwhich came first the chicken or the eggâ things. Is the rider working the controls from the way the bike feels; making a mental decision before working the controls? Looking (with his eyes) then making a decision and then working the controls? Do we naturally take into account the lag-time between looking then feeling and then initiating control actions? Is the rider âahead of himselfâ; is he riding right in present time or slightly âbehindâ himself to make these decisions? Is this all guided by what he did the last time he made this or another turn like it? How often does he flip back and forth from one sequence of seeing and feeling what the bike is doing to another? See what I mean, a lot more questions than answers. Whatever approach you finally use must be based on a keen understanding of what the rider senses, how he uses it and a clear picture of which chain of events he uses leading up to controlling the bike. Try One You could ask, âIs it really so complicatedâ? Isnât there some simple way of going about sorting this out? Sure, once the categories are established, a few of which are listed above, then it does become somewhat simpler but beware, it also brings up more questions. Iâll take point number 27 from the list under the category of LINE so you can see what I mean. 27. Do you have Immediate Certainty on your Line?â This breaks down into several questions of its own: 1. Can you see and understand the exact line you are on right away after getting to your final leaned-over angle? 2. Do you have to wait a while to see if it is right or not? 3. Do you know itâs good sometimes before you even know that you know it is? Refinement Breaking this tiny portion of time down into its mini component parts can be done by referencing: 1. Time, how long does it take you? 2. Distance, what is the distance covered before you know? 3. Your attitude, how does it make you feel when you have to wait? 4. A description of visual data, what were you looking at? 5. The feel you get from the bike, was the bike stable or what? 6. Perception of speed, were you trying to decide if your speed would get you where you wanted or not? 7. Lean angle, could you tell if it needed changed or left alone? and 8. Traction, is your awareness of traction at this point too attention consuming? These are but a few possibilities of additional questions. But wait, thereâs even more. The answer to those bring about a whole other column of questions. Super Refinement Which of the above is more important than the others? Can Humans multi task--input and process--this much information? Do we monitor this sequentially or simultaneously? Do all riders do it in the same way? You can see the problems in working this out. But most importantly, the value of this line of questioning is rider improvement. To access this value you have to be able to rate yourself from 1 to 10 on point number 27. Can you do it? Go back and look it over. Tricks or Basics Sure the things that weâve developed over the past twenty-five years like the Lean and Slide Bike, the Panic Brake Trainer, the Control Trainer and our various video inventions are a big help in solving these areas. When we broke our school days into individual âdrillsâ in 1983, that was a major breakthrough in rider training all on its own. That was the beginning for me. I knew then that, luckily, there are simple answers. Unfortunately, it isnât just one technique that covers #27 of the list. Itâd be nice but itâs not so. What we have here is a very detailed process built on the true fundamentals of riding: throttle control, visual skills, traction sensitivity, ability to turn the bike accurately, rider input, speed setting and line recognition skills. All of these have to be in place for any rider to rate high on this Certainty of Line aspect of riding, # 27 above. Is anyone likely to get to be a 10 on this in even one corner on one day? Sure, its possible. Could anyone get it right for every corner on a given track in one day? Hmmm, havenât seen that happen. When mastered is it one of the parts of a riderâs confidence? Think it throughâif you could get point 27 on the list really right all the time, how would you feel? See answers below... The Benefits Here is a partial list of what you would have conquered: 1. You could see your line right away. This reduces the tendency to target fix. 2. You wouldnât be sitting on the bike waiting while you search for the answer to âwhere am I going in this turnâ. Perhaps the most important question a rider can have. 3. No doubts about when the gas should go back on. Being able to achieve throttle- induced stability earlier in the turn is always a plus. 4. Total certainty on any steering corrections you might have to make. This dramatically improves timing the steering inputs to be most effective. 5. A solid idea of where the bike is going to wind up at apex and the exit. Having good prediction on this always inspires confidence. 6. Huge reduction in rider tension on the bike. You donât have to be wound-up about steering inputs you imagine you âmightâ have to make. How valuable would the above six points be to you? OK, there are 47 more points, let me know when you are ready to start (or continue) working them out; weâve got over 100 school days in 12 countries in 2005 to handle it. Keith Code Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
