VIPER MOTORCYCLE
dead_man_walking
http://www.vipermotorcycle.com/
The Diablo Super Cruiser is a high-performance factory custom that is designed and manufactured from the ground up. With a right-hand drive, center mount and rubber mount engine, the Diablo at 600 pounds has a perfect balance point which delivers excellent handling and performance characteristics like no cruiser before it. When you couple these features with a 128 cubic inch billet Patrick motor, a 6-speed transmission and adjustable air-ride suspension, you have a production Super Cruiser that is truly functional.
2005 Viper Diablo
Engine: Proprietary Billet Aluminum
Displacement: 2093cc/128 Cubic Inches
Cooling: Air Cooled 45 degree V-Twin
Bore x Stroke: 4.25 x 4.50
Max Torque: 141 Foot Pounds
Max Horsepower: 128 HP
Carburetion: Mikuni HSR 45 Flat Slide
Exhaust: Tuned 2 into 1
Oil Capacity: 4.5 Quart Capacity Dry Sump
Electrical: 32 Amp Alternator with Odyssey Dry Cell Battery
Primary Drive: Proprietary Hydraulic Chain
Clutch: Hydraulic High Performance Rivera
Final Drive: Patented VHD System with Right-Hand Drive and High Performance Belt
Front Brake: Single Disc with 4 Piston Billet Caliper and Stainless Steel Rotor
Rear Brake: Single Disc with 4 Piston Billet Caliper and Stainless Steel Rotor
Length: 96 Inches
Wheelbase: 68 Inches
Seat Height: 24 Inches
Rake/Trail: 34 Degrees
Dry Weight: 570
Front Suspension: Marzocchi Inverted Adjustable Cartridge Forks
Rear Suspension: Proprietary Billet Aluminum Swing Arm with Oil Dampened Adjustable Air Ride
Front Tire: 130 / 70-18 Metzler Radial
Rear Tire: 240 / 40-18 Metzler Radial
Colors: Viper Red / Viper Black / Viper Blue/Silver
Engine
Proprietary Billet Aluminum 128 Cubic Inch 45 Degree V-Twin
Proprietary Dry Sump Oiling System
Hydraulic Lifters
Fuel System
Mikuni HSR45 Flat Slide
K&N Air Filter
Stainless Steel Braided Fuel Line
Final Drive System
1.5 inch Kevlar Reinforced High Performance Rivera Belt
Chassis
Patented Rubber Mounting Engine System Utilizing a Non-Rubber Mounted Swing Arm
Center Mount Engine/Transmission Utilizing a 240mm Rear Tire
Lubrication System
Proprietary Dry Sump Oiling System Utilizing 4.5 quarts
Front Suspension
Chrome Inverted Marzocchi Adjustable Cartridge Forks with Billet Triple Trees
Rear Suspension
Oil Dampened Air Ride Suspension
Adjustable On-Board Air Compressor with Electronic Air Release Valve and LED Display
Proprietary Billet Aluminum Swing Arm with Hidden Axle Covers
Transmission
Right-Hand Drive 6-Speed with Overdrive
Ignition System
Proprietary Fully Adjustable Digital Ignition
High Capacity Crane Ignition Coil
Primary Drive System
Wet Chain with Proprietary Hydraulic Adjuster
Hydraulic Rivera Pro Clutch
6061 Billet Aluminum Inner and Outer Primary
Wheels
Polished Billet with Matching Drive Pulley
Brake System
Hydraulic Front and Rear with Billet Four Piston Calipers and Polished Stainless Rotors
Lighting
HID Headlight
LED Front Turn Signals
LED Rear Turn Signals and Tail Light Integrated into Rear Fender
Body Components
Carbon Fiber Front and Rear Fender, Shrouds and Air Filter Cover
Steel Tank
Security System
Motion Security System with Keyless Remote and Digital Pager
Electrical System
Digitally Controlled
High Capacity Starter
High Output Charging System with Odyssey Dry Cell Battery
Additional Features
Polished Stainless Steel Side Stand with Internal Spring
Patented Billet Adjustable Forward Controls
Rubber Mounted Handlebars
Proprietary Anti-Vibration Weighted Handlebar End Caps
Key Operated Seat Latch
Digital Speedometer and Gauges with LED/LCD Bar Graph Instrumentation
Billet Chrome Mirrors
