Gas Gas Sm125
Salut tuturor! Va invit pe toti sa va dati cu parerea despre Gas Gas 125sm. Banuiesc ca mai sunt baieti care vor sa stie date tehnice despre acest motor, cum se comporta pe strada, care sunt +urile si -urile, pretul etc. Imi cer scuze daca s-a mai discutat pe acest subiect dar eu nu am gasit.
Date tehnice
General information
Model: GAS GAS SM 125
Category: Super motard
Rating: 78 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 124.00 ccm (7.57 cubic inches)
Engine type: Single cylinder
Stroke: 2
Bore x stroke: 54.0 x 54.5 mm (2.1 x 2.1 inches)
Fuel system: Carburettor
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Dry weight: 100.0 kg (220.5 pounds)
Seat height: 940 mm (37.0 inches) If adjustable, lowest setting.
Ground clearance: 340 mm (13.4 inches)
Wheelbase: 1,475 mm (58.1 inches)
Chassis and dimensions
Frame type: TType deltabox, made of rectangular profile Cr-Mo
Front suspension: Marzocchi inverted fork, 50 mm
Front suspension travel: 295 mm (11.6 inches)
Rear suspension: Progressive system, Ohlins shock absorber.
Rear suspension travel: 320 mm (12.6 inches)
Front tyre dimensions: 120/60-17
Rear tyre dimensions: 150/60-17
Front brakes: Single disc
Front brakes diameter: 300 mm (11.8 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Other specifications
Fuel capacity: 9.50 litres (2.51 gallons)
Further information
Parts and accessories Check out parts and accessories from our partners. GAS GAS SM 125 accessories
Ask questions Join the 04 GAS GAS SM 125 discussion group,
the new GAS GAS forum at Bikez.name or
the new Super motard forum at Bikez.name.
Insurance, loans, tests Search the web for dealers, loan and insurance costs, tests, customizing, etc.
Related bikes List related bikes for comparison of specs
Editat de cosmin_moto
  • 3 weeks later...
