Bombardel Postat Septembrie 27, 2005 Share Postat Septembrie 27, 2005 ce zicetzi de desingulde la R1? SPECS - 2006 Yamaha YZF-R1 and YZF-R1 SP Engine: 998cc, four cylinder, liquid cooled, four stroke, 20-valve Bore x Stroke: 77 x 53.6mm Compression: 12.4:1 Induction: Fuel injection Claimed Power: 128.7kw (175hp) at 12500rpm Claimed Torque: 106.6Nm (11kg-m) at 10500rpm Starter: Electric Transmission: Six speed Final Drive: Chain Wheelbase: 1,415mm Dimensions (L x W x H): 2,085 X 720 X 1105mm Trail / Rake – 97mm / 24-degrees Seat Height: 835mm Dry Weight: 173kg (174kg for the ‘SP’ model) Fuel Capacity: 18 litres Tyres: Front _ 120/70-17; Rear _ 190/50-17 Suspension: Front _ 43mm fully adjustable inverted forks (Ohlins on the ‘SP’ model); Rear _ Fully adjustable single shock (Ohlins on ‘SP’ model complete with hydraulic preload adjuster) Brakes: Front _ 320mm dual disc, radial four-piston calipers; Rear _ 220mm single disc Price: TBC Warranty: Two years, unlimited kilometres Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
