bhairava Postat Ianuarie 1, 2005 Share Postat Ianuarie 1, 2005 By survey 100% of over 10,000 riders agree on this point: they know that if they possessed the ability and skill to get their turn entry speeds consistently right, their confidence would soar; they would feel more in control; they would be faster and they would be smoother. Here is some information on why you might want to master that ability. Coasting Races In the mid â70's I was introduced to an amazing form of âracingâ. Four or five of us would get together at the top of one of our favorite southern California canyon descents; turn off the engines; line up across the road; heckle each other; count to three; pick up our feet without pushing off any more than was necessary to get moving and laugh and yell out insults to one another all the way down to the bottom. Most of the runs were a couple of miles long with lots of turns. Thatâs a coasting race. The rider who coasted the farthest and fastest (they were usually the same rider) âwonâ. There werenât any tricks, equipment mattered little, it was all you. Well, I did have one little trick -- pushing the pads back into my front caliper to eliminate the pad drag. The camaraderie was elevated enormously by the fact that, unlike our usual canyon rides we could, for the most part, communicate throughout the descent. It was such a delight. Even when it went wrong and someone crashed (like me) I still have fond memories and get a warm sensation when recalling it. Strategy of Coasting Races On the technical side of things: I was immediately impressed with several aspects of this form of entertainment and a couple of those points were indelibly printed in my memory and became a part of the California Superbike School over 20 years ago. The simple trick to winning a coasting race is the obvious, the rider who could maintain his momentum by using his brakes the least generally would prevail. Doing an entire run down some of the steeper roads with little or no braking took as much or more mental grip than doing it with them, this becoming immediately apparent in the first semi-tight corner you came to. Unwilling to give up the momentum yet afraid of the speed which had accumulated, your focus and interest became laser sharp. Sure your hand would be poised over the lever and sure it took some supreme acts of willpower to keep from using brakes and sure you would make errors and have to use the brakes but you also paid closer attention to the speeds than you normally would. The reduction of distractions like engine noise and gear changes and throttle and charging the corners with hard braking were all eliminated and it allowed you to make much finer estimates of your corner entry speeds and maintain that precious momentum. Low Noise, High Speeds After my first coasting race I realized I never would have gone through those turns with the power on as fast as I had done with no engine running, no charging and, for the most part, no brakes. It made me realize just how distracting those things really were and just how much of my attention they absorbed. One of the things I have noticed when I watch students is how erratic their turn entry speeds often are. That comes from the idea they have to charge the corners and brake hard but they can tend to over-brake and foul up their entry and corner speed momentum. Low Speeds, Quick Times One day, as I was driving up to the Laguna Seca track in northern California to do a school, I realized that if anyone was going to overcome this self generated confusion from over-braking, the quickest route to that was riding no brakes. Once I got to the track I tried it out and rediscovered what Iâd already figured out before from the coasting races. I went faster into the turns, my speed sense and judgement became sharper, I worried less about my entry speed and found that getting back to the throttle earlier was significantly easier. I thought it would be worthwhile to have the students try it out. While it is true that some tracks lend themselves to this form of sharpening your riding skills better than others, I did begin to notice a trend at different tracks. The riders who stuck with the no brakes, even after we officially switched back to using them, made more improvement in their speed and confidence than those who were âtestingâ our brake pad material by charging the turns. Ignore the Instincts Itâs almost as if riders feel obligated to charge turns. Itâs the idea that you will go faster because of it and seems such a simple and direct route to that end but rarely works. The instinct to brake late and hard is like clubbing a female to then take her for a wife. That plan isnât going to work. I have observed many truly diligent riders who ignored the instinct and stayed with the No Brakes format knocking off seconds from their lap times. To top it off they were achieving their quicker times with only one or two gears instead of the usual thrashing through the gear box. They might be going 20 mph slower on the straights but one should pay attention to the results (improved lap times and corner speed) not the impulse to go fast on the straights. As I have said a thousand times, the brakes become more of a crutch than a tool for most riders. Someone always whines about the no-brakes riding format at school. Well, crutches are notoriously hard to put down, arenât they? Riders claim it is difficult (of course it is), that they could go faster with them (faster down the straight away, yes); that they âhadâ to use them (the crutch again) and on and on. What these riders donât realize is how satisfying it is to persevere at the exercise until you really get it, so you really can judge your entry speeds and really know you can do it. Very, very satisfying. Very, very big contribution to your riding confidence. Very! The Basic Idea The logic is flawless. Using or not using the brakes is irrelevant to the intended result of getting into the corner at the exact right speed. One either knows what that right speed is and can achieve it or they are guessing. If they are guessing they are paying more attention to it than they should have to. Guessing brings about inaccurate braking and inaccurate braking brings about rough and uncertain turn entries. Trail Braking (Definition: Action of trailing off or tapering off brake lever pressure and braking force as the rider enters the corner.) Trail braking is a valid and useful tool for any rider at any level of riding. The warning is this: when used too often, or as a crutch to calm the fear brought on by the inability to sense speeds accurately, it not only doesnât solve the source of the problem it makes it worse. As the pilot you must make the decision on when to let off of the brake(s). It is a complicated little piece of work with all of the other usual distractions you encounter at the turnâs entry, e.g., setting the lean, getting the line and feeling the traction. Bottom line â- if you are trailing the brakes towards a well known, accurately understood speed it is a tool. Otherwise it tends to become a crutch and invites riders to âchargeâ the turns, low line them, leave the throttle till late and make tricky and sometimes dangerous mid-corner steering corrections all of which could be avoided with accurate turn entry speed sensing and setting. Panic Crutch In contrast to the aforementioned, I see many riders who feel compelled to stab at their brakes in the last moments before entering a corner. While watching them do it, the only conclusion one would come to is that the speed was a big surprise; all of a sudden they become aware of it and it seemed too fast. This is an obvious error. They arenât using the brake to adjust anything except their fear. In either of the above cases, an accurate sense of speed opens the door to confidence. Results Then and Now The essence and final result of any brake release for cornering remains what I said in 1980 in my first Superbike School lecture and on page 64 of the first âA Twist of the Wristâ book in 1982: To set the speed of the bike correctly for that place on the track (or road) so that no further changes are necessary. In other words, you get it right. Not too fast, not too slow. Braking itself is an art within the art of cornering. Your sense-of-speed is the underlying resource you have to get it right. As an exercise, no brakes riding will help improve your sense-of-speed. Do no-brakes whenever you have the opportunity and see what happens to your sense of speed and see what happens to your riding. The best part is that once you have combined a good sense of speed with the other twelve basic skills of cornering it all begins to come together. It is truly one of the skills that allows you to discover the ART OF CORNERING. All the best, Keith Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Mos Craciun Postat Ianuarie 4, 2005 Share Postat Ianuarie 4, 2005 Tare articolul. Insa chiar nu putem gasi nicaieri cum anume se ia un viraj? Se intra in frana fata spate pana la mijloc sau doar in frana de motor? Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
