PROBLEME AMBREIAJ
SALUT
DUPA CUM MAI STITI DIN UNELE TOPICURI DESCHISE DE MINE AM O APRILIA RS 125..
AM O MARE PROBLEMA LA AMBREIAJ ...
SI ACEA PROBLEMA E: CAND PORNEC IN VITEZA 1 DA SA PLECE DE PE LOC , IAR DAK O PORNESC PE LIBER SI AM BAGAT IN VITEZA DAK NU ACCELEREZ SE OPRESTE:(
ACUM ...AM CITIT MAI MULTE TOPICURI DESPRE ASA CEVA ...DAR SE PARE CA NU MAU AJUTAT ASA MULT
AM INCERCAT SA REGLEZ AMBREIAJUL DIN INTINZATORUL DE PE MANER ...NIMIC
AM INCERCAT SA REGLEZ DIN SURUBUL ACELA DE PE FURCA DIN CUTIE ...NIMIC
AM CUMPARAT O FURCA NOU SI SPRE UIMIREA MEA NU AVEA ACEL SURUB CU CONTRAPIULITA ...AM PUS SURUBUL DE LA CEALALTA FURCA ...LA FEL
INTR`UL FINAL SA STRICAT SI LA FURCA ASTA FILETUL ACELA INTERIOR ( E DIN ALUMINIU SI DE NU ESTI ATENT , TAC PAC ALTI BANI )
DE DATA ASTA NU AM MAI CUMPARAT NICI O FURCA ...AM BAGAT UN SURUB MAI MARE(GROS) ...DAR TOT ASA FACE SINCER SA FIU NUSH CE SA II MAI FAC ....
AVETI CAREVA VREO IDEE????
MSI SI ASFALT USCAT ALL!!!!
Editat de Diabolic_Nightwing
Ai incercat sa schimbi uleiul din cutie ? Daca ai un ulei vechi si gros pana se incalzeste tine discurile lipite si practic nu decupleaza.
TOT ASA FACE SI CAND E ULEIUL CALD
ADIK DUPA CE MERG CU EA CEVA KM TOT ASA FACE :lol:
SINCER NUSH CE SA II MAI FAC
DAK STII VREO SOLUTIE AS FI RECUNOSCATOR
oala de ambreiaj a facut santuri din cauza discurilor
UZE CA AM INTARZIAT
AM DEMONTAT SI AMBREIAJUL SI NU ARE NICI UN SANT PE OALA DE LA AMBREIAJ
DAR SA VA SPUN O SIMPTOMA CARE E MAI NOUA
AM PORNIT MOTORUL FARA ULEI IN CUTIE SI MERGEA PERFECT ...CAND IAM PUS ULEIUL INAPOI ACEEASI PROBLEMA CA CEA DE MAI SUS ...DA SA PLECE ...
CRED CA E VINA ULEIULUI DIN CUTIE ...CU TOATE CA PE STICLA SCRIA ULEI DE CUTIE DARA CUM CRED CA NU E BUN
MSI INCA O DATA
ASFALT USCAT
