cezarzanf Postat Septembrie 7, 2010 Share Postat Septembrie 7, 2010 Salut. Am gasit pentru motocicleta mea placute frana spate SBS LS. Pe unele site-uri apar ca SBS LS si pe altele ca SBS LS Street Excel. Ba chiar pe unele am gasit doar SBS Street Excel. Toate aceste denumiri duc la un singur model de placute? Adica SBS LS Street Excel? Adica aceasta este denumirea completa? Sau sunt modele diferite? Si care este diferenta daca sunt 2 modele diferite din punct de vedere al performantei? Pretul este identic ca sa zic asa intre modele de mai sus. SBS 586 LS este modelul indicat pentru motocicleta mea din ce am vazut la SBS in catalog. Multumesc. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Thomas Postat Septembrie 8, 2010 Share Postat Septembrie 8, 2010 LS Street Excel este denumirea completa, multi folosesc doar COD si LS The perfect combination of fade free brake performance, brake feel and thermal stability, especially developed for sport riding and high loads from heavy motorcycles. The HS lining is rotor friendly, the performance is stable under dry as well as wet conditions and no thermal bedding-in is required.Recommended for newer high performance, sports, touring and custom motorcycles which are originally equipped with sinter metal brake pads. For example Honda CBR & VT, Kawasaki ZX & VN, Suzuki GSX-R & VL. Yamaha YZF & XV and Harley Davidson’s. Sinter metal brake lining LS for the rear brake with high thermal stability which in combination with HS for the front brake provides the necessary and expected brake performance. To avoid excessive braking of the rear wheel, the friction level of the LS lining is adjusted to match the friction characteristics of the HS lining, according to the concept of the originally equipped sinter metal brake pads. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
