Vreau Sa Inteleg Si Eu Ceva
Redresor
am gasit faza asta pe net si nu prea inteleg eu ce vrea sa spuna :
Steering
Steering a motorcycle at low speeds is a straightforward process. The rider simply turns the handlebar in the direction he wishes to go. This only works at speeds below five miles an hour. If a motorcycle is traveling any faster, the rider must use a different kind of steering, known as counter-steering. This type of steering may seem counterintuitive. That's because motorcycle riders must push the handlebars to the left to make the vehicle turn right and vice versa.
Here's how it would work out on the street. Imagine that you're riding a motorcycle on the interstate. In front of you, blocking the right half of your lane, is a wreck or some other obstacle. If you're a novice rider, you might be tempted to push on the right side of the handlebar, thinking this will turn the bike to left. In reality, this will steer the bike to the right, directly into the obstacle. Instead, you should push on the left side of the handlebar, which directs the front wheel to the right but steers the vehicle to the left.
Adik intleg engleza ,dar modalitatea de condus....... :baldy: ;)
