E Fiabila Husqvarna Te 610 E ?
Metallbyker
E fiabila Husqvarna TE 610 E ?
35 membri au votat
Salut , vreau pareri despre o motocicleta : Husqvarna TE 610 E An:1999 . Ma intereseaza cat de fiabila este (in mers normal cu ea nu pe creasta muntelui) , si ce probleme apar la ea care sunt mai grave (daca detineti , daca stiti pe cineva care are , sau din auzite)
Model: Husqvarna TE 610 E
Year: 1999
Category: Enduro / offroad
Rating: 71 out of 100. Show full rating and compare with other bikes
Engine and transmission
Displacement: 577.00 ccm (35.21 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: 46.00 HP (33.6 kW)) @ 7100 RPM
Compression: 9.0:1
Bore x stroke: 98.0 x 76.5 mm (3.9 x 3.0 inches)
Valves per cylinder: 4
Starter: Electric & kick
Cooling system: Air
Gearbox: 6-speed
Transmission type
final drive: Chain
Physical measures
Weight incl. oil, gas, etc: 156.0 kg (343.9 pounds)
Front percentage of weight: 47.0
Seat height: 890 mm (35.0 inches) If adjustable, lowest setting.
Wheelbase: 1,500 mm (59.1 inches)
Chassis and dimensions
Front suspension travel: 280 mm (11.0 inches)
Rear suspension travel: 285 mm (11.2 inches)
Front tyre dimensions: 90/90-R21
Rear tyre dimensions: 140/80-R18
Front brakes: Single disc
Front brakes diameter: 260 mm (10.2 inches)
Rear brakes: Single disc
Rear brakes diameter: 220 mm (8.7 inches)
Speed and acceleration
Top speed: 160.0 km/h (99.4 mph)
0-100 km/h (0-62 mph): 5.600 seconds
60-140 km/h (37-87 mph), highest gear: 16.800 seconds
Other specifications
Fuel capacity: 9.10 litres (2.40 gallons)
Fuel consumption pr. 10 km (6.2 miles): 0.54 litres (0.14 gallons)
:lol:
up:)
am postata gresit.. :lol: eu am zis ca e un gunoi ;)
dar nu e asa.......husqvarna e veche in domeniul motocicletelor....si cred ca e detul de fiabila
De ce sa nu fie ? Nu am asa ceva si nici nu m-am plimbat, dar cred ca nu e' mai putin fiabila decat un ..... LC4, sau EXC, de exemplu.
Oricum, este un motor ,,marfa", nu stiu cum e' cu piesele de schimb. Am auzit ca le gasesti cam rar, dar cred ca merg multe de la KTM.
Bafta! :burnout:
Bafta! :burnout:
1. Intre LC4 si EXC nu poate exista comparatie. Solutiile tehnice ale motoarelor sunt diferite. Una este racing pur-sange (EXC).
2. Ai dreptate. Husqvarna este slab reprezentata pe piata. Piesele nu se prea potrivesc. Nu confunda Husqvarna cu Husaberg. La Husaberg se potrivesc piesele de KTM. Sunt surori.
Vis-a-vis de fiabilitatea Husqvarnei nu cred ca o sa ai o parere obiectiva de la vreun roman pentru ca sunt foarte putini utilizatori ai unei astfel de motocicleta. Aceiasi dilema am avut-o si eu cand am cumparat Husaberg.
Bafta oricum.
Husqvarna sunt motoare tari, facute pentru competitii. Sunt fiabile daca sunt intretinute asa cum spune cartea.
Daca e modelul cu pompa de ulei atunci e OK. Cele de pana in 1999 parca nu aveau pompa de ulei si din cauza asta se cam lipeau pistoanele.
Problema generala e aprinderea (daca e Ducati e un gunoi) Aprinderile suedeze SEM sunt mult mai bune.
Daca planuiesti sa o cumperi si sa te plimbi cu ea pe sosea atunci mai bine cumpara-ti altceva.
Nr. de km este irelevant. Uzura la aceste motociclete se masoara in ore de functionare
Bafta oricum.
:burnout:
Asa este, insa ma refeream la fiabilitate. Dracu', este motor facut in secolul XXI, nu o plesnii asa repede.
Stiu, LC4 nu este motor de curse si nu poate fi comparat cu un EXC. Ma refeream ca motoarele sunt fabricate in ,,era noastra".
Bafta! ;)
Editat de petrica
