Costel Albot Posted February 10, 2017 Share Posted February 10, 2017 Salut,am un Derbi GPR 125 2T si nu are scînteie la bujie cauza ar fi firele si am nevoie de o schema ce am gasit nu cam se intelege Motorul mergea perfect pina am scos CDI si cind lam pus la loc am incurcat mufele cu locul si de atunci..... Rog un admin sa-mi schimbe topicul daca nu am scris unde trebuie Quote Link to comment Share on other sites More sharing options...
dedant68 Posted February 11, 2017 Share Posted February 11, 2017 Salut, Spune-mi daca CDI-ul este in corp comun cu bobina de inductie? De asemenea, daca conductoarele care ajung la CDI sunt culorate in: verde, alb si rosu Numai bine, Quote Link to comment Share on other sites More sharing options...
Costel Albot Posted February 11, 2017 Author Share Posted February 11, 2017 Spre CDI se duc 3 mufe si nu se afla in corp comun cu bobina Poze cu CDI si bobina de inductie http://imgur.com/daI7PRz http://imgur.com/kSQbWFo http://imgur.com/OV2FQSj Quote Link to comment Share on other sites More sharing options...
dedant68 Posted February 11, 2017 Share Posted February 11, 2017 Referinte la CDI O mufa are 4 pini/orificii, iar celelalte doua au 6 pini/orificii ? Nu imi dau seama din foto ! Quote Link to comment Share on other sites More sharing options...
Costel Albot Posted February 11, 2017 Author Share Posted February 11, 2017 Exact Quote Link to comment Share on other sites More sharing options...
dedant68 Posted February 11, 2017 Share Posted February 11, 2017 Cred ca inversat cele doua mufe cu 6 pini intre ele, adica cea care se conecteaza cu generatorul si cea care comanda servomotorul( fluxul gazelor de evacurea). Prima, cea cu 4 pini se conecteaza la bobina si la contactul cu cheie/ignition. Conecteaza conform schemei din imagine si spune-mi ce ai rezolvat. Mufa cu 6 pini mai scurta-generator, a doua cu 6 pini- servomotor si ultima la bobina+ contact Quote Link to comment Share on other sites More sharing options...
Costel Albot Posted February 11, 2017 Author Share Posted February 11, 2017 Acus am sa incerc ,pina diseara iti dau raspuns Dar o schema la toata instalatia electrica na-i?adica fiecare fir unde trebuie sa se duca Tot nu are scinteie am pus mufele asha cum miap spus Quote Link to comment Share on other sites More sharing options...
dedant68 Posted February 12, 2017 Share Posted February 12, 2017 Verifica cu atentie toate conexiunile si identifica corect circuitele. Este posibil sa fie afectat CDI-ul daca nu ai respectat initial schema de conexiuni. Quote Link to comment Share on other sites More sharing options...
Costel Albot Posted February 12, 2017 Author Share Posted February 12, 2017 Ma gindeam si eu ca cdi e devina dar inainte sa deschid acest topic am comandat din italia alt cdi cu alta instalatie si alta bobina si tot nimic dar mai este una ca dupa ce am incurcat mufele peurma leam pus corect si motorul pornea doar ca nu actiona la acceleratie deloc ,peurma am mai umblat prin electrica si deja nu se mai pornea dar avea scinteie pe 2-3 sec si iar nu avea il mai lasam jumate de ora si iar avea scinteie pe 2-3 secunde si acuma nu are nimic Quote Link to comment Share on other sites More sharing options...
Recommended Posts
