Harley Leaning Trike - Ii Bate Gandul De Asa Ceva?
Mr.Wattmaster
Am dat de asta accidental, pe thekneeslider.com
http://thekneeslider.com/archives/2007/06/...nt-application/
Aruncati un ochi si acolo pentru poveste cat mai ales pe insasi documentul de patentare in sine
http://appft1.uspto.gov/netacgi/nph-Parser...dson%22&OS=
Desenele din dosarul de patentare
The present invention relates to a suspension system for a three-wheeled vehicle. The suspension system permits the vehicle to lean while cornering, much like a motorcycle. This is accomplished via hydraulic actuators that force the bike into a leaning position while turning, and back to an upright position while tracking a straight line. A transverse beam is coupled to the hydraulic actuators and to spring dampers to allow the suspension to operate independently, even while the vehicle is cornering.
Sincer, nu stiu ce i-a apucat. :burnout:
Si nici vorba de clasicul concept de trike.
Now that's a hard nut!
Am vazut nishte scutere,asa...Aprilia Fuoco (parca),de 500 cmc si Piaggio nu-stiu-cum,de 125 cmc. E tendinta...Mi-i se pare ciudata ,ca rotzile din fatza sunt foarte departate de motocicleta...Ocupa spatiu cat o masina...!
De cand au scos aia de la Piaggio scuterele lor, 'brusc' toti s-au trezit ca, de fapt, e o idee misto. Deh, asa-i in afaceri, toata lumea vrea sa omoare ariciu' cu curu' altuia. Eniuei...
Principalu' avantaj al asteia e ca, in cazul unui viraj luat mai 'energic', nu risti sa te dai cu zgaibaracele-n sus ca-n cazul unei triciclete obisnuite. Plus ca, daca rupi aderenta pe roata spate si stii cum sa-nclini trocariciul, tragi niste drifturi de le ploo-n gura alora din Tokyo (evident, asta daca nu pun si ei frane combinate, cum au facut aia de la Can-Am).
