Reverse Postat Mai 29, 2006 Share Postat Mai 29, 2006 Am facut un topic cu piese si preturile lor ptr orice modificare la Aprilia Rs125...vor fi facute si ptr alte modele separat,informatii utile daca aveti puneti aici nu comentarii inutile venite de la diferiti "rossi" sau "ghost rideri" Exhausts - Arrow Carbon/Kevlar Can: £94.95 - Arrow Mild Steel & Carbon/Kevlar Can: £239.95 - Jim Lomas Mild Steel & Stainless Can: £199.95 - Jim Lomas Mild Steel & Carbon Fibre Can: £224.95 - Jim Lomas Twin Exit Mild Steel & Carbon Fibre Can: £224.95 - Jim Lomas Stainless Steel and Stainless Steel Can: £234.95 - Jim Lomas Stainless Steel and Carbon Fibre Can: £259.95 - Jim Lomas Twin Exit Stainless Steel and Carbon Fibre Can: £289.95 Transmission & Clutch Front Sprockets; - JT Sprockets 14 Tooth Front Sprocket: £6.45 - JT Sprockets 15 Tooth Front Sprocket: £6.45 - JT Sprockets 16 Tooth Front Sprocket: £6.75 - JT Sprockets 17 Tooth Front Sprocket: £6.95 - Renthal 14 Tooth Front Sprocket: £6.45 - Renthal 15 Tooth Front Sprocket: £6.45 - Renthal 16 Tooth Front Sprocket: £9.45 - Renthal 17 Tooth Front Sprocket: £9.45 Rear Sprockets; - JT Sprockets 39 Tooth Rear Sprocket: £14.45 - JT Sprockets 40 Tooth Rear Sprocket: £14.45 - JT Sprockets 41 Tooth Rear Sprocket: £15.95 - JT Sprockets 42 Tooth Rear Sprocket: £15.95 - JT Sprockets 43 Tooth Rear Sprocket: £15.95 - Renthal Alloy 38 Tooth Rear Sprocket: £20.95 - Renthal Alloy 39 Tooth Rear Sprocket: £20.95 - Renthal Alloy 40 Tooth Rear Sprocket: £20.95 - Renthal Alloy 41 Tooth Rear Sprocket: £20.95 Chains; - IRIS Heavy Duty Nickel Chain: £39.95 - IRIS Heavy Duty Gold O-Ring Chain: £45.95 - IRIS Heavy Duty Gold X-Ring Chain: £55.95 - Renthal Gold Non-O-Ring Chain: £35.95 - Renthal Gold O-Ring Chain: £49.95 Clutch Components; - EBC Heavy Duty Clutch Springs: £8.45 - EBC Uprated Clutch Plates: £35.45 Carbon Fibre - Fibre-Lyte Carbon Fibre Yoke Protector: £15.45 - Fibre-Lyte Carbon Fibre Instrument Surround: £19.45 - Fibre-Lyte Carbon Fibre Filler Cap Cover (6 Bolt): £17.95 - Fibre-Lyte Carbon Fibre Filler Cap Cover (5 Bolt): £17.95 - CMP Racing Carbon Fibre Front Mudguard: £82.95 - CMP Racing Carbon Fibre Rear Hugger: £76.95 - CMP Racing Carbon Fibre Heel Plates: £44.95 - CMP Racing Carbon Fibre Chain Guard: £30.95 Notes: All carbon fibre is made using the finest of materials and resins (epoxy resin) and NOT using polyester resins which are flexible, cheaper to make and can crack easily. Brake Components Brake Pads; - EBC FA126HH Sintered Front's £16.95 - EBC FA47HH Sintered Rear's £14.95 - EBC FA126 Standard Kevlar Front's £14.45 - EBC FA47 Standard Kevlar Rear's £10.45 Brake Discs; - EBC Pro-Lite Disc: £134.95 - EBC Pro-Lite Contour (Wave) Disc: £144.95 - EBC Rear Disc: £59.95 - Brembo OE Front Disc: £139.95 - Brembo MQ Gold Front Disc: £194.95 - Galfer Wavey Disc: £174.95 Brake Lines - Goodridge SS Braided Front Line With SS Fixings: £32.95 - Goodridge SS Braided Rear Line With SS Fixings: £32.95 - Goodridge SS Braided Front & Rear Line Kit With SS Fixings: £65.95 Ignition Systems/Plugs Spark Plugs; - Denso W31ESR-U Standard Plug: £2.45 - Denso W31ESR-ZU Platinum Racing Plug: £6.95 - Denso IW31 Iridium Racing Plug: £13.95 - NGK B10EG Standard Plug: £3.45 - NGK B10EGV Platinum Plug: £6.95 - NGK BR10EIX Iridium Plug: £9.45 Racing CDIs; - CMP Programmable Racing CDI: £194.95 - CMP Dual Map Programmable Racing CDI: £254.95 - CMP CDI Re-Programmer: £139.95 Screens & Headlamp Covers 1993-1995 - Skidmarx Standard Screen (93-95): £35.95 - Skidmarx Flip Screen (93-95): £35.95 - Skidmarx Headlamp Cover: £16.45 1995-1998 - Skidmarx Standard Screen: £35.95 - Skidmarx Flip Screen: £35.95 - Skidmarx Double Bubble Screen: £50.95 - Skidmarx Headlamp Cover: £18.45 1999-2004 - Skidmarx Standard Screen: £35.95 - Skidmarx Double Bubble Screen: £49.95 - Skidmarx Headlamp Cover: £18.45 Air Filters; - CMP Racing Panel Filter: £8.45 - PiperX Panel Filter: £18.95 - PiperX Conical Filter: £29.95 - PiperX Power Cone: £39.95 Reeds & Reed Blocks; - Hy-Tech Carbon Fibre Reeds: £19.95 - V-Force 3 Dual Stage Reed Block: £124.95 Carburettors; - CMP Racing 34mm Carb Kit w/ Rotax 34mm Manifold: £174.95 - Dell’Orto PHBH Main Jets: £2.75ea. - Dell’Orto VHSB Main Jets: £2.75ea. - Dell’Orto PHBH Idle Jets: £3.45ea. - Dell’Orto VHSB Idle Jets: £5.95ea. - Dell'Orto VHSB 34mm Carb: £149.95 - Rotax 34mm Manifold: £34.95 Suspension Front Forks; - Ariete Fork Seals: £6.95 - PJ1 Fork Oil 1 Litre (2.5W ~ 15W): £5.95 - CMP Racing Anodising Fork Service: £124.95 Rear Shocks; - Niton Adjustable Rear Shock: £312.95 - Nitron Fully Adjustable Rear Shock With Remote Reservoir: £409.95 - Hyperpro Adjustable Rear Shock: £329.95 - Hyperpro Fully Adjustable Rear Shock With Remote Reservoir: £489.95 Bodywork Solo Rear Seat Unit: £TBA Engine - VHM Head Insert (Standard Piston): £74.95 - VHM Head Insert (Flat Top Piston): £74.95 - Single Ring Flat Top Piston: £49.95 - Mikata 122 Rebuild Kit: £219.95 - Mikata 123 Rebuild Kit: £219.95 - PRO-X Piston & Rings: £59.95 - Small End Bearing: £5.95 - Top End Gasket Set: £19.95 - Full Engine Gasket Set: £34.95 - Main Bearings: £22.95 - Crank Case Seals: £9.95 Pro-Bolt Bolt Kits - Engine Bolt Kit: £22.45 - Fairing Bolt Kit: £34.45 - Screen Bolt Kit: £7.45 - Tank Bolt Kit: £5.45 - Anodised Dust Caps: £3.45 (Pair) Notes: Prices quoted are for 1999 onwards bikes, for earlier models contact me for information and prices. Anodized alloy parts are available in Red / Blue / Green / Gold / Purple / Black & Silver. Accessories - Renthal Grips (Soft/Med/Firm): £6.95 - Aluminium Bar Ends: £TBA - Silkolene Light Gear Box Oil: £TBA - Silkolene Comp 2+: £TBA - Castrol TTS: £TBA - R-Clips: £0.25ea. Dupa cum stiti (sau nu ) cele mai performante evacuari ptr Rs125 sunt cele Jim Lomas ,atasez cateva poze si niste detalii in engleza,cine nu stie limba ghinion These exhausts are pure race bred systems, they weigh one quarter of the weight of the standard RS125 system, not only are they lighter, they are designed to give improvements all through the rev range. These exhausts are non-restrictive and will increase the power output of your bike, as well as unleashing the sound of a real two stroke race bike. Jim Lomas exhausts are available in a range of materials; stainless steel, the stainless expansion chambers do not corrode so will never need to be painted if it gets mucky simply give it a rub with some metal polish, or there’s mild steel, although slightly lighter than the stainless system, they will be prone to rusting like any mild exhaust system. There is also the option of a twin system, this system uses the same expansion chamber design as the single, the main difference is it has two silencers! These systems are only available in stainless steel with carbon fibre silencers. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
GSK Postat Mai 29, 2006 Share Postat Mai 29, 2006 (editat) reverse, iti asumi responsabilitatea in cazul unei comenzi? sau tot la Sean comandam? Editat Mai 29, 2006 de GSK Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
soriyn17 Postat Mai 29, 2006 Share Postat Mai 29, 2006 good job, s-a rezolvat si problema "cam cat ar costa..." Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Reverse Postat Mai 29, 2006 Autor Share Postat Mai 29, 2006 GSK a spus: reverse, iti asumi responsabilitatea in cazul une comenzi? sau tot la Sean comandam? Am un prieten care a comandat de pe site de la baiatul din UK,pot vorbii cu el sa va faca legatura sau comandati voi direct edit : cateva poze cu diferite rs`uri,gasiti si de la noi pe aicea din Constanta orasul cu cele mai multe rs`uri si cele mai modificate,tineti`o tot asa baietii Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
rss Postat Mai 29, 2006 Share Postat Mai 29, 2006 deci si rsu meu era frumos tetsuya harada:) Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
CobraArt Postat Mai 29, 2006 Share Postat Mai 29, 2006 GSK a spus: reverse, iti asumi responsabilitatea in cazul unei comenzi? sau tot la Sean comandam? Am luat eu toba de la ei si sunt de incredere Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
GSK Postat Mai 29, 2006 Share Postat Mai 29, 2006 (editat) scuze... eu glumeam cu domnul reverse. stiam ca cei din Anglia sunt de incredere. vroiam sa vad cum se prezinta reverse. ca fiind vanzator al acestor produse, intermediar, ..etc. Editat Mai 29, 2006 de GSK Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Reverse Postat Mai 29, 2006 Autor Share Postat Mai 29, 2006 GSK a spus: scuze... eu glumeam cu domnul reverse. stiam ca cei din Anglia sunt de incredere. vroiam sa vad cum se prezinta reverse. ca fiind vanzator al acestor produse, intermediar, ..etc. eu sunt baiatul cu informarea si sfaturile Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Reverse Postat Mai 29, 2006 Autor Share Postat Mai 29, 2006 Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
sebby Postat Iunie 1, 2006 Share Postat Iunie 1, 2006 frumos foc rs-ul asta vopsit cu flacari.. de cat e? 250?(ca vad ca are 2 tobe, dar totusi parca-mi pare cam subtirica in latime..) Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
CobraArt Postat Iunie 1, 2006 Share Postat Iunie 1, 2006 125 Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
