Hyosung RT 125 D
Salut...am deschis acest topic.. pt ca m-am gandit de ceva timp sa imi achizitionez un Hyosung RT 125 D ... insa as vrea niste pareri de la voi cunoscatori daca se merita sa imi iau? Imi iau necaz pe cap? sau e un motor bunicel la 125 cmc in 4 timpi? Motorul nu este nou... stiu insa ca e folosit de un instructor de motociclete... pt invatare... are ceva zgarieturi...dar nu e lovit sau busit:)
adaug niste poze optionale sa vedeti si motoru:)
Am ales sa imi iau acest motor...pt ca stau intro zona de tara... si ma drumuri destul de proaste, bine o sa am de gand sa ies si cu el in oras.
Niste specificatii:
Model: Hyosung RT 125 D
Year: 2007
Category: Allround
Rating: 69.6 out of 100. Show full rating and compare with other bikes
Safety: See our safety campaign with the high safety rated bikes in this category.
Price as new (MSRP): Euro 2912. Prices depend on country, taxes, accessories, etc.
Engine and transmission
Displacement: 124.50 ccm (7.60 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: 13.40 HP (9.8 kW)) @ 10000 RPM
Bore x stroke: 57.0 x 48.8 mm (2.2 x 1.9 inches)
Fuel system: Carburettor. Euro 3
Valves per cylinder: 4
Fuel control: DOHC
Ignition: Digital
Starter: Electric
Cooling system: Oil & air
Transmission type
final drive: Shaft drive (cardan)
Physical measures
Dry weight: 125.0 kg (275.6 pounds)
Weight incl. oil, gas, etc: 135.0 kg (297.6 pounds)
Seat height: 790 mm (31.1 inches) If adjustable, lowest setting.
Overall height: 1,125 mm (44.3 inches)
Overall length: 2,085 mm (82.1 inches)
Overall width: 840 mm (33.1 inches)
Ground clearance: 230 mm (9.1 inches)
Wheelbase: 1,350 mm (53.1 inches)
Chassis and dimensions
Frame type: Steel
Front suspension: Telescopic
Rear suspension: Monoshock
Front tyre dimensions: 130/80-18 66P
Rear tyre dimensions: 180/80-14 78P
Front brakes: Single disc. 2-piston caliper
Front brakes diameter: 275 mm (10.8 inches)
Rear brakes: Expanding brake (drum brake)
Rear brakes diameter: 130 mm (5.1 inches)
Speed and acceleration
Top speed: 105.0 km/h (65.2 mph)
Power/weight ratio: 0.1072 HP/kg
Other specifications
Fuel capacity: 9.10 litres (2.40 gallons)
Fuel consumption pr. 10 km (6.2 miles): 4.00 litres (1.06 gallons)
Color options: Orange, Metallic Blue
Modifications compared to previous model: Equipped with oil cooler, DOHC, Digital cockpit and improved rear suspension. Digital speedometer + Oil cooler + Dual Overhead camshaft + Nickel Rims + 15% more engine power + Better rear suspension
Astept parerea voastra:) Va multumesc!!!!
Mesaj completat
Revin si cu poze cu motoru despre care vorbeam sa il cumpar:)
post-57284-1275138612_thumb.jpgpost-57284-1275138592_thumb.jpgpost-57284-1275138621_thumb.jpgpost-57284-1275138636_thumb.jpgpost-57284-1275138642_thumb.jpgpost-57284-1275138649_thumb.jpg
Niste specificatii:
Year: 2007
Category: Allround
Stroke: 4
Fuel control: DOHC
Ignition: Digital
Starter: Electric
Transmission type
Physical measures
Frame type: Steel
Mesaj completat
Cati bani dai pe el ?? Nu o fi cazut sau stiu eu , dar gandeste-te daca a fost folosit la scoala , pe el au mers diferiti elevi care nu poti sa sti cum l-au folosit . Poate il baga aiurea in viteza , poate mai trosnea una alta , foloseau ambreiaju ala excesiv. Parerea mea e ca ar fii ideal pentru zona in care stai tu , dar mergi cu el ( sau poate ai mers ) si vezi cum se comporta.
OFF TOPIC : Chiar nu imi poate imprumuta si mie cineva maine un stender plssssss !!!! Am nevoie pentru roata fatza Dau o cola. :lol:
Salut ,
am mers si eu cu motoru' ala la scoala , ca eu am facut scoala la ADI MOTO .. Ce sa zic merge cam praf ... si a fost si cazut .. Eu zic sa te mai gandesti ... Cat ti-a cerut pe el ?
Salut ,
2200lei;))) mai are ceva de 200 qlink parca, cu ala ai fost? cam in ce stare e?
Pff , se aflta intr-o stare foarte jalnica ...
In prmu' rand saua este super praf facut ...
Motoru' se aude urat ..
Guma de pe spate e foarte uzata , daca nu o fi schimbat-o ..
Ambreijau are inceput de sfarsit ..
la care te referi. ? la hyosung sau la qlinq?
