jawa 500 R
cristian78
http://www.jawa500r.org.uk/Can I fit a rotax engine in my Jawa.htm
:wave:
Question:Can I fit a 500cc Rotax engine in my Jawa350?
Answer: Don't bother unless you have a lot of money or you are a skilled engineer.
Here's why.
Below is a list of the alterations you will have to carry out.
The frame has been altered at the front and rear and an extra mounting point fitted underneath the engine.
The electics have to be altered because the engine has a seperate ignition
and charging circuits.
You will have to fit a voltage regulater/rectifier.
The exhaust is completely different to the 350 and would not fit at all.
You would probably have to make a throttle cable to fit which carbureter you
fit.A dellorto is the best but the Jawa 500R's were fitted with an Amal in
the UK.
There is no speedo drive on the engine so another drive will have to be used
on the front wheel.
There two types of front brakes fitted to the 500R.A drum brake with heavier
brake shoes and a hydralic disc.
The chain is bigger and the rear sprocket is unique to the Jawa 500R.It
looks the same as the standard 350 rear sprocket but they are different
sizes and cannot be interchanged.
You will also have to remove the enclosed chain and fit a chain guard to the
rear swinging forks.
The foot peg on the left side of the bike is also mounted differently and is
shorter.This is for the kick start and the gear lever.
You will also have to convert the left side panel/oil tank for the oil pipes
to and from the engine and a breather hose.
The air filter will not fit and you will have to remove the air box and fit
a K&N or something like it.
You will also have to fit a valve lifter to start the engine.
If I haven't put you off the idea then good luck with the work.
Potzi sa pui si alt motor nu numai cel rotax.De exemplu stiu ca se potrveste fara nici un fel de modificare la cadru si la prinderi motorul de la un model de suzuki in 2 cilindri,4 timpi.faza nashpa ca motorul ala e de 250,dar stiu pe cineva care a facut asa ceva si nu are nici un fel de problema,adik merge de rupe.
e bun si de 250 !
Totusi inca ma intreb daca merita. Ideea pentru care ma gandesc la aseasta modificare este sa cresc fiabilitatea cu bani putini! :wave: . Cu bani putini nu cred ca imi pot lua decat un motor in 4 timpi destul de uzat -> asa ca fiabilitatea este cu semnul intrebarii.
Cred ca voi renunta la aceasta ideea, mai bine imi iau o motocicleta sh in 4 timpi, dar momentan raman la jawa.
Merci.
P.S. oricum e de apreciat ce au reusit sa faca unii din jawa.
ceea ce ma intereseaza este:
un motor in 4 timpi cu minim 350 cmc.
sa nu coste mult .... :huh:
sa functioneze bine....
sa nu necesite modificari complexe la cadru.
sa nu necesite schimbarea basculei ....
In conditiile date mai sus cred ca reusesc sa o modific.
Ecuatia data mai sus are vreo rezolvare ??
P.S. ceva cunostinete de mecanica mai am (doar am terminat inginerie mecanica :wave: )
