VICTORY MOTORCYCLES
robychopper
ridicat minge la fileu...
sa continuam
mdelele 2005
1. Kingpin
Kingpin features
Freedom 92/5, fuel-injected and counterbalanced.
Aluminum swingarm with rising-rate linkage rear suspension for a smooth ride.
Deeply contoured seat. And full, vibration-absorbing floorboards.
Inverted front fork, 6-spoke cast aluminum wheels and fully valanced fenders.
New self-canceling turn signals and new paint schemes.
Engine
Engine Type 4-stroke 50° V-Twin
Cooling System Air/Oil
Displacement 92 cu in/1507cc
Bore x Stroke 97x102mm
Compression Ratio 9.2:1
Valve Train Single overhead camshafts with 4 valves per cylinder, self-adjusting cam chains, hydraulic lifters
Fuel System Electronic Fuel Injection with 44mm throttle bodies
Fuel Capacity 4.5/17.0 U.S. gallons/liters
Exhaust Staggered slash-cut dual exhaust with common volume
Oil Capacity 6.0qts/5.7ltr
Charging System 38 amps max output
Battery 12 volts/18 amp hours
Primary Drive Gear drive with torque compensator
Clutch Wet, multi-plate
Transmission 5-speed constant mesh
Final Drive Reinforced belt
Brakes
Front Brake 300mm floating rotor with 4-piston caliper
Rear Brake 300mm floating rotor with 2-piston caliper
Dimensions
Length 99.1/2519 in/mm
Wheelbase 65.6/1690 in/mm
Seat Height 26.5/673 in/mm
Ground Clearance 5.8/148 in/mm
Rake/Trail 32.8°/5.44/138 in/mm
Dry Weight 639/290 lbs/kg
GVWR 1154/524 lbs/kg
Suspension
Front Suspension Inverted cartridge telescopic fork
Rear Suspension Single, mono-tube gas/forged and cast aluminum w/ rising-rate linkage/3.9in. (100mm) travel/preload adjustable spring
Tires
Front Wheel 18x3in
Rear Wheel 18x5.0in
Front Tire 130 70-18 Dunlop Elite II
Rear Tire 180 55-B18 Dunlop D417
Victory Kingpin Awards
The Victory Kingpin was an immediate hit when it was introduced for 2004. It became a popular choice among riders who love to pile up the miles, and won awards that included:
Best New V-Twin Motorcycle, V-Twin Magazine
Easyriders Best American Motorcycles of 2004 Top 10 Bike
2. Vegas
la celelalte modele specificatiile tehnice sunt aproximativ aceleashi, asha ca nu le mai postez!!!
Vegas features
Custom one-piece sculpted tank with raised spine and split tail.
Frenched rear fender over the 180 mm rear tire.
Laced wheels.
Freedom 92/5. It’s an overhead-cam, 4-valve, fuel-injected and counterbalanced.
Rubber-mounted handlebar with new self-canceling turn signals.
Bold, new paint.
Victory Vegas Awards
The Victory Vegas™ wowed the motorcycle world when it made its debut in 2003, sweeping the year’s best cruiser awards from four leading motorcycle enthusiast magazines. The 2003 Vegas awards included:
Best Cruiser, Cycle World
Cruiser of the Year, Cruising Rider
Best Cruiser, Motorcyclist Magazine
3. HAMMER
Hammer features
100 cubic inch Freedom V-Twin, fuel-injected and counterbalanced.
Super fat rear tire. Measuring an impressive 250 mm, it’s the largest tire ever attached to a production bike.
New 6-speed overdrive transmission.
Inverted cartridge fork.
Big rear fender.
Powerful front dual disc brakes.
Radical new paint.
4. TOURING CRUISER
Touring Cruiser features
Freedom 92/5 engine, equipped with counterbalancers and EFI
Rubber-mounted, vibration-isolating handlebar.
Cushioned floorboards, freeway bars, highway lights and windshield.
Lockable, hard saddlebags.
Standard passenger floorboards.
5. 8 BALL
8-Ball features
Black bodywork, black powdercoat, blacked-out front fork and triple clamp.
92 cubic inch, 4-valve, overhead-cam Freedom V-Twin.
Long, low design, one-piece sculpted tank with split tail, and a frenched rear fender.
Solo seat.
6. ARLEN SI COXY NESS au colaborat cu cei de la victory la 2 modele: Kingpin shi Vegas
NESS SIGNATURE SERIES KINGPIN™. TAKING THE FACTORY CUSTOM SOMEPLACE IT’S NEVER BEEN BEFORE.
The introduction of the Ness Signature Series Vegas last year set a new standard for the factory custom. This year, we set Arlen and Cory Ness loose on the Victory Kingpin. Once again, the bar has been raised. It starts with standard Kingpin genetics. Big fenders. Inverted front fork. Freedom 92/5 V-Twin. Comfortable ride. And an attitude from the other side of the tracks. But look deeper, and you’ll see this bike is a vision in Ness chrome and billet. Billet wheels, billet engine cover inserts and billet-style mirrors. You’ll also find a chrome swingarm, chrome foot controls, chrome passenger peg supports, chrome axle brackets, chrome triple clamps and chrome switch housings. If the Nesses could make it shine, they did. There’s a radical “Purple Haze” color scheme that tells you this didn’t run through any ordinary paint booth. There’s a radius drag bar with braided stainless cables and a custom-stitched ostrich-pattern seat. It’s finished with a Ness logo EFI cover and Ness signature side cover.
:huh: :laugh: :laugh:
  • 6 years later...
  • 11 months later...
Vad ca tocmai au incheiat un parteneriat cu Eicher Motors Ltd - producator Royal Enfield printre altele. Mi se pare mai inspirat decit asocierea HD/ATK/Hyosung.
Habar n-am de termenii asocierilor si nici nu ma intereseaza prea tare dar un Royal Enfield e infinit mai appealing decit orice ATK/Hyosung
http://hellforleathermagazine.com/2012/07/polaris-the-orient-express/
Bineinteles ca-i de preferat ca in ultima instanta sa-ti iei informatiile pentru decizia de cumparare din experienta directa, nu din presa. Totusi uite ca modelul Continental GT Cafe Race, ce urmeaza sa fie lansat in 2013, pare ca va fi echipat cu componenete Ohlint si Brambo.
http://www.b4bike.com/wheels/332/royal-enfield-cafe-racer-will-be-on-road-by-2013/
  • 4 months later...
  • 4 months later...
1. nu inteleg de ce diferentele de opinie se sustin mereu prin jigniri. pe langa asta, nu inteleg de ce tot timpul "sta cate unu' la panda sa-ti dea in cap" !!! raman neintelegator si ma mir cum motociclete si femeile starnesc aceeasi senzatie in barbati: fiecare crede c-o fooote cel mai bine....
2. nu inteleg de ce ma intereseaza polemica voastra.
3. da, mi se pare cel putin ciudat modul direct si pe fata si sustinut in vare cei de la Victory se iau la tranta cu HD. dar nu e problema mea, ci a lor, asa ca nu ma deranjeaza.
4. cine critica HD.... e prieten cu vulpea....erau strugurii acri. valabil insa si pentru cei ce critica Victory. am avut HD, chiar un model deosebit FXSTSSE2, dar cand bea 2l ulei in 2000km.....pe el si pe mama lui, ca mie nu-mi trebuie. sau cand sare vopseaua de pe cilindri ....la fel. sau cand lacrimeaza ulei, oricate garnituri ai schimba... tot la fel. da, am mers cu toate modelele de HD si pot spune ca sunt minunate; e o incantare sa le atingi si sa le calaresti...evident ca nu toate sunt pe gustul tuturor, fiecare cu ce i se potriveste, insa in afara de mangaieri placute....ca scumputza "curva", iar despre legenda......am cateva carti cu legende, nu-mi trebuie sa mai platesc una...
5. despre Victory, in afara de unele finisaje penale, da, arata penal, nu am multe de comentat. motorul imi place mai mult ca aspect. Visionul fata de Electra este insa mult mai manevrabil, usor, prietenos etc. am avut de ales si am ales. multe nu pot spune dupa 1200km, insa in iulie voi avea cam 16000km si voi reveni cu detalii. despre customizare....mda nu prea se gasesc piese, dar "nu prea" inseamna ca se gasesc dar cu mai mult efort.
numai bine tuturor
