alchool Postat Aprilie 19, 2010 Share Postat Aprilie 19, 2010 Noua mea achizitzie...........Cine mai are asa ceva? From Saturday night downtown cruising, sport-touring and commuting to drag-racing and even for casual track-day use! Here's a bike that does it all reliably, very quickly and with style and comfort General information Model: Yamaha FZX 750 Year: 1991 Category: Naked bike Engine and transmission Displacement: 749.00 ccm (45.70 cubic inches) Engine type: In-line four Stroke: 4 Power: 94.00 HP (68.6 kW)) @ 9500 RPM Compression: 11.2:1 Bore x stroke: 68.0 x 51.6 mm (2.7 x 2.0 inches) Valves per cylinder: 5 Fuel control: DOHC Cooling system: Liquid Gearbox: 6-speed Transmission type final drive: Chain Physical measures Weight incl. oil, gas, etc: 225.0 kg (496.0 pounds) Chassis and dimensions Front tyre dimensions: 110/90-16 Rear tyre dimensions: 140/90-15 Front brakes: Dual disc Rear brakes: Single disc Speed and acceleration Top speed: 216.0 km/h (134.2 mph) Other specifications Fuel capacity: 13.00 litres (3.43 gallons) Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Stephon Postat Aprilie 19, 2010 Share Postat Aprilie 19, 2010 hai hai...nu exagera! ) Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
soarecu Postat Aprilie 23, 2010 Share Postat Aprilie 23, 2010 Foarte frumoasa la vremea ei...... Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Gixu. Postat Aprilie 23, 2010 Share Postat Aprilie 23, 2010 Noua mea achizitzie...........Cine mai are asa ceva? From Saturday night downtown cruising, sport-touring and commuting to drag-racing and even for casual track-day use! Here's a bike that does it all reliably, very quickly and with style and comfort General information Model: Yamaha FZX 750 Year: 1991 Category: Naked bike Engine and transmission Displacement: 749.00 ccm (45.70 cubic inches) Engine type: In-line four Stroke: 4 Power: 94.00 HP (68.6 kW)) @ 9500 RPM Compression: 11.2:1 Bore x stroke: 68.0 x 51.6 mm (2.7 x 2.0 inches) Valves per cylinder: 5 Fuel control: DOHC Cooling system: Liquid Gearbox: 6-speed Transmission type final drive: Chain Physical measures Weight incl. oil, gas, etc: 225.0 kg (496.0 pounds) Chassis and dimensions Front tyre dimensions: 110/90-16 Rear tyre dimensions: 140/90-15 Front brakes: Dual disc Rear brakes: Single disc Speed and acceleration Top speed: 216.0 km/h (134.2 mph) Other specifications Fuel capacity: 13.00 litres (3.43 gallons) Varianta in RRomana o ai ? Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
alchool Postat Aprilie 24, 2010 Autor Share Postat Aprilie 24, 2010 Da, dar nu suna la fel de bine ca varianta in engleza... http://www.pro-bike.ro/catalog/detalii-FZX+750-5913.html Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
