Honda VT 750 RS Shadow
Go-Getter
Noul "Sportster" japonez? Asa pare... doar de n-ar fi asa de slab motorizata...
Make Model
Honda VT 750RS Shadow (VT 750S )
Year
2010
Engine
Liquid cooled, four stroke, 52° V-twin, SOHC, 6 valve
Capacity
745
Bore x Stroke 79 x 76 mm
Compression Ratio 9.6:1
Induction
PGM-FI electronic fuel injection with automatic choke, 34mm Throttle Bore
Ignition / Starting
Fully transistorised electronic / electric
Clutch Wet, multiplate with coil springs
Max Power
31.7kW @ 5500 rpm
Max Torque
61.8Nm @ 3250 rpm
Transmission / Drive
5 Speed / chain
Gear Ratio 1st 3,166 (38/12) / 2nd 2,000 (34/17) / 3rd 1,500 (30/20) / 4th 1,173 (27/23) 5th 1,041 (25/24)
Front Suspension
41mm telescopic fork, 118mm wheel travel
Rear Suspension
Dual conventional dampers with 5-step adjustable spring preload, 90mm wheel travel
Front Brakes
Single 296mm disc 2 piston calipers
Rear Brakes
Single 180mm drum
Front Tyre
100/90 -19
Rear Tyre
150/80 -16
Seat Height 737 mm
Kerb-Weight
229.5 kg
Fuel Capacity
10 litres
e frumoasa... dar prea mica rau....
10 litri rezervoru? :peace: nasol....
nu stiu de ce Honda nu mai fac motoare mari gen power-cruiser....
Mica?750 de centimetri cubi?
Nu cumva e si motocicleta de incepatori?
229,5 kg la gol?
Sa imi zica cineva cina o ridica de la sol usor fara a fi culturist sau sportiv.
ma refer la cadru, ca aspect, (pai io am 1860 mm inaltime, si comenzile sunt scurte)
pt mine, 750 CMC, motoru e mic :peace: (zic ca e scuter pt mine) :moron:
Mesaj completat
LE: pot sa ridic jucaria asta fara probleme
:moron: ...Vulcanu' meu de 750 cc,are 60 CP si 60 cuplu...si e cu cardan,roti tubeless,racire cu apa,si indicator de benzina...Oare sa ma uit cu jind,la "mobra" asta?! :peace:
10 litri rezervor (VARZA) meri 200 de km si tre sa cauti benzinarie
ce naiba cu puterea asta........virago al meu de 535cc e mai cu vana ca asta
LANTUL e naspa rau dupa mine (Ori curea ori cardan dupa mine)
si numa cu virago de 535cc am facut comparatie :peace:
Editat de IceLord
  • 1 year later...
Dealer honda la colt? La care ca eu stau cu banii pentru un shadow phantom aproape pregatiti si nu ai de unde cumpara din Ro pt ca importatorul intermotorcycle nu mai este. O varianta este sa iau din ungaria
  • 3 years later...
Pe hirtie pare putin , la condus merge foarte bine ,accelereaza surprinzator de bine ,de la 50km/h cu a cincea mergi pana la 170 .Are 3 supape pe cilindru ,si 2 bujii pe cilindru consuma 3.8L/100km.Cei de la Honda sunt cei mai buni la acordat motorul cu lantul de transmisie. Motocicleta are ciclistica super, :merge singura" suspensia nu scutura pe drum mai prost.
Sportsterul cel mai mic are 883 ccm, deci se aplica regula there is no replacement for displacement. In rest, depinde de gusturi - Honda e cu siguranta mai finutza. El pe Sportster, ea pe Honda, life is good, wtf... Tehnic vorbind, Honda nu are rivali.
Ahoi!
Cred-ca gama Star de la Yamaha are multe de spus, totusi.
Cu stima :tempted:
Editat de IceLord
Am avut shadow de 750 model 1997 ACE .... era mai mare la cam tot ce vrei , greutate, putere, dimensiuni...si nu am avut nici cea mai mica problema de ridicat, impins...si sunt mai mic decat @Crazy Angel....doar la inaltime ... deci asta noua nu e mare nici pe departe!!!
Ahoi!
Cu stima :tempted:
De la Virago am cam pierdut firul cu chopperele de la Yamaha - prea multe variante si cu apa si cu aer si stratoliner si stratocumulonimbus, dar probabil ca sunt ok si nu te lasa in drum ca o americana sau ruseasca.
De lasat la drum nu m-a lasat inca (al meu) si mai am prieteni care au si nu au patit-o inca, ce so bulit am reparat pe loc.
Singura buba mare la al meu a fost ambreajul de pornire (starter clutch) care a fost ceva....si mi-a murit la pornire in garaj (noroc sa zic).
Oricum sunt multumit de jucariele de la Yamaha pe care le-am avut: Virago de 535cc vreo 30.000km si pe Dragstar 1100cc cam 25.000km pana acuma.
La gama star chiar ai ce alege, pentru ca sunt multe modele. Cu racire pe aer, pe lichid, cu transmisie pe curea, cardan, lant.
In fine deviez de la subiect, imi cer scuze!
Editat de IceLord
