Rodaj
Am citit mai multe materiale despre "rodaj", ma rezum sa indic doar unul singur, care mi s'a parut cel mai complet.
http://www.ashonbikes.com/content/running
Foarte interesant mi s'a parut comentariul pe tema uleiului sintetic nerecomandat pe perioada de rodaj:
"Peter Brett (Advisor, Automotive Technology
Castrol - nota mea) says that they?ve discovered synthetic oils actually interfere with running in, for reasons which go beyond their low friction properties - there also seems to be a chemical process happening which hinders it. ?Although you can treat an engine as fully run in after 500 miles, surface stabilisation continues for at least the first 5,000 miles of an engine?s life,? he says. ?Synthetic oils actively prevent this from happening, and not simply by holding friction surfaces apart, although we still don?t know exactly why and how this happens. But there?s no doubt they inhibit the process itself. So the consequence of using a synthetic too early is your engine will never run in properly. I would even suggest waiting until 10,000 miles (16,000km) before using it in most engines subjected to normal use. Until then, you?re best to use an inexpensive but branded mineral oil.?
Nu trebuie sa credeti pe nimeni, cititi si judecati singuri!
Ride SAfe!
P.S. I'as face si eu o "honuiala" lu' Luciu...
Editat de yo4hgx
