eliminare dracie numita MMM
Cautam ceva legat de suzuki vz800 marauder, si am dat de clipul asta
Toate comentariile ziceau ca merge smecheria cu puntea.
Oameni care aveau probleme cu pornirea (in sensul ca era greoaie sau deloc), dupa ce au schimbat una/alta, au bagat bani in manopera/piese, au facut smecheria din clip si au rezolvat cu pornirea.
Unul dintre comentarii spunea chiar ca unii au scos de peste 2 ani MMM-ul ala si pana acum nu s-a stricat nimic.
Un tip pe care il lauda uniii cum ca ar fi tare in vz800 (marauderblue e tipul) spune ca nu a intalnit pe nimeni care sa fi avut vreo problema dupa ce a scos MMM (ca fapt divers MMM=mitsubishi mistery module , pt ca nimeni nu stie ce face)
"I have not heard of one instance of someone's bike suffering any negative impact from removing the MMM. I have not heard of one start relay failure, not one burned up starter, not one shorted battery cable or one failed battery. Suzuki has many, many other bikes that use this exact same start relay and the same basic start safety system, and not one of them use an MMM. The 800 Marauder is the only one.
It was once said that the electrical engineer on the VZ800 had a brother-in-law that designed this module for Mitsuba, but couldn't sell it or find a use for it. The engineer did his brother-in-law a favor and designed it into the VZ800, making the family some money and an easier life for his sister."
http://m.delphiforums.com/mig/messages/30522/17
Acum eu stau si ma intreb care e smecheria cu dracovenia numita MMM?
Specialistii de aici ce parere au?
P.S.
Nu am postat la capitolul "cruisere" pt ca , desi MMM nu se afla la alt motor, consider ca e binevenita o expunere mai mare, pt mai multe idei.
eu am eliminat un condensator de la cuprotul cu microunde care facea scurt,si n-am nici cea mai mica idee pt ce era condensatorul ala... :))
ideea e ca de vre-o 7-8 luni,se comporta fix la fel ca inainte cand nu avea probl;ema cu scurtul asta...!
Editat de Danut Ionda
Salut,
Starter Control Relay sau uzual Mitsuba Mystery Module este de fapt un releu electromagnetic interconectat intre infasurarea releului principal de pornire si comanda de pornire(conditionat in functionare de levierul ambreiajului) cu rol de protejare a releul principal de pornire /Starter Relay la socurile de curent. Contactele principale/conductoarele de conexiune ale SCR sau MMM sunt Galben/Verde si Galben/Negru, dar mai are o borna de masa Negru/Alb(img). Posibil ca aceste contacte principale sa se uzeze in timp si sa inrautateasca alimentarea RELULUI PRINCIPAL DE PORNIRE (Starter Relay), rezultand o pornire dificila/greoaie !! Solutia practica este eliminarea acestui releu(MMM) prin shunt-area lui, adica conexiunea galvanica conductoarelor Galben/Verde si Galben/Negru(lipire termica +izolare) si rezolvarea situatiei(interlock_ img). Schema devine mai simpla, idem ca la majoritatea motocicletelor.
Numai bine,
