dead_man_walking Postat Februarie 23, 2007 Share Postat Februarie 23, 2007 http://www.ridleymotorcycle.com/html/Ridley_Models07.htm AUTO GLIDE CHOPPER CAPACITIES Oil Capacity 2 Quarts Fuel Capacity 3g/11.4L Seat Height 24.5"/62.2cm Footrest Height 11"/27.9cm Front Wheel Travel 4"/10.2cm Rear Wheel Travel 3.5"/8.9cm Dry Weight 460lbs/209kg GVWR 760lbs/345kg Wheelbase 77"/196.9cm Length 102.8"/261.1cm Width 36"/91.4cm Height 45"/114.3cm Ground Clearance 5.25/13.3cm ENGINE Manufacturer (MOR) Ridley™ Configuration 90° V-Twin Displacement 44ci/738cc Cooling System Aid Compression Ratio 8.5:1 Valves Per Cyclinder 2 Starter Electric Exhaust Type Muffled/Straight Lubrication Pressure RPM @ 60MPH 3450 Spark Plug RC12YC DRIVE SYSTEM Transmission Type Automatic CVT Primary Drive Kevlar & Rubber Belt Final Drive Belt WHEELS Front Wheel 21"/53.3cm | 60 Spoke Rear Wheel 16"/40.6cm | 60 Spoke BRAKES Brake Type Hydraulic (DOT5) Front Brake 4 Piston (Ferodo Pad) Rear Brake 4 Piston (Ferodo Pad) LIGHTING SYSTEM Headlight High/Low, Daytime Brake/Tail Light Daytime Turn Signal Front LED Amber Turn Signal Rear LED Red AUTO GLIDE OLD SCHOOL CAPACITIES Oil Capacity 2 Quarts Fuel Capacity 4.2g/15.9L Seat Height 24.5"/62.2cm Footrest Height 6"/15.2cm Front Wheel Travel 4"/10.2cm Rear Wheel Travel 3.5"/8.9cm Dry Weight 460lbs/209kg GVWR 760lbs/345kg Wheelbase 66"/167.6cm Length 97"/246.4cm Width 37"/94cm Height 41"/104.1cm Ground Clearance 4.75"/12.1cm ENGINE Manufacturer (MOR) Ridley™ Configuration 90° V-Twin Displacement 44ci/738cc Cooling System Aid Compression Ratio 8.5:1 Valves Per Cylinder 2 Starter Electric Exhaust Type Muffled/Straight Lubrication Pressure RPM @ 60MPH 3450 Spark Plug RC12YC DRIVE SYSTEM Transmission Type Automatic CVT Primary Drive Kevlar & Rubber Belt Final Drive Belt WHEELS Front Wheel 16"/40.6cm | 60 Spoke Rear Wheel 16"/40.6cm | 60 Spoke BRAKES Brake Type Hydraulic (DOT5) Front Brake 4 Piston (Ferodo Pad) Rear Brake 4 Piston (Ferodo Pad) LIGHTING SYSTEM Headlight High/Low, Daytime Brake/Tail Light Daytime Turn Signal Front LED Amber Turn Signal Rear LED Red AUTO GLIDE SPORT CAPACITIES Oil Capacity 2 Quarts Fuel Capacity 4.2g/15.9L Seat Height 24.5"/62.2cm Footrest Height 6"/15.2cm Front Wheel Travel 4"/10.2cm Rear Wheel Travel 3.5"/8.9cm Dry Weight 460lbs/209kg GVWR 760lbs/345kg Wheelbase 66"/167.6cm Length 97"/246.4cm Width 37"/94cm Height 41"/104.1cm Ground Clearance 4.75"/12.1cm ENGINE Manufacturer (MOR) Ridley™ Configuration 90° V-Twin Displacement 44ci/738cc Cooling System Aid Compression Ratio 8.5:1 Valves Per Cyclinder 2 Starter Electric Exhaust Type Muffled/Straight Lubrication Pressure RPM @ 60MPH 3450 Spark Plug RC12YC DRIVE SYSTEM Transmission Type Automatic CVT Primary Drive Kevlar & Rubber Belt Final Drive Belt WHEELS Front Wheel 16"/40.6cm | 60 Spoke Rear Wheel 16"/40.6cm | 60 Spoke BRAKES Brake Type Hydraulic (DOT5) Front Brake 4 Piston (Ferodo Pad) Rear Brake 4 Piston (Ferodo Pad) LIGHTING SYSTEM Headlight High/Low, Daytime Brake/Tail Light Daytime Turn Signal Front LED Amber Turn Signal Rear LED Red AUTO GLIDE CLASSIC CAPACITIES Oil Capacity 2 Quarts Fuel Capacity 4.2g/15.9L Seat Height 24.5"/62.2cm Footrest Height 6"/15.2cm Front Wheel Travel 4"/10.2cm Rear Wheel Travel 3.5"/8.9cm Dry Weight 460lbs/209kg GVWR 760lbs/345kg Wheelbase 66"/167.6cm Length 97"/246.4cm Width 37"/94cm Height 41"/104.1cm Ground Clearance 4.75"/12.1cm ENGINE Manufacturer (MOR) Ridley™ Configuration 90° V-Twin Displacement 44ci/738cc Cooling System Aid Compression Ratio 8.5:1 Valves Per Cyclinder 2 Starter Electric Exhaust Type Muffled/Straight Lubrication Pressure RPM @ 60MPH 3450 Spark Plug RC12YC DRIVE SYSTEM Transmission Type Automatic CVT Primary Drive Kevlar & Rubber Belt Final Drive Belt WHEELS Front Wheel 16"/40.6cm | 60 Spoke Rear Wheel 16"/40.6cm | 60 Spoke BRAKES Brake Type Hydraulic (DOT5) Front Brake 4 Piston (Ferodo Pad) Rear Brake 4 Piston (Ferodo Pad) LIGHTING SYSTEM Headlight High/Low, Daytime Brake/Tail Light Daytime Turn Signal Front LED Amber Turn Signal Rear LED Red AUTO GLIDE TT CAPACITIES Oil Capacity 2 Quarts Fuel Capacity 4.2g/15.9L Seat Height 24.5"/62.2cm Footrest Height 8"/20.3cm Front Wheel Travel 4"/10.2cm Rear Wheel Travel 3.5"/8.9cm Dry Weight 460lbs/209kg GVWR 760lbs/345kg Wheelbase 67"/170.1cm Length 99"/251.5cm Width 37"/94cm Height 42"/106.7cm Ground Clearance 6.75"/17.2cm ENGINE Manufacturer (MOR) Ridley™ Configuration 90° V-Twin Displacement 44ci/738cc Cooling System Aid Compression Ratio 8.5:1 Valves Per Cyclinder 2 Starter Electric Exhaust Type Muffled/Straight Lubrication Pressure RPM @ 60MPH 3450 Spark Plug RC12YC DRIVE SYSTEM Transmission Type Automatic CVT Primary Drive Kevlar & Rubber Belt Final Drive Belt WHEELS Front Wheel 21"/53.3cm | 60 Spoke Rear Wheel 16"/40.6cm | 60 Spoke BRAKES Brake Type Hydraulic (DOT5) Front Brake 4 Piston (Ferodo Pad) Rear Brake 4 Piston (Ferodo Pad) LIGHTING SYSTEM Headlight High/Low, Daytime Brake/Tail Light Daytime Turn Signal Front LED Amber Turn Signal Rear LED Red Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Lt. Navarro Postat Februarie 24, 2007 Share Postat Februarie 24, 2007 Alea din a 2-a si a 3-a poza arata misto de tot. Parerea mea. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
mihai_prd Postat Februarie 24, 2007 Share Postat Februarie 24, 2007 Si toate cam la fel. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
easybiker Postat Februarie 25, 2007 Share Postat Februarie 25, 2007 D.M.W ,ce motor au pe ele ca nu pot sa imi dau seama? Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
Blackrider Postat Februarie 26, 2007 Share Postat Februarie 26, 2007 motor Ridley(TradeMark) de 44cui,V-twin la 90*. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
