Judas Iscariot Postat Martie 21, 2006 Share Postat Martie 21, 2006 THE EASIEST WAY TO OWN A DUCATI The 695 is a most unique offering in the world of motorcycles – welcoming to beginners, and yet able to deliver a level of performance that can also thrill advanced riders. Compared to the 620, which it replaces, the 695 is a leap forward in performance. The potent new L-twin delivers much greater horsepower and torque – the highest output per cc of any Ducati air-cooled engine. But just as important, the 695's engine produces smoother and more fluid power, while still making every twist of the throttle exciting. The 695 introduces new graphics and colour treatments in step with its increased performance. A matte black colour combined with red, long associated with Ducati Corse, has been selectively applied to the bike. The engine of the 695 is its most important technical advancement, and much more than an additional 75 cc's of displacement might indicate. The new L-twin delivers new levels of horsepower and torque but also, just as important, smoother and more fluid power. The 63 hp of the 620 has been increased to 73 hp for the 695, the highest output per cubic centimetre of all Ducati air-cooled engines. The rider's environment on the 695 is one of comfort, control and confidence. With the lowest seat height of any Ducati, riders can plant both feet securely on the ground. The rider's position is more upright as hands reach to a set of raised handlebars that are a bit wider for increased comfort and control. The footpegs strike a comfortable balance between a rearward 'sport' position and a forward 'laid-back' sport cruiser position. All in all, a rider feels confident and in control aboard a Monster 695. The 695 takes full advantage of the confidence inspiring road-holding and stability contribution of the Ducati trellis frame design. The trellis frame is light, rigid and beautiful, and distinctively Ducati. Quality Marzocchi 43 mm inverted forks and a Sachs rear shock, both crafted in Italy, smooth out the bumps and add their share of poise to the 695's road manners. TECH SPECS CHASSIS Frame Tubular steel trellis frame Wheelbase 1440 mm / 56.7 in Rake 24° Front suspension Marzocchi 43 mm upside-down fork Front wheel travel 130 mm / 5.1 in Front brake 2 x 300 mm discs, 2-piston caliper Front wheel 3-spoke light alloy 3.50 x 17 Front tyre 120/60 ZR 17 Rear suspension Progressive linkage with preload and rebound adjustable Sachs monoshock Rear wheel travel 148 mm / 5.8 in Rear brake 245 mm disc, 2-piston caliper Rear wheel 3-spoke light alloy 4.50 x 17 Rear tyre 160/60 ZR 17 Fuel tank capacity 14 L / 3.6 US gal (includes 3L / 0.8 US gal reserve) Weight * 168 kg / 370 lbs Seat height 770 mm / 30.3 in Instruments Electronic panel: speedometer, rev counter, neutral light, oil pressure warning light, low fuel warning light, high beam indicator, turn signals, immobilizer system, LCD clock Warranty 2 years unlimited mileage Colour combinations: (Tank-Frame-Wheels) (red-black-black) (matte black-black-black) (black-red-black) Versions Dual seat * = The weight excludes battery, lubricants and, where applicable, cooling liquid. ENGINE Type L-twin cylinder, 2 valves per cylinder Desmodromic; air cooled Displacement 695 cc Bore x Stroke 88 x 57.2 mm Compression Ratio 10.5:1 Power* 53.7 kw - 73 hp @ 8500 rpm Torque* 6.2 kgm (45 lb-ft) @ 6750 rpm Fuel injection Marelli electronic fuel injection, 45 mm throttle body Exhaust 2 aluminium mufflers Emissions Euro3 TRANSMISSION Gearbox 6 speed Ratios 1st 32/13, 2nd 30/18, 3rd 28/21, 4th 26/23, 5th 22/22, 6th 24/26 Primary drive Straight cut gears; ratio 1.85 Final drive Chain; Front sprocket 15; Rear sprocket 42 Clutch APTC wet multiplate with hydraulic control Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
partizan Postat Martie 26, 2006 Share Postat Martie 26, 2006 73 de cai la 168 de kg (la gol), adauga sunetul inimitabil (cea mai frumoasa muzica - azi am ascultat-o cca 200 km), manevrabilitatea unei biciclete, un cuplu care iti da niste reprize comparabile cu o sportiva de 600 ("in line 4"), designul lui Angel Galuzzi si vibratiile motorului in "L": ce altceva iti mai trebuie sa te bucuri de viata? Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
ipman Postat Martie 26, 2006 Share Postat Martie 26, 2006 Fiabilitate? Si benzina. Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
mielu Postat Martie 26, 2006 Share Postat Martie 26, 2006 Fiabilitate? Si benzina. Adica o Honda. Si benzina! Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
partizan Postat Martie 26, 2006 Share Postat Martie 26, 2006 (editat) Sosele fara gropi si fara radare...si, bineinteles, benzina. (sa faca honda un 600 naked - pe langa cb600f si cbf600 - cu motor v2, furca up-side down marzocchi, 2 tobe aluminiu, jante marchessini, frane brembo, design sexy, original, unic- adica o motocicleta cu caracter & personalitate - si sunt primul pe lista de asteptare) Editat Martie 26, 2006 de partizan Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
guzz Postat Martie 27, 2006 Share Postat Martie 27, 2006 ...... Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
SnapShot Postat Martie 28, 2006 Share Postat Martie 28, 2006 Meh. Prefer un V10 Centauro (4-valve rulz). Sper ca in viitor Moto Guzzi sa reia dezvoltarea liniei asteia de motoare Citează Link spre comentariu Distribuie pe alte site-uri More sharing options...
