dnepr 900 cm3 70CP enduro
orestte
Overall dimensions Length, mm, not greater than - 2400
Width, mm, not greater than - 880
Height, mm, not greater than - 1350
Wheel base, mm, not greater than - 1600
Road clearance, mm, not less than - 300
Dry mass, kg, not over - 220
Maximum load, kg, (N) not greater than - 170 (1700)
Engine - four-stroke, carburettor, OHV
Capacity, cc: - 998
Nominal cylinder bore, mm - 92
Nominal piston stroke, mm - 74
Geometric compression ratio - 7.4
Max.power, h.p. - 70
at engine speed, min.-l - 6000
Check fuel consumption per 100 km, 1, not greater than - 6.0
Fuel - petrol A-92
Starting - with electric starter and kickstarter
Air filter - with paperboard filter element
Electrical equipment- single-wired 12 V
Gearbox - five-speed
Suspension: front - telescopic with spring-hydraulic shock absorber
rear - swing arm with spring-hydraulic shock absorbers
Brakes: front - disc with hydraulic drive
rear - drum with mechanic drive
Seat: dual Tyres- front; 3.50 x 19/ rear: 4.00х18
OFFTOPIC (oarecum) :
Tricyle passenger "DNEPR-303"
Vehicle specifications
Overall dimensions Length, mm, not greater than - 2950
Width, mm, not greater than - 1780
Height, mm, not greater than - 1530
Wheel base, mm, not greater than - 1450
Road clearance, mm, not less than - 185
Dry mass, kg, not over - 320
Maximum load, kg, (N) not greater than - 300 (3000)
Capacity, ее: - 696
Nominal cylinder bore, mm - 79
Nominal piston stroke, mm - 71
Geometric compression ratio - 8.5
Max.power, h.p. -42
at engine speed, min.-l - 5500
Fuel - petrol A-92
Air niter - with paperboard filter element
Electrical equipment-single-wired 12V
Gearbox - four-speed with reverse
rear - independent swing arm with cylindric-hydraulie springs and shock absorbers
parking - mechanic with rear wheels drive
Seat: front - single / rear - two separate saddles with improved comfort
Tyres - front: 3.75 x 19 / rear: 225/50 x 15
Special equipment - baggage containers
