COUNTSKUSTOMS
robychopper
Aici va prezint citeva choppere facute de cei de la http://www.countskustoms.com/
Mie personal imi plac foarte mult si mai ales springerurile fascute de SUGAR BEAR
Au o linie de choppere super interesanta....si sigur veti observa partea de jos de la sprigeruri(forma lor) nu este doar de desing...propriu zis sunt facute asa pt a putea controla chopperul mult mai bine,,sunt facute asa pt a putea intoarce mai usor chopperul pt stabilitate mai buna si ca sa nu fii nevoit sa ai tot timpul ambele mini pe ghidon
Am sa va pun un reportaj despre conceptul acestui springer care a fost inventat de vestitul SUGAR BEAR
El este omul ce a facut chopperul din filmul WILD ANGELS
VA pun acum reportajul facut de LAYLA de la BIKERNET... http://www.bikernet.com/garage/sugarbear.asp
We've met all sorts of guys through the years who build bikes. Some found a niche and stuck to it--like Sugar Bear. He started building his own front ends 'cause he couldn't pry one from the fingers of the famous Dick Allen. Sugar Bear grew up in Los Angeles, hanging out at shops like MC Supply and Bennie Hardy's, who was his mentor and built the bikes for the movie Easyriders.
"He became pals with Peter Fonda when he built the bike for 'Wild Angels,'" Sugar Bear said about Bennie. "The Billy Bike was a basic South Central bike in the '60s. I used to sit and listen to the old masters talk."
CB Clausen owned MC Supply. "He was one of the original Booze Fighters and I paid a lot of attention to his ramblings," Sugar Bear said. While learning from the South Central originals, he built long bikes in his own garage: Harleys and 750 Hondas.
"We had just survived the slug era," Sugar Bear said. "In '72 I bought an Amen springer and bolted it to a Harley. The springer bowed under the weight of the heavy bike, so I went back and got another one. It did the same thing. Neil, the owner of the company, told me that if I didn't like his front ends, I should build my own. He was a little upset."
Sugar Bear tried to buy a Dick Allen front end. "Getting one was like pulling granny's teeth," Sugar Bear said. "I ended up with some parts." He started playing with the components.
"Dick's trees were in line with the neck like stock front ends, so I made a set of trees that pushed the legs forward," Sugar Bear said describing his changes. He decided to use oil-light bushings (instead of zirk fittings) that were narrow and not like the wide brass bushings. "I don't use zirk fittings because people don't use them and wear out bushings." He only weighed 170 pounds, so the long front end needed to be light to handle.
"I was good at math in school, so I started to figure out the rake and trail." Sugar Bear taught math in high school as a substitute teacher. He moved out of his garage in '71 and into a shop, but the hours were 4:00 p.m. to 10:00, in order to teach school in the day. About the same time he started fooling with the trail of his front ends.
"I took two straps 3/8-inch thick and drilled holes down the center, 7/8 inch apart until I had eight holes." He bolted them to the legs with a 21-inch front wheel and started to study the flop using the various holes.
"It was like developing power steering for long bikes," Sugar Bear said. He discovered that if he designed a front end with zero trail that it handled smoothly, turned easily and never flopped. "Customers don't need fork stops unless you lift the bike off the ground," Sugar Bear said.
Sugar Bear builds between three and six springers a month by himself. He's never had one returned. "Sometimes a customer will call and tell me that he can't ride the bike," Sugar Bear laughed. "I tell them to ride the bike around the block with their left hand behind their back. I know they're over steering because it feels so light. Works every time."
If you tell him the frame stretch and rake on your bike, he will recommend the length. He is accustomed to building front ends that are 25-30 inches over stock. "Even if the guy orders the wrong size, they usually buy another front end and keep the first one."
Each front end is handmade. He developed special springs to eliminate pogo. He manufactures the spring and rocker nuts, and the clevis at the bottom of the front legs to ensure the axle runs straight. Since the '70s, his springers have remained the same--made from bar stock, not tubing, to the design of the wild rockers. As a test he asks riders to sit on their bike and turn the handlebars one way then the other. "The frame behind the neck should not move or lift."
Sugar Bear is a craftsman who builds each front end to suit the customer's bike. They're wild, yet work like power steering for custom bikes. For more information about his springers or Sportster neck cups that adapt springers contact the man himself at (310) 768-4158.
Daca cititi reportajul veti intelege care estea idea acestui springer
in linkul acesta aveti 5 filmulete destul de interesante despre cei de la http://www.countskustoms.com/films.html
in linkul acesta veti vedea chopperul facut pt tommy lee de la MONTLEY CRUE
http://www.countskustoms.com/bikes_tommy.html
in acest link vedeti chopperul facut pt OZZY OSBOURNE
javascript:popUp('ozzy/index.html')
va salut L&R
roby
------Nu ziceti nici unul nimic despre conceptul asta de springer,a fost conceput ca sa ne ofere o mobilitate mai buna a chopperelor cu furca springer lunga........
va salut
L&R
roby
Tot sunt curios cum ar fi functionat furca spinger curbata de la Martin Bros. din serialul cu Biker Build-off pe Discovery.
Ar fii functionat bine,atita timp cit rezistau tevile la forta depusa la frinare....si pina la urma era un showbike nu se facea mile multe cu el.....pt citeva sute de mile cit ar fii facut chopperul ala daca raminea cu furca aia tinea sigur,mecanismul furcii raminea acelasi doar ca tevile erau curbate.........
salut
L&R
roby
  • 2 months later...
fiind facuta bine de oameni specialisti in custom,nu vad de ce nar rezista? are suspensie ,furca amortizeaza si ea cit ii permite culisarea....si credema ca si la americani au niste gropi pe marinea drmurilor....nu atitea ca la noi.....dar au si ei ceva gropi.......
salut
  • 10 months later...
interesanta furca springer...dar personal nu ma atrage asa lunga...
ce este drept niciodata nu am avut ocazia sa "pilotez" o motocicleta de genul...pare cam nesigura si nu cred ca ar avea viata lunga pe drumurile noastre...
arata spectaculos dar cred ca noi ne-am invatat ca tre sa fie si utila...
