CBR 300r vs Ninja 300
sprike
M1941%202014%20Kawasaki%20Ninja%20300%20
Kawasaki Ninja 300 :
Motor
Engine type Liquid-cooled, 4-stroke Parallel Twin
Displacement 296 cm3
Bore x stroke 62.0 x 49.0 mm
Compression ratio 10.6:1
Valve/Induction system DOHC, 8 valves
Fuel system Fuel injection: ø32 mm x 2 (Keihin), with dual throttle valves
Ignition Digital
Starting Electric
Lubrication Forced lubrication, wet sump
Frane
Frame type Tubular diamond, steel
Rake/Trail 27° / 93 mm
Wheel travel, front 120 mm
Wheel travel, rear 132 mm
Tyre, front 110/70-17 M/C 54S
Tyre, rear 140/70-17 M/C 66S
Steering angle, left / right 35° / 35°
Performanta
Maximum power 29.0 kW {39 PS} / 11,000 rpm
Maximum torque 27.0 N•m {2.8 kgf•m} / 10,000 rpm
Transmisie
Transmission 6-speed, return
Final Drive
Sealed chain
Primary reduction ratio 3.087 (71/23)
Gear ratios: 1st 2.714 (38/14)
Gear ratios: 2nd 1.789 (34/19)
Gear ratios: 3rd 1.409 (31/22)
Gear ratios: 4th 1.160 (29/25)
Gear ratios: 5th 1.000 (27/27)
Gear ratios: 6th 0.857 (24/28)
Final reduction ratio 3.000 (42/14)
Clutch Wet multi-disc, manual
frane
Brakes, front
Single 290 mm petal disc Single balanced actuation dual-piston
Brakes, rear
Single 220 mm petal disc Caliper: Dual-piston
suspensii
Suspension, front
37 mm telescopic fork
Suspension, rear
Bottom-Link Uni-Trak with gas-charged shock and 5-way adjustable preload
Dimensiuni
Dimensions (L x W x H) 2,015 mm x 715 mm x 1,110 mm
Wheelbase 1,405 mm
Ground Clearance 140 mm
Fuel capacity 17 litres
Seat height 785 mm
Curb Mass 172 kg / 174 kg (ABS)
Pret estimativ : 5000 ~ 5600 eu
Honda Cbr 300 :
Motor
Engine Type
286cc liquid-cooled single-cylinder four-stroke
Bore And Stroke
76mm x 63mm
Induction
PGM-Fi, 38mm throttle body
Ignition
Computer-controlled digital transistorized with electronic advance
Compression Ratio
10.7:1
Valve Train
DOHC; four valves per cylinder
Transmisie
Transmission
Six-speed
suspensii
Front Suspension
37mm fork; 4.65 inches travel
Rear Suspension
Pro-Link single shock with five positions of spring preload adjustability; 4.07 inches travel
Front Brake
Single 296mm disc
Rear Brake
Single 220mm disc
Front Tire
110/70-17 radial
Rear Tire
140/70-17 radial
Dimensiuni
Rake
25.30 degrees
Trail
98mm (3.9 inches)
Wheelbase
54.3 inches
Seat Height
30.7 inches
Curb Weight
357 pounds. Includes all standard equipment, required fluids and full tank of fuel-ready to ride.
Altele
Emissions
Meets current EPA standards. Models sold in California meet current CARB standards and may differ slightly due to emissions equipment.
Available Colors
Black, Red, Pearl White/Red/Blue, Matte Black Metallic/Yellow
Pret estimativ : 5480 eu ~
Care model ati alege ?
» Post actualizat in 18 Aug 2014 12:40
kawa in 2 cilindri paraleli. CBR-ul arata un picut mai bine (dar e subiectiva treaba asta), kawa e un picut mai potenta, iar diferenta de vreo 9-10 caluti (sau cat e) se va simti.
Editat de Banzay
Din cate m-am informat,pt A2,ar fi frumos Ninjala-ul :) La 39 cp ai destula putere,si la consumul pe care il are 3.74 l/100 sau ceva in genu,e prea bun.Din pacate sunetul stock pe toba lasa de dorit,pretul ridicat chiar si second,si lipsa de reprezentanta kawasaki in Romania(avem asa ceva macar in Bucuresti?).Alt dezavantaj la Kawasaki ar fi carenajul expus,care la prima tranta necesita reparatie.Daca sa zicem ma loveste cineva,de unde sa fac rost in Romania de carenaj nou pt el...?Ma bate gandul sa imi iau una...
Kawasaki fara discutie, din filmulete se vede ca Honda ramane repede fara suflu, mergi cu 130 pe autostrada si nu ai rezerva de putere deloc.
Honda ar putea face un enduro mic reusit cu motorul ala dar nu ceva sport.
Dupa ce-l cumperi, scoti toate carenele stoc, cuperi un set ori aftermarket China, ori din fibra si-l vopsesti. Iti iei moto sa te dai cu ea, nu s-o admiri. La vinzare, pui setul original la loc si-o anunti ca fiind inca virgina. In tarile mai avansate se practica metoda asta.
Mai sunt service-uri pe kawa, united motors parca e unul. Carnajul expus... ai prefera ca la o tranta simpla sa schimbi altele? Jagi stie ce zice, e un sfat de urmat. Sunetul stock? Mie unul mi se pare decent. Chiar am intors capul dupa unul ca eram curios ce se aude si venea verzitura. Drept e ca nu mai imi aduc aminte exact 'botul' posibil sa fi fost cu farul 'plin' model 2012, dar se auzea ok.
