Yamaha 2007
suru
YZF R1 - 2007
2007 TECHNICAL SPECIFICATION YZF-R1
ENGINE
Type Liquid cooled, 4-stroke, DOHC, 4-valve, forward inclined,
parallel 4-cylinder
Displacement 998 cc
Bore & stroke 77.0 x 53.6 mm
Compression Ratio 12.7:1
Max. power (without direct air induction) 132.4 kW (180 PS) @ 12,500 rpm
Max. power (with direct air induction) 139.0 kW (189 PS) @ 12,500 rpm
Max. torque (without direct air induction) 112.7 Nm (11.5 kg-m) @ 10,000 rpm
Max. torque (with direct air induction) 118.3 Nm (12.1 kg-m) @ 10,000 rpm
Lubrication Wet sump
Carburettor / Fuel supply Fuel injection
Clutch type Wet multiple-disc coil spring
Ignition TCI
Starter system Electric
Transmission Constant mesh, 6-speed
Final transmission Chain
Primary reduction ratio 65/43 1.512
Secondary reduction ratio 45/17 2.647
Gear ratio:
Gear ratio-1st gear 38/15 2.533
Gear ratio-2nd gear 33/16 2.063
Gear ratio-3rd gear 37/21 1.762
Gear ratio-4th gear 35/23 1.522
Gear ratio-5th gear 30/22 1.364
Gear ratio-6th gear 33/26 1.269
CHASSIS
Frame Aluminium die-cast Deltabox
Front suspension Telescopic forks, Æ 43 mm
Front wheel travel 120 mm
Rear suspension Swingarm
Rear wheel travel 130 mm
Caster angle 24°
Trial 102 mm
Front brake Dual discs, Æ 310 mm
Rear brake Single disc, Æ 220 mm
Front tyre 120/70 ZR17MC (58W)
Rear tyre 190/50 ZR17MC (73W)
DIMENSIONS
Overall length 2,060 mm
Overall width 720 mm
Overall height 1,110 mm
Seat height 835 mm
Wheelbase 1,415 mm
Min. ground clearance 135 mm
Dry weight 177 kg
Fuel tank capacity (reserve) 18 litres (3.4 litres)
Oil capacity 3.83 litres
Mai multe date/poze gasiti pe www.motociclete.com.ro
Editat de suru
  • Răspunsuri 60
Eu unul inca din 2000 urasc designul superbike-urilor! Candva aveau carene umflate si aratau fioroase... acum sunt super puternice, performante extraordinare, dar slabanoage si futuristice... Sunt eu prea conservator?? Totusi, nu-mi doresc numai cai putere si performante maxime, vreau sa arate si bine, nu doar sa fie aerodinamica (Luati exemplul Hayabusei). Adica nu pui motor de 600 de cai pe un trabant, tre sa arate si masina bine. In concluzie, stiul H.R. Geiger aplicat la motoarele de viteza ma lasa rece. Imi iau R1 din 2007 si ii schimb si carenele, si codita, si partea din fata, chit ca pierd coeficient aerodinamic :)
Exact ca si la suzi..le de-careneaza si nu inteleg de ce..R1 05 si 06 erau ele mai goale dar erau frumos realizate..cu negru asa, nu-ti dadeai seama...07 parca e un bandit.
Bandit rulz. :D :)
mama ce puteri declarate :) , astept masterbike 2007. Misto design....
Daca sunt asa de "optimisti" (ca sa nu zic altfel) ca si cu turatia maxima la R6 2006 (17500 pe gartie si pe ceas, 16200 in realitate), e clar. Dar sa vedem ce zic testele. :D
nu e prima oara cand yamaha baga din burta cai putere.tin minte un test comparativ intre yamaha r1 sp(ala scump) la 176 cai si mv agusta f4s ca 165 cred.la liniuta de 1000 de metrii(unde se vad caii putere) mangusta a iesit invingatoare.asta te face sa te intrebi daca acei cai putere italieni nu sunt mai armasari decat cei ai japonezilor :).oricum yamaha r1 ramane o meserie de motocicleta.abia astept v-max ul de 2007
