Enduro pana in 700 euro
RaduDaniel
În ce zonă geografică? 250 de kg nu poate avea, poate cu tot cu pasageri.
» Post actualizat in 02 Nov 2014 18:37
Model: Aprilia ETX 350 E Year: 1986 Category: Enduro / offroad Rating: 58.7 out of 100. Show full rating and compare with other bikes Engine and transmission Displacement: 349.00 ccm (21.30 cubic inches) Engine type: Single cylinder, four-stroke Power: 27.00 HP (19.7 kW)) @ 7000 RPM Top speed: 130.0 km/h (80.8 mph) Compression: 9.6:1 Bore x stroke: 79.5 x 70.4 mm (3.1 x 2.8 inches) Valves per cylinder: 4 Fuel control: OHC Cooling system: Air Gearbox: 5-speed Transmission type,
final drive:
Chain Chassis, suspension, brakes and wheels Front tyre dimensions: 90/90-21 Rear tyre dimensions: 130/80-17 Front brakes: Single disc Rear brakes: Single disc Physical measures and capacities Weight incl. oil, gas, etc: 167.0 kg (368.2 pounds) Fuel capacity: 13.00 litres (3.43 gallons)
http://www.bikez.com/motorcycles/aprilia_etx_350_e_1986.php
» Post actualizat in 02 Nov 2014 18:38
Weight incl. oil, gas, etc:167.0 kg (368.2 pounds)
Eu nu cred asta....fostul meu bmw F650 avea in talon 320kg, dar in realitate ea are 170kg la gol si 195 parca cu lichide.
Cum ar putea sa aiba un enduro de 350 respectiv 200 atatea kg ? probabil ca au trecut masa maxim autorizata in loc de masa proprie
de fiecare data cand il dau pe-o parte ma chinui sa il ridic..mai ales pe noroi
» Post actualizat in 30 Nov 2014 16:26
Varadero de 125 e destul de interesanta.Racire pe apa,motor V2.Plus ca o poti folosi si pe sosea foarte bine
e super faina motocicleta,se poate conduce cu a1?
