BOSS HOSS CYCLES
  • Răspunsuri 85
BHC-3 ZZ4
SPECS FEATURES
Engine
Type: Liquid Cooled V-8
Horsepower: 355
Torque: 405
Block: Cast Iron - 4 bolt main
Cylinders: Aluminum (58cc)
Valvetrain: 1.94"Int. / 1.5"Exh.
Size: 350 c.i. (5700cc)
Compression: 10:1
Carburetor: Quadrajet 750 cfm
Exhaust: 2.0" with dual mufflers
Transmission: 2-speed semi-auto w/rev.
Final Drive: Belt,Gates - Polychain
Dimensions
Wheel Base: 80.0"
Seat Height: 28.0"
Rake: 33.0 degrees
Grd. Clearance: 4.5"
Frame Width: 28.0"
GVWR: 1675 lbs.
Dry Weight: 1100 lbs.
Tires/Wheels
Front: 130/90-16, 3.50"x16.0"
Rear: 230/60, 7.0"x15.0"
Suspension
Front: 63mm inverted forks, adj. preload 2.5" travel
Rear: Dual 13.0" coilover shocks, adj. preload
Brakes
Front: Dual four-piston calipers, 12.6" floating disc
Rear: Single four-piston caliper, 12.6" floating disk
Fuel
Tank: 8.5 gal.
Reserve:
High/Low MPG: 25/20
Features
Storage: 400 cu. in.
Instruments: Electronic Speedo, odometer, tripmeter, volts, water temp., oil pressure, fuel gauge
Indicators: Hi-Beam, turn signals, neutral
Warranty: 12 mo., unlimted miles
BHC-3 502
SPECS FEATURES
Engine
Horsepower: 502
Torque: 567
Cylinders: Aluminum (110cc)
Valvetrain: 2.25"Int. / 1.88"Exh
Size: 502 c.i. (8200cc)
Compression: 9.6:1
Carburetor: Quadrajet 850cfm
Exhaust: 2.5" with dual mufflers
Final Drive: Belt, Gates - Polychain
Dimensions
Wheel Base: 82.0"
Seat Height: 28.5"
Rake: 33.0 degrees
Frame Width: 31.0"
GVWR: 1827 lbs.
Dry Weight: 1300 lbs.
Tires/Wheels
Suspension
Brakes
Fuel
Tank: 8.5 gal.
Reserve:
High/Low MPG: 18/13
Features
Warranty: 12 mo., unlimited miles, excluding engine and drivetrain
BHC-9 ZZ4
SPECS FEATURES
Engine
Horsepower: 355
Torque: 405
Compression: 10:1
Transmission: 3-speed automatic w/rev.
Final Drive: Shaft, narrowed Ford 7.5" (open)
Dimensions
Wheel Base: 81.5"
Seat Height: 29.0"
Rake: 33.0 degrees
Grd. Clearance: 6.5"
Frame Width: 60.0"
GVWR: 2093 lbs.
Dry Weight: 1500 lbs.
Tires/Wheels
Rear: 275/60R-15, 10.0"x15.0"
Suspension
Rear: Dual 17" coilover shocks, single 17.5" rebound damper, adj. preload
Brakes
Front: Dual four-piston calipers, 12.6" floating discs
Rear: 9.0" drum brakes
Fuel
Tank: 8.5 gal.
Reserve:
High/Low MPG: 25/20
eatures
Storage: 4 cu. ft., 6 cu. ft., 10.5 cu. ft.
BHC-9 502
SPECS FEATURES
Engine
Horsepower: 502
Torque: 567
Compression: 9.6:1
Dimensions
Wheel Base: 83.5"
Seat Height: 29.0"
Rake: 33.0 degrees
Frame Width: 60.0"
GVWR: 2293 lbs.
Dry Weight: 1700 lbs.
Tires/Wheels
Suspension
Brakes
Fuel
Tank: 8.5 gal.
Reserve:
High/Low MPG: 18/13
eatures
Warranty: 12 mo., unlimted miles, excluding engine and drivetrain
PRETZURI SHI ACCESORII:
http://www.bosshoss.com/build_bike.asp?cid...43.85950.423469
Base Options
Bike Order: 200584125236b
BHC-3 zz4-350 Bike - 'Complete'(Solid Color Paint) $34,500.00
BHC-3 zz502/502 Big Block Bike - 'Complete'(Solid Color Paint) $40,500.00
Wheels Gauge
Spoke
Mirage
Kit, Black Gauges
Kit, White Gauges
Cam Kit w/true roller rockers (Not Available with Fuel Injection) $1,250.00
Throttle Body Fuel Injection **Required for California Bikes** $2,250.00
California Exhaust - Small Block $700.00
California Exhaust - Large Block $700.00
Small Windshield & Mounts $157.00
Small Windshield Mounts Only (2) $70.00
Quick Release Windshield & Mounts - Clear $479.00
Quick Release Windshield & Mounts - Tinted $479.00
Quick Release Windshild Mounts Only $170.00
Risers, 2" Pull Back Kit $172.00
Sissy Bar Assembly, Small Mustang Pad $159.00
Sissy Bar Assembly, Countour Mustang Pad $202.00
Chrome, Rear Luggage Rack (Maximum Capacit: 15 lbs) $169.00
Mustang Touring Seat (Rider Seat Only) $50.00
Mustang Rider backrest & Wide Passenger Seat Combo $120.00
Highway Peg Kit with "Kuryakin" Mounts $92.00
V-8 Tailight Grill - Lucas Style $65.00
"Boss Hoss" Dash Inserts (Chrome) $74.00
Tool Bag (Leather) $54.00
Arlen Ness "Big Eye" Mirrors $55.00
Gas Cap Covers - "Boss" "Hoss" $84.00
Rambler Tail Pack (20"H X 15"W X 11"L) $153.00
Little Rambler (12"H X 15"W X 11"L) $107.00
Hard Saddlebags and Mounting Assembly $1,000.00
Fairing w/stereo & Speaker and Mounting Assembly $1,500.00
Am un prieten in Ungaria, care are una. De fapt motorul ala e singurul Boss in Ung. Consuma peste 20 de litri si are 600 kile. E (sau a fost numai) de vanzare, baiatul n-a avut unde sa foloseasca, in oras te omoare, desi tipul e peste 120 kg. Oricum, mie imi place tare mult... v8 pe 2 roti.... :D
Vizitator AndreiRN
Acum vreo 2 saptamani am intrat in magazin la Boss Hoss in Torrance, CA si m-am asezat pe unul si sunt frumos balantate dar trebuie sa inveti sa mergi cu ele ca te pierde in urma. Au transmisie automata cu 3 viteze si in oras trebuie multa grija. Pe autostrada se duce de nu te vezi, nerv sa ai. Ai de ales intre motoare de Ford sau GM. O motocicleta extravagata pe care daca vrei ti-o duci acasa.
Dar nici Daimler-Chrisler nu sa lasat mai prejos.
Cam cum arata un BOSS-HOSS putin mai custom-izat! Am de mult aceasta poza in My Pictures :D
Datorita greutatii lor (si a motorului Chevy) cred ca sunt destul de greu de condus! Oricum, cred ca odata ce te-ai obisnuit n-ai probleme!
Daca, Doamne fereste, "scapi" motoru' ce faci? Chemi pe cineva cu o macara?
Bogdan
  • 8 months later...
