Yamaha XT si Yamaha TENERE - 600/660
Vizitator _Raul_
  • Răspunsuri 3,3k
Vand sistem de pornire la pedala (kickstart) Yamaha XT 600 Z model 1VJ cu tot cu capac. Se poate monta la mai multe modele de XT insa nu stiu exact la care, cei care au asa ceva in plan sigur sunt mai documentati. Pot masura cote la cerere. Pret: 300 lei. / Contact in semnatura.
Editat de mihai
incalzesti,dai drumu' la ala din cadru, apoi la ala din cutie, desfaci filtrul, schimbi filtrul, strangi CU GRIJA suruburile, pui ulei semi fara sa te grabesti cantitativ cat cere manualul +/- filtru nou, infiletezi joja, faci cativa km, verifici,faci 1000km, verifici si completezi, faci 4000km, schimbi uleiul
Editat de yuk
multumesc , sper sa nu dau buleala:))
aa si inca ceva, a mea din cate imi amintesc nu are ulei in cadru :tomato: :tomato:
Se pare ca TT-ul are rezervor de ulei dedicat. Pt ca ti-a fost lene sa cauti manualul mobrei, uite, am tradus eu din romana in engleza pt tine :D Poze nu-ti pun. Google translate:
Engine oil replacement (with oil filter replacement)
1. Warm up the engine for a few minutes.
2. Stop the engine. Place an oil pan under the
engine and remove the oil filler cap.
3. Remove the drain plug (1) and drain the
engine oil.
4. Remove two bolts (2) and O-ring of the oil
hose flange, and drain the oil from oil tank.
5. Remove the air bleed screw (3) attached to
the oil filter cover (4).
6. Wait until the oil has completely drained.
NOTE:
The oil filter cover is secured by three screws (5).
The lower one should be removed so that the filter
cavity will drain.
7. Remove the other filter cover screws and
remove the oil filter cover.
8. Remove the oil filter (6) and O-ring (7).
9. Inspect:
• All gaskets
• O-rings
Damaged ➔ Replace.
10. Reassemble:
• (New) filter cartridge
• Filter cover screw
• Oil filter cover bleeder screw
• Engine drain plug
• Oil tank hose
Fastening torques:
Drain plug (engine):
30 Nm (3.0 mkg)
Oil tank hose (flange):
10 Nm (1.0 mkg)
Filter cover screw:
10 Nm (1.0 mkg)
Oil filter cover bleeder screw:
5 Nm (0.5 mkg)
11. Fill:
• Oil tank
Recommended oil:
SAE20W40SE or SAE10W30SE
Refer to the chart for selection of
the oils suited to the atmospheric
temperature.
API Standard:
API SE, SF, SG or higher grade
Oil capacity:
Total:
3.0 litres
Periodic oil change:
2.4 litres
With oil filter change:
2.5 litres
• Do not put in any chemical additives or use
oils with a grade of CD (a) or higher.
• Be sure not to use oils labeled “ENERGY
CONSERVING II” (B) or higher. Engine oil
also lubricates the clutch and additives
could cause clutch slippage.
• Be sure no foreign material enters the
crankcase.
CAUTION:
12. Install:
• Oil tank cap
13. Check:
• Oil level
See section “ENGINE OIL LEVEL
CHECK”.
• Oil pressure
See section “ENGINE OIL PRESSURE
CHECK”.
• Oil leakage
multumesc man:D deja l-am schimbat . nu l-am cautat ca vroaim sa o duc la mecanic dar cum in " comuna" in care aveam motocicleta nu exista un mecanic sa ma ajute m-am gandit sa-l fac singur si totul s-a intamplat pe ultima suta de metri.totul a fost bine , am facut azi 300 de km dupa schimb merge brici !
Problema e asa: am dat unui cunoscut in Iasi capacul cu statorul, electromotorul, comanda de pornire la buton, plus ce pinioane a vut nevoie si a reusit sa modifice un XT 600 de dinainte de '90 din kickstart in pornire la electromotor. Problema e ca porneste numai cu CDI-ul si releul de incarcare de pe un alt 3AJ din oras sau cu CDI-ul lui original numai daca motorul e cald. Intre timp eu am vandut tot ce aveam pe electric in tara si nu mai am cum sa-l ajut sa-si termine modificarea. Intrebarea: Ar porni cu CDI si releu de incarcare de la XT 600 E cu pornire la electromotor (sau XTZ 660)? Si daca da, care vinde?
Editat de mihai
Nu stiu ca nu i-am facut eu modificarea, nici nu ma pricep asa bine. Poti elabora te rog, sa stiu ce sa-l intreb pe nea' care i-a facut? (mecanic amator)
Editat de mihai
Si XT600 are d-ala pe cablu. Schimba-i si axa cu came de la un XT cu demaror. Nu XTZ ca asta are 5 came. Sau doar pinionul de pe axa, daca se potriveste.
Apropos, cand zici ca nu porneste, de fapt invarte greu?
  • Vizitator pinned this topic
