Yamaha MT-07
WickedAssHell
MT-07
Engine
Engine type
2-Cylinder, liquid-cooled, 4-stroke, DOHC, 4-valves
Displacement
689 cm³
Bore x stroke
80.0 mm x 68.6 mm
Compression ratio
11.5 : 1
Maximum power
55.0 kW (74.8PS) @ 9,000 rpm
Maximum Torque
68.0 Nm (6.9 kg-m) @ 6,500 rpm
Lubrication system
Wet sump
Carburettor
Fuel Injection
Clutch Type
Wet, Multiple Disc
Ignition system
TCI
Starter system
Electric
Transmission system
Constant Mesh, 6-speed
Final transmission
Chain
Chassis
Frame
Diamond
Front suspension system
Telescopic forks
Front travel
130 mm
Caster Angle
24º 50
Trail
90 mm
Rear suspension system
Swingarm, (Link type suspension)
Rear Travel
130 mm
Front brake
Hydraulic dual disc, Ø 282 mm
Rear brake
Hydraulic single disc, Ø 245 mm
Front tyre
120/70 ZR 17M/C(58W) (Tubeless)
Rear tyre
180/55 ZR 17M/C(73W) (Tubeless)
Dimensions
Overall length
2,085 mm
Overall width
745 mm
Overall height
1,090 mm
Seat height
805 mm
Wheel base
1,400 mm
Minimum ground clearance
140 mm
Wet weight (including full oil and fuel tank)
179 kg / ABS 182 kg
Fuel tank capacity
14 L
Oil tank capacity
3.0 L
2014-Yamaha-MT-07-EU-Matt-Grey-Studio-00
2014-Yamaha-MT-07-EU-Deep-Armor-Studio-0
2014-Yamaha-MT-07-EU-Competition-White-S
The Dark Side Of Japan
Pretul inca nu a fost anuntat oficial,insa zvonurile spun ca ar putea fi in jur de ~ 6000 de euro.Ar fi interesant ca aceasta platforma sa fie baza noului XT iar cea a lui MT-09,pentru noul TDM.Oricum,felicitari Yamaha :)
Editat de WickedAssHell
  • Răspunsuri 76
Daca ar fi motorizarea asta pe XT ar inseamna un concurent pentru F800 sau Transalp. Sa urmeze oare un nou XT? ar renunta oare yamaha la monocilindru? MT03 avea motorizarea de pe XT (R,X,Z) cam slaba.
Editat de lostheaven
Tinand cont ca un MT-03 este undeva la 7500 euro, ma indoiesc ca asta ar iesi la 6000 de euro!
Tinand cont ca pretul oficial pentru MT-09 este de 7890 euro,respectiv 8390 pentru versiunea cu ABS,cred ca ar putea fi posibil un pret atat de mic pentru MT-07.Sunt doua platforme diferite.
MT-07 este in concurenta directa cu Suzuki Gladius si Kawasaki ER-6N,insa poate concura si cu noul model CB650F de la Honda,chiar daca sunt totusi doua clase diferite.
Ar fi interesant sa fie baza pentru XT,reteta e perfecta din punctul meu de vedere pentru clasa intermedie.F800 nu este accesibil pentru toata lumea,Triumph la fel,Honda nu a facut nici un upgrade pentru Transalp.De aceea trebuie ca Yamaha sa scoata un nou XT in opinia mea.Valabil si pentru TDM/R6,care ar putea avea ca baza platforma MT-09
Motoreta arata beton.
Este zic eu orientata spre o nisa de piata care a cunoscut o foarte mare dezvoltare in ultimii ani : fun bikes.Adica motoretele lejere,nededicate unui scop precis,dar care pot face de toate si le pot face bine.Si care iti aduc obligatoriu un zambet pe buze cand meri cu ele.Aceste moto sunt din ce in ce mai cautate si de incepatori care cauta o moto lejera si usor de condus,dar si de cei trecuti de 30 de ani care s-au plictisit sa stea in cap pe sportive si ar vrea si o motoreta de plimbari,dar care sa fie totusi potenta.
Naked-urile au incercat sa faca treaba asta,insa erau facute in majoritate din bucati si aveau motoare 4L luate de pe sportive si detunate.
Supermoto-urile iarasi au incercat sa pice pe acest target,insa lipsa de putere e vizibila.
Prima moto care a reusit sa indeplineasca cerintele acestei nise zic eu ca fost Ducati Monster.Apoi,vazand succesul de piata al Ducati-ului,Suzuki s-a miscat repede si a venit cu SV-ul 650.Iarasi,Kawasaki a scos ER6.
Sunt din ce in ce mai multi bani pe aceasta piata si iata ca si Yamaha nu ramane indiferenta.MT-03-ul a fost in opinia mea o motoreta mult prea slaba.MT-07 promite.
Dupa cum am zis,motoreta arata beton,si asta e unul din cele mai importante lucruri.
Bordul ala e frumos,motoreta e ff usoara (180kg la plin e ceva extraordinar),sasiul arata ok.,cred ca handling-ul va fi bun.
Ce am eu de imputat motoretei asteia,la prima vedere : putea sa iasa o motoreta extraordinara daca ii puneau o furca fata usd si frane radiale (eventual luate de la un r6/r1 de generatie veche,in stilul MT-01) si un motor V2.
Furca aia nu cred ca ridica pretul extraordinar,mai ales daca era de generatie mai veche.N-a zis nimeni sa pui furcile de R1 2013,dar niste furci de R6-2005 nu cred ca erau un capat de tara.
Si iarasi,daca motorul ala era V2 si nu 2L,cred ca era o mare diferenta.ar fi iesit un motor cu caracter,ceva in genul SV-ului.E adevarat ca e mai scump de facut un motor V2 decat un 2L,dar Suzuki ne-a aratat cu SV-ul ca se poate face o motoreta cu sasiu bun si cu motor V2 care are caracter si e si f fiabil la un pret competitiv.
Vizitator Adrian
Ca fun cred ca una dintre motoretele cele mai smechere e Husqvarna Nuda 900R. N-am mers pe una,dar din ce-am vazut, imi ridica parul de pe ooua...
Sunetul si cum arata....un fel de SM/ Naked
Editat de Adrian
MT-03 cred ca a vrut sa acopere doua nise destul de eterogene: fun bike-ul accesibil si supermoto. Ca vanzari nu a fost o catastrofa, dar nu cred ca Yamaha au fost multumiti cu cate au vandut.
Chestia asta (MT-07) vrea sa fie in primul rand accesibila ca bani. Vad bine de ce nu i-au pus USD si nici motor V2. Desi upside-down-ul a ajuns sa fie qvasi-standard pe majoritatea motocicletalor din vest, o furca ne-inversata ramane mai ieftina. Eventualul V2 ar fi trebuit proiectat de la 0 pentru acest model, iar rentabilitatea ar fi fost redusa.
Una peste alta, mi se pare o motocicleta buna ca raport calitate/performanta/pret, desi pacatuieste printr-o oarecare lipsa de personalitate. Dar asta e deja subiectiv.
Este un fel de Suzuki Gladius, ceva mai neinspirat desenat. In loc sa faca mobre fin ce in ce mai aratoase, astia incearca sa vada cad de departe pot impinge granitele urateniei. A avut un prieten un Diversion nou si nu stia cum sa scape mai repede de el. Oricine are minte isi cumpara un Fz1 sau un Mt-01 cu banii aia. Asta daca tine musai sa-si cumprre Yamaha. In categoria in care isi baga nasul "noul" mt sunt deja o multime de mobre mult mai misto, monstrul de exemplu.
Editat de Gixu.
Vizitator Adrian
mai baieti, mobra asta chiar arata bine (stiu, e subiectiv)
Mobra urata este Honda NC700 si noul NC750 (S/X/ etc).
este o mobra fiabila cred si cu un consum de invidiat (Honda aia),dar abia aia are personalitate ZERO.
Asta chiar arata binisor,mai ales codita..
De acord cu tine cu MT-03-ul.Nu cred ca e un flop ca vanzari dar nici nu a rupt gura targului.
Despre MT-07,e adevarat,trebuiau sa tina costurile jos.Si nu poti tine costurile jos cu usd si frane radiale.Bine,Monster-ul poate...
Eu vad insa treaba in felul urmator : de prin 2008 incoace,motoretele europene castiga din ce in ce mai mult teren pe o piata ce pana acum era pur si simplu exclusiv japoneza :
pe sport-touring,bmw-ul,ktm-ul si mai nou Triumph sunt regi ;
pe motorete sport iarasi,bmw a rupt gura targului si acum va ataca (cu succes zic eu) si piata muscle-naked cu motoreta asta noua naked derivata din cea sport ;
la choppere-cruisere e Harley,e Triumph,dar aici japonezii au totusi vanzari
la clasa supermoto la fel,ktm e tatic,dar ia mult si din piata de cross,enduro,etc.
la clasa naked mic Triumph rupe cu Street Triple,are si Ducati o parte acolo,si MVAgusta,etc.
pe acest segment de fun-bikes,naked,etc europenele se descurca foarte bine,mai ales Ducati cu Monster-ul.Bine,e si Suzuki cu Gladius si in paralel SV-ul,Kawasaki cu Er6,etc
Japonezii mi se pare ca pierd din ce in ce mai mult teren pe toate partile : la motoare sport sunt de la locul 2 in jos,la enduro-touring de la 3 in jos,la naked-uri nu mai zic,etc,etc.Mai detin suprematia pe 2 segmente care sunt totusi in mare cadere : la sport-touring si la clasa ss.Busa inca e Busa,ZZR la fel,iar la ss R6 inca e rege,desi nu l-au mai innoit din 2006.Dar aceste segmente sunt in cadere libera ca nr de unitati cumparate.
Cu acest MT-07 (care mie mi se pare totusi ca arata ff bine) eu cred ca Yamaha putea da lovitura : ai o motoreta ieftina,frumoasa,ai mai reusit s-o faci si f usoara,ai un sasiu bun zic eu,putin derivat din FZ1.Smecheria e ca ai pe mana o gramada de piese de performanta de la modelele mai vechi,nu mai tre sa proiectezi nimic.Ai tot ce-ti trebuie,numai sa dai drumul la roboti.Cheltuielile ar fi fost mult mai mici.
Daca ii trageau,dupa cum am zis,o furca usd,luata direct de pe o moto veche de performanta care nu pot sa cred ca ridica enorm pretul cu tot cu prinderile radiale ale etrierilor si un V2 relaxat,de cuplu,tot pana in 80 de cai,cred ca ar fi iesit ceva care s-ar fi vandut ca pita calda.
E pe principiul supermarket-ului : degeaba faci profit 1500-2000e la una daca se vand 10.000,e mult mai bine dpdv economic sa faci profit 500e/bucata si sa vinzi 100.000.
Si apropo de motor,pai motorul asta l-au luat de pe alta?Nu e tot gandit de la 0?
Mie mi se pare ca arata bine.Nu asa bine ca Gladius insa.Si Gladius,revin obsesiv deja,are acel motor V2 de pe SV,care e foarte fun.Asta va fi un partz.
MT-01/FZ1 ? Nu,nu cred ca sunt pe acelasi target nici una cu alta (poate foarte fin),si deloc cu aceasta motoreta.
FZ1 e un hooligan-bike adevarat.
MT-01 e un fel de power-cruiser,cu influente de chopper dar care mere bine si daca dai de vreo curba.
Una o vad pt cei de peste 28-30 de ani care stau prin oras si s-au plictisit de vitezane,pe cealalta o vad pt cei pe la 40 de ani,care vor plimbari lungi,clienti de choppere dar care ar mai vrea sa se dea si pe o curba,dar asa,mai lejereanu.
MT-07 e entry-level,fun-bike,nu cre ca tre sa fii profesor sa meri cu ea,ti-o iei si tu ca e Yamaha si arata bine si e noua,si vezi tu dupa aia.Cam cum era Hornet-ul mai demult :P
Pt celelalte 2 tre sa cam stii cu ce se mananca motoretele.
Vizitator Adrian
ei hai sa nu exageram...
daca raportam la motociclismul autohton, cate naked uri europene vezi tu pe drum nene? Cate BMW R850/1100/1150/1200R vezi? Cate F800R, cate MV Agusta Brutale, cate KTM Duke/Superduke, cate Aprilia Tuono, cate Triumph Street/Speed Triple?
Da, sunt o gramada de monstere, din alea de 600, din 1900 toamna. Cate monstere noi vezi?
Poate in afara, e ceva mai diluat cu europene, mai vezi cate o exotica, dar la noi nu.
Culmea,chiar piata naked urilor mi se pare ca e detinuta de japoneze.... de la CB 500/ER5/ GS500 pana la Hornet-uri ,Bandit-uri, GSR uri, FZ uri, si asa mai departe...
Si mai scutiti-ma cu furcile alea USD de pe Monster. Voi macar ati vazut ca nu ai nici un REGLAJ pe furca aia?
Am vazut la nu stiu ce intrunire din Neamt in 2012 un Street Triple negru, model nou (2011 model parca) cu furca USD si fara reglaje.
Asta e mandria romanului care nu intelege nimic, AM FURCA USD,sunt smecher, desi furca aia n-are nici un reglaj si e vai de neamul ei...
Sau sa va explice ERU (daca retin bine username ul) ce furca USD "smechera" are pe F800 GS ul lui....
Deci nu mai ridicat in slavi furcile USD, ca nu-s toate la fel.
Vezi ce furca este pe Monster 796, care plm...e motor nou,modern, cu pretentii cat de cat sportive, si vezi ce fruca ai pe Ducati 748,care e 'antic' (ca model)...
Editat de Adrian
Stai putin ca gandesti gresit :
1.Tu iei piata din Romania ca etalon ????
Piata din Romania e vacs-albina pt TOTI constructorii moto.E nimic,e 0,e negru sub unghie,cum vrei tu sa-i zici.Fantastic,in piata din Romania ne proptiram acuma.Constructorii au in interes asa : Europa (cu accent pe Italia,Germania,Franta,Spania,UK),America de Nord+Canada,America de Sud si Asia (cu mare accent pe China,India si apoi Japonia,Australia).Noi suntem muc cel mic aici.
Normal ca Honda+Yamaha au desfacere babana pe Asia,unde cum draq sa intre europenii ?Normal ca sunt cei 4 colosi industriali care rup pt ca au o cota de piata enorma.Insa eu spun ca aveau aproape monopol si nu il mai au.Ce cota aveau pe USA?Ce cota pe EU?Si acum s-a cam schimbat treaba in ultimii ani,pierd teren galopant.Dar e adevarat,japonezii sunt sefi.Numai ca se ridica anumite semnale de alarma.
La noi normal ca o sa vezi numa Hornet-uri si FZ6 si Bandit si GSX-R din 2001 si CB500 din 98 si alte asemenea bashini pt ca la noi cred ca 85% din piata sunt motoare la mana a doua aduse din Italia sau in cel mai bun caz din Germ.Ce vanzari de motoare noi avem noi?30/an?Bine,exagerez,dar iti dai seama ce vreau sa zic.
La ce nivel de trai avem noi,suntem total nesemnificativi pe piata de motoare noi.Cata lume ai auzit tu sa-si ia motor nou?Cati prieteni ai care si-au luat motor nou?Draq,aici,pe forum,la fel,de cine ai auzit sa aiba motor din 2013?Eu am un singur (1) amic care si-a luat motor nou,si ala e full de bani,dar bine,poate o ard eu printre lume mai saraca,cine stie :P
La noi se va vedea acest trend de trecere spre motoare europene peste 5-6 ani cand le vand astia din afara si le luam noi la mana a 15-a :D
2.Nu am zis ca furca USD de pe Monster e o mare smecherie.Am dat exemplu pe Ducati prin faptul ca au pus o usd si frane brembo si totusi au putut veni cu un pret competitiv.Nu am dat Monster-ul ca exemplu de handling.
Am sugerat ca acest model (MT-07) ar fi putut veni cu furci usd de pe modele sport de Yamaha din ani mai vechi (R1/R6-mie si suspensia R1'98 mi se pare beton) care sunt excelente si care,fiind in-house,ar fi putut fi produse la un pret rezonabil care nu ar fi ridicat pretul motoretei foarte mult.
Da,am inteles ce vrei sa spui,furca usd nu inseamna automat furca buna (vezi Hornet).Si sunt de acord cu tine,mi se pare o mare muiangerie furca nereglabila.Macar pe preload.Adica bai nene,cat te costa in plus sa-i pui 2 suruburi care sa compreseze arcurile,da-o draq.Si iarasi,franele radiale,pe alea mor.Pe multe modele Yamaha am vazut,etrierii aia Sumitomo,vechi inca hat de pe R1'98,care de felul lor sunt extraordinari,dar nu ii monteaza radial decat pe modele de varf,ca deh...Adica bai nene,cat te costa in plus sa ii faci acea mica furca pe care stau,nu,hai sa-i tragem 2 suruburi pe furca si gata,avem frane.Ca oricum sunt etrierii buni.
Inteleg ce vrei sa spui,ce vroiam eu sa zic e ca o companie cu tehnologia pe care o are Yamaha poate face o motoreta extraordinara,investind destui de putin bani pt ca poate lua piese de pe motoarele mai vechi.
Vizitator Adrian
Method,ai inteles gresit la punctul 1.
Chiar si pe plan international, zi-mi cate motorete JAPONEZE vezi pe strada, si cate vezi europene?
Ponderea e mai mare ca in Romania,dar sa fim seriosi, nu se compara procentul europene vs. japoneze.
La faza cu furca, stai relax, nu ti-am pus vorbe-n gura...ci doar am argumentat exemplul tau (cumva l-am combatut)..
Monsterul e la pret competitiv pt ca este o motoreta simpla, fara performante la nici un capitol iar dpdv tehnologic e depasita (era depasita si atunci).
Imi place Monster, imi place cum arata, daca mi-as permite, mi-as lua unul. As da RSV ul pt un S4, pt ca dpdv al look ului,sunetului si motorizarii, Monster intruchipeaza ce-mi doresc de la un motor...
Dar Monsterul sa stii ca ia bataie la cwr de la SV, care are performante superioare, e si mai ieftin si mai fiabil..
Nu vorbim de monsterele noi,pt ca acum SV ul nu se mai fabrica, iar pt mine Gladius e o gluma proasta, un fel de motoreta pt muieri.
Ce e bun pe monster este sistemul de franare, care vine cu etrieri/pompe/etc Brembo destul de eficiente. La capitolul frane,da, sta mai bine ca alte motorete. Dar spre deosebire de Hayabusa,care la un momoment dat avea frane subdimensionate, pt puterea pe care o dezvolta, Monsterul are frane supradimensionate :) (bine,sunt ironic,dar intelegi ideea).
Nedumerirea pe care o ai tu, o am si eu, cum de Triumph ul ala ce l-am vazut (model 2011/2012) avea furca USD panarama? nu puteau sa puna una USD cu reglaje,de la un model anterior?
Si da, ai dreptate, s-au tiganit dar asta o fac dinadins pt ca asta e si ideea de marketing,de vanzare....de diversificare a pietei...
@method
Pai ideea este ca trebuiau sa mentina costurile de productie joase,cum ai zis si tu.Recent am auzit ca pretul pentru modelul fara abs,ar putea fi in jur de 5800 de euro.Oficial nu a fost confirmat inca nimic.
Fun bike,entry level,nu cred ca sa urmarit ca prin acest model sa se faca concurenta naked-urilor consacrate.Este in concurenta directa cu Suzuki Gladius si Kawasaki ER-6N,insa nu m-ar mira sa fure si cativa clienti de la Honda.Acum trebuie vazut insa cum se comporta si noul model,CB650F si care va fi pretul de lansare al acestuia. Pentru ceea ce ofera,probabil este destul de ok MT-07.Sper sa am ocazia sa o testez in primavara.
Cine vrea sa joace in liga superioara,va achizitiona MT-09.Eu m-am dat cu ea si parerea mea este ca lasand la o parte latura estetica,cred ca acest model va fi unul de succes.
Este un proiect nou,per total cei care au testat motocicleta au ramas destul de incantati de ce ofera aceasta platforma,de raportul calitate/pret iar in momentul de fata in clasa intermedie a naked-urilor,sunt foarte putine motociclete ce pot intra in concurenta cu ea.
Evolutia inseama inovatie. :)
O sa-ti dau un exemplu,Italia.Este o tara cu cultura din punct de vedere motociclistic,insa tineti cont ca totusi este si patria mama a marcilor Ducati,Aprilia,Moto Guzzi,MV Augusta,Benelli...etc.Acest lucru influenteaza oarecum rezultatul final.
Asta e top 100 din Italia,din luna octombrie 2012 cu cele mai vandute motociclete:
Classifica Top 100 Gen-Ott 2012 - Moto
Pos. 	Marca 	Modello 	Segmento 	Tot Gen-Ott
001 	BMW 	R 1200 GS 	Enduro 	2.221
002 	HONDA 	NC700X 	Enduro 	2.021
003 	BMW 	R 1200 GS ADVENTURE 	Enduro 	1.111
004 	HONDA ITALIA 	CB 600 F HORNET 	Naked 	1.078
005 	BMW 	F 800 GS 	Enduro 	1.038
006 	TRIUMPH 	TIGER 800 	Enduro 	940
007 	BMW 	F 800 R 	Naked 	917
008 	BMW 	R 1200 R 	Naked 	833
009 	HARLEY-DAVIDSON 	XL1200X FORTY-EIGHT 	Custom 	820
010 	TRIUMPH 	BONNEVILLE 	Naked 	794
011 	SUZUKI 	DL 650 V-STROM 	Enduro 	793
012 	HARLEY-DAVIDSON 	XL883N IRON 883 	Custom 	744
013 	HONDA 	CROSSTOURER 	Turismo 	743
014 	DUCATI 	STREETFIGHTER 848 	Naked 	740
015 	KAWASAKI 	ER-6N 	Naked 	729
016 	KAWASAKI 	Z 750 	Naked 	720
017 	KTM 	125 DUKE 	Supermotard 	716
018 	YAMAHA 	FZ8-N 	Naked 	687
019 	DUCATI 	MULTISTRADA 1200 S TOURING 	Turismo 	668
020 	HONDA ITALIA 	XL 700 V TRANSALP 	Enduro 	641
021 	DUCATI 	MULTISTRADA 1200 	Turismo 	569
022 	MOTO GUZZI 	V7 CLASSIC 	Naked 	561
023 	YAMAHA 	XJ6-N 	Naked 	541
024 	HONDA ITALIA 	CB 1000 R 	Naked 	534
025 	DUCATI 	HYPERMOTARD 796 	Supermotard 	525
026 	KTM 	690 DUKE 	Supermotard 	517
027 	HONDA 	NC700S 	Naked 	505
028 	KAWASAKI 	Z 750 R 	Naked 	489
029 	KTM 	125 EXC 	Enduro 	476
030 	BMW 	F 650 GS NEW 	Enduro 	465
031 	SUZUKI 	GSR 750 	Naked 	446
032 	DUCATI 	DIAVEL ABS 	Naked 	431
033 	BMW 	R 1200 RT 	Turismo 	422
034 	YAMAHA 	XT 1200 Z 	Enduro 	422
035 	DUCATI 	1199 PANIGALE / 1199 PANIGALE S / 1199 PANIGALE S TRICOLORE 	Sportive 	408
036 	TRIUMPH 	STREET TRIPLE 	Naked 	403
037 	DUCATI 	MONSTER 796 	Naked 	402
038 	BMW 	S 1000 RR 	Sportive 	398
039 	DUCATI 	1199 PANIGALE / 1199 PANIGALE S 	Sportive 	380
040 	YAMAHA 	FAZER 8 	Naked 	380
041 	MV AGUSTA 	F3 675 	Sportive 	368
042 	HONDA ITALIA 	CBF 1000 	Naked 	366
043 	KAWASAKI 	VERSYS 650 	Enduro 	365
044 	HONDA 	CROSSRUNNER 	Turismo 	359
045 	BETA 	EVO 2T 300 	Trial 	344
046 	HONDA 	CBR 1000 RR 	Sportive 	335
047 	MV AGUSTA 	BRUTALE 675 	Naked 	330
048 	YAMAHA 	TDM 900 	Turismo 	330
049 	YAMAHA 	YZF-R125 	Sportive 	326
050 	APRILIA 	SHIVER 750 	Naked 	322
051 	BMW 	G 650 GS 	Enduro 	321
052 	KTM 	300 EXC 	Enduro 	320
053 	HUSQVARNA 	NUDA 900 R 	Naked 	314
054 	KTM 	350 EXC-F 	Enduro 	314
055 	DUCATI 	MONSTER 696 	Naked 	313
056 	TRIUMPH 	SPEED TRIPLE 1050 	Naked 	303
057 	KAWASAKI 	Z1000 	Naked 	296
058 	KAWASAKI 	VERSYS 1000 	Enduro 	285
059 	BMW 	K 1600 GT 	Turismo 	269
060 	KTM 	EXC 450 	Enduro 	268
061 	HONDA 	CRM 125R HM 	Supermotard 	252
062 	YAMAHA 	XVS 950 A 	Custom 	251
063 	MOTO GUZZI 	STELVIO 1200 	Enduro 	247
064 	APRILIA 	DORSODURO 750 	Supermotard 	245
065 	DUCATI 	848 EVO 	Sportive 	230
066 	HARLEY-DAVIDSON 	FLHX STREET GLIDE 	Custom 	230
067 	HONDA ITALIA 	CBR 600 F 	Sportive 	230
068 	YAMAHA 	YZF-R1 	Sportive 	230
069 	KTM 	FREERIDE 350 	Enduro 	226
070 	APRILIA 	DORSODURO 1200 	Supermotard 	224
071 	HARLEY-DAVIDSON 	XL1200C SPORTSTER 1200
CUSTOM 	Custom 	220
072 	HARLEY-DAVIDSON 	FXDB DYNA STREET BOB 	Custom 	219
073 	KAWASAKI 	Z1000 SX 	Turismo 	218
074 	KTM 	250 EXC 	Enduro 	215
075 	DUCATI 	MONSTER 1100 EVO 	Naked 	214
076 	HONDA ITALIA 	CBF 600 S 	Naked 	212
077 	HUSQVARNA 	SMS 125 	Supermotard 	209
078 	SUZUKI 	GLADIUS 650 	Naked 	208
079 	HONDA 	CBR 125 R 	Sportive 	206
080 	KTM 	990 ADVENTURE 	Enduro 	203
081 	KTM 	990 SUPERMOTO T 	Supermotard 	199
082 	TRIUMPH 	TIGER 1200 EXPLORER 	Turismo 	198
083 	YAMAHA 	WR 125 X 	Supermotard 	194
084 	HARLEY-DAVIDSON 	XL1200V SEVENTY-TWO 	Custom 	189
085 	GAS GAS 	TXT 300 RAGA 	Trial 	185
086 	TRIUMPH 	SCRAMBLER 	Naked 	183
087 	YAMAHA 	YZF-R6 	Sportive 	182
088 	HARLEY-DAVIDSON 	FLS SLIM 	Custom 	172
089 	BETA 	ALP 4.0 	Enduro 	169
090 	KTM 	200 DUKE 	Naked 	163
091 	KTM 	250 EXC-F 	Enduro 	162
092 	HONDA 	CBR 600 RR 	Sportive 	158
093 	HARLEY-DAVIDSON 	XL1200N SPORTSTER 1200 NIGHTSTER 	Custom 	157
094 	HARLEY-DAVIDSON 	FLHRC ROAD KING CLASSIC 	Custom 	155
095 	MOTO GUZZI 	750 NEVADA 	Custom 	151
096 	ENFIELD 	BULLET 500 	Turismo 	150
097 	SHERCO 	SHERCO 2.9 	Trial 	150
098 	KAWASAKI 	W800 	Naked 	148
099 	KAWASAKI 	NINJA ZX-10R 	Sportive 	147
100 	HONDA 	CRE F 250R HM 	Enduro 	143
http://www.motoblog.it/post/82119/mercato-classifiche-top-100-ottobre-2012-tmax-530-r-1200-gs-e-nc700x-restano-i-piu-venduti
Pe pagina respectiva,pentru luna octombrie/2012 gasesti si top 100 scutere vandute si top 100 vanzari globale la nivel national,in functie de marca.
Per total,japonezii nu stau chiar atat de rau,inca sunt sefi,cum ai zis si tu.Insa este adevarat,BMW are ceva succes,mai ales pe segmentul Enduro,dar au avut numere bune si in clasa Naked cu modelele F800R si R1200R.
Nici Triumph si KTM nu sunt de subestimat
Exact,asta spuneam,iata ca tu vii si cu cifre,japonezii pierd teren pe niste piete unde detineau monopolul.Si acest trend se accentueaza.Era o vreme (acum 6-7 ani) cand motocicleta de orice segment (mai putin chopper) insemna automat japoneza.Marcile europene erau foarte de nisa si aveau vanzare la ei aks.Acum europenii s-au lansat si sunt foarte bine ancorati pe pietele internationale.Acum cand auzi motor de viteza te gandesti la S1000RR si nu la CBR,cand auzi naked te gandesti la Triumph,Brutale,Monster,enduro-touring BMW e rege,etc.S-a schimbat treaba
De aceea ziceam eu ca trebuie sa vina cu ceva superior concurentei,asa (re)acaparezi piata.Ca daca tu faci ceva care e la acelasi nivel cu Er6,dar arata mai frumos,Er6 fiind pe piata din 2006,iti dai seama ca nu spargi pe nimeni.Aceeiasi Marie cu alta palarie.
Nu vad ce mare evolutie,inovatie,etc aduce MT-07,daca dai si mie exemplu de 1 (una) bucata evolutie fata de Er6 esti doctor.
Eu zic ca un Sv din 2003 sterge pe jos cu motoreta asta,mai ales la capitolul fun,si aia e o moto veche de 10 ani.Da,poate in mainile unui racer profesionist,MT-07 va fi superioara,dar astea sunt motoare la care primeaza feeling-ul si fun-ul,si aici eu merg pe mana SV-ului si/sau a Monster-ului.Deci ce e pana la urma asa bun la ea in afara de look?
Nu,mi se pare ca au cam gresit-o si cu 07 si cu 09.09 cel putin va avea concurenta grea cu naked-urile astea noi de 800.Total inferioara din start,copil nascut mort.Si eu sunt fan Yamaha,apai cei care nu sunt si judeca obiectiv...
Pai nush ca nu am mai iesit demult din Romeinia :D
Am stat ceva timp in Canada insa,daca ne luam dupa ce motoare vezi acolo,japonezii au cam imbulinat-o : Harley gramada,multe Triumph-uri naked si BMW-uri touring.A,si multe Monster.Iti zic sincer,naked-uri japoneze cam pas,ma si miram,eu iesit dupa cum ne-am obisnuit pe aici dintre Hornet-uri si FZ6,etc.Dar pe partea motoare sport,da,numa japoneze.In rest insa....
Si eu sunt fan Monster ca si look.Au scos o motoreta superba.Dar de ce am dat exemplu Monster-ul : pt ca e o moto etalon care a infiintat o clasa.Au stiut sa ia o nisa si sa o transforme in ditai segmentul de piata.Cum au facut asta?Au facut un motor cat mai simplu.Au pus sasiul lor trellis clasic si motorul L2,o bascula spate si niste furci usd pe fata.A,si da,frane brembo (probabil le-au gasit la discount).Motorul rezultat era destul de modern atunci,ieftin,curat,design aerisit si frumos.Si avea si personalitate.Ce vrei mai mult?
Secretul succesului care a fost?Numele Ducati pe de o parte combinat cu pretul mic pe cealalta parte,design-ul,si putina smecherie cu furcile usd si franele brembo.Sa nu uitam totusi ca au adus furci usd,chiar daca slabutze,intr-o perioada cand asa ceva era doar pe motoretele de varf,aici a fost smecheria.
Bine,ca dupa aia a venit Suzuki cu SV-ul si le-a dat in cap,asta e partea a doua.Suzuki le-a aratat cum tre sa fie un motor V2.
Uite,iarasi,SV-ul mi se pare un yardstick,toate motoretele pe acest segment au fost de atunci comparate cu el,ba pe deasupra a luat si clienti din clasa superioara,a naked-urilor 4L de 600.Si acum,daca comparam la rece,sunt f multe motoare care nu iti dau senzatia pe care ti-o da SV-ul.
Cum au facut - ca look nu e mare smecherie si nici a tehnica :au copiat cadrul de Monster si au obtinut ceva f bun,frane mediocre,suspensie chiar slabutza.Secretul a fost motorul :motorul ala e intoxicant.Sunt fan SV de cand m-am urcat prima data pe unul.Trage asa de jos de tot si parca nu se opreste,extraordinar.Nota 15.Si sunetul...Toate astea combinate cu comoditate buna si greutate mica si pret competitiv au dus la succesul SV-ului.Si apoi au mai venit si cu un update si de look si de tehnica (inj,cadru schimbat,etc,etc) in 2003 si de atunci mere treaba ceas.Se mai face si astazi in paralel cu Gladius din cate stiu eu.
Concluzia e ca pt a face un fun-bike,nu-ti trebuie mari tehnologii si inovatii ci doar cateva smecherii : un cadru bunicel,un design curat,greutate mica ca regula de baza dar mai presus de toate un motor cu foarte mult caracter.Care sa fie si artzagos dar si maleabil,elastic.Si asta zic eu ca poti face doar cu un V2.
Ori de aia zic eu ca MT-07 e slabutz,daca dai look-ul la o parte si il compari cu un SV,eu cred ca va iesi prost.Ori cand iesi prost comparat cu un motor vechi de 10 ani,ai o problema.
Si e pacat pt ca promitea MT-07 : are look-ul,are pretzul,are sasiul,are greutate mai mult decat ok,ii mai trebuia un motor cu caracter si vreo smecherie ceva pe langa.Eu zic ca daca ii puneau un motor V2 tot de vreo 70-75 de cai,si o pozitie pe led alb in fata,ceva,un gimmick,ii bagau pe toti in buzunar,ii amanetau :D
Vizitator Adrian
Method, vreau doar sa corectez o chestie la ce-ai spus (sau cateva)
Monsterul cand a aparut a fost ceva nou tocmai datorita motorizarii in V, un cadru usor, trellis, V2, 600 cc, etc.. era un motor fun. si-atat.
performantele sale nu erau ceva de publicat in reviste.
Si tocmai,aici vreau sa te corectez, nu e nici un SF faptul ca au pus furca USD, pt ca au pus o furca USD fara reglaje, foarte slaba.
Ce-i drept, Suzuki au fost idioti si au pus furca slaba atat pe prima generatie de SV 99-02, cat si pe a doua (aia pe injectie) 03-09.
Ca motorizare, Ducati poate sa ia o lectie de la Suzuki ( monster vs SV 650).
Si tot Ducati poate sa ia lectie de la Suzuki la categoria 916/996/998 & S4 / S4R de la TL 1000, la capitolul motorizare
Motorul de pe TL e mai puternic si dezvolta mai mult cuplu , motor pus pe TL din 97 ...
In cifre vorbind, motoru de pe TL e mai puternic si decat cel de pe Ducati 998....
Insa Suzuki au reusit sa fu.ta TL ul la capitolul suspensii & cadru.... si de aia 916/996/998 e superior unui TL , pur si simplu e o motocicleta mai buna.
TL ul e exmeplul de cum sa strici un motor bun, punandu-l intr-o motocicleta gandita prost... :)
Pai uite, Aprilia Shiver. La look e ok (oricum arata mai bine ca SV ul, parerea mea, mai ales cu tobele alea sub sa), e o motoreta moderna, throttle cu ride by wire, 3 moduri de riding, V2 750cc, putere mai multa decat pe SV sau Monster, deci foarte fun, furca USD (ca esti fan :P ), etc....
Si culmea, nu s-au bucurat de un succes asa mare cum te-ai astepta (asta poate si datorita stigmatului ca-s italiene....)
Shiverul nu are nici pe departe carisma unui Monster (look ul etc) cum e un 696 de ex..... dar la pilotat, 696 se sime ca o jucarie,iar Shiverul ca o motocicleta serioasa....
Eu cred ca tu pornesti de la o premiza gresita.
De ce comparam mere cu pere?
SV este o motocicleta produsa pana in 2008,este un model care a avut un mare succes,insa a fost inlocuit de Gladius.Ea este cea care intra in concurenta cu MT-07,asa cum face si ER-6N.Noi vorbim vorba de motociclete noi (~),de asta am si deschis acest topic.
Nu vad rostul pentru care sa ne raportam la piata motoarelor SH,ca asa nu-si mai cumpara nimeni o motocicleta noua,sunt atatea alternative uzate nu-i asa?Oricum la nivel european Romania nu prea conteaza pe harta in privinta achizitiilor de motociclete noi,la noi piata este absenta in aceasta privinta.Nici macar pe piata SH,daca facem o statistica nu avem cu ce ne mandri.
Suntem o tara fara cultura motociclistica dar si un popor fara resurse financiare.
MT-07 este o motocicleta mediocra,sa zicem ca nu iese in evidenta cu nimic.Asa cum sunt si Gladius si ER-6N.
Parerea mea e ca totusi sunt motociclete ce ofera unele emotii cand le conduci,senzatii pe care nu le intalnesti la platforma 4 cilindri.Si aceste motociclete au nisa lor pe piata.
Vom vedea in primavara care se descurca mai bine cand probabil se vor face si ceva teste de catre editorialele motociclistice.
Cand am spus ca evolutia inseamna inovatie,m-am referit la platforma MT-09.Avand in vedere criza financiara pe plan mondial si faptul ca vanzarile moto au suferit un declin important in ultimii ani,cred ca cei de la Yamaha au avut ceva curaj sa iasa cu un proiect complet nou,3 cilindri pe deasupra.Pe net umbla zvonuri ca se vor baza pe platforma asta cand vor face upgrade si pentru Yamaha R6 si TDM,vom vedea daca va fi sau nu asa.
Putem discuta despre MT-09 pe topicul dedicat: /index.php?/topic/698613-yamaha-mt-9/
Eu m-am dat cu ea in septembrie,la Yamaha Open Day.Insa parerea mea in privinta acestui model chiar este irelevanta.Sunt un incepator/amator in motociclism.Eu nu sunt fan Yamaha,iar acum MT-09 nu prea intra in target-ul meu...parca urmatoarea motocicleta as vrea sa fie ceva cu abilitati turistice.Naked-urile din ultimii ani se preteaza mai greu la asa ceva.
Lasand la o parte latura estetica,MT-09 se pare ca promite.Cel putin asa sustin revistele de specialitate si din partea testerilor profesionisti a obtinut in general pareri pozitive.
Parerea mea este ca concurentul direct pentru MT-09 este Street Triple :)
Kawasaki Z800 este un model relativ ok insa este prea grea (229 kg)... :nono:
Brutale 800 este model mai mult de nisa...dar nu e motocicleta de incepatori.Ciclistica este de bicicleta insa ca motor e instabila,prea brutala,finisajele sunt de slaba calitate la ultimul model.Chiar daca pretul acum e mai accesibil pentru public,tot ramane cea mai scumpa dintre toate.
In legatura cu datele oficiale,am gasit si o statistica partiala din Italia pentru anul 2013.Pana in luna iulie din punct de vedere a vanzarilor top 100 era in felul urmator:
http://www.motociclismo.it/mercato-a-luglio-calo-delle-moto-quasi-fermo-top-100-moto-moto-55956
In perioada ianuarie - septembrie 2013 suma totala a vehiculelor pe doua roti inmatriculate era de 159.050,in scadere cu 24% in comparatie cu aceeasi perioada din anul 2012.
Sursa
Criza economica isi spune cuvantul.
Vizitator Adrian
am mai zis-o si pe alt topic, o motoreta care se pisa pe MT-09 si MT-07: MV AGUSTA TURISMO VELOCE 800
http://www.topspeed.com/motorcycles/motorcycle-reviews/mv-agusta/2014-mv-agusta-turismo-veloce-800-ar161099.html
de la look, la touring capabilities, la orice (bine, in esenta e un touring)
Efectiv salivez la ea......
Vizitator Adrian
Ce au in comun Yamaha MT-07/MT-09 cu MV Augusta Turismo Veloce 800? :baldy:
Suntem OFF-Topic
s-a cam zis tot ce era de zis despre MT-07, mai multe ce poti spune din......poze?
si inevitabil discutia curge catre comparatii cu diverse motorete.......
Vizitator Adrian
stii cum e......vorbim,dar sa fim seriosi,cati din cei care citesc topicu asta isi permit un motor nou sau cati sunt dispusi sa dea banii pe un motor nou,mai ales de genul asta.... (ma refer la MT-07)
majoritatea vor veni cu lozinca "de banii astia imi iau un K9 de 750 si gata" sau etc......
@Adrian :
Da,in mare sunt de acord cu tine.No comment.
Da,furca aia usd nu e mare smecherie.Corect.Sunt suspensii mult mai bune cu furca clasica (vezi bmw).
Smecheria pe care a facut-o Ducati insa,si pe care restul nu prea au facut-o e ca a pus acea furca+frane brembo pe o moto entry-level,mai ales,dupa cum am zis,intr-o perioada in care furci usd existau doar pe rachete.
Cand tragi linie de fapt care e treaba : furca aceea de pe Monster nu ofera nici pe departe suspensia pe care o ofera o Kayaba sau o Showa puse pe ss,sbk-urile japoneze.Banuiesc ca a fost si ieftin de produs,deci Ducati a facut o vrajeala,o strategie de vanzare in opinia mea,dar le-a iesit foarte bine.S-au gandit in felul urmator "hai sa punem o furca usd,da sa fie eftina si niste frane de la confratii brembo sa le luam ochii la gugustiuci".Si le-a iesit,corect?Simplu si eficient.Ce nu le-a iesit a fost motorul.
Intr-adevar,SV a dat clasa Ducati la motor,si la sasiu,dar suspensia e muci.Si a ramas muci si la a doua generatie.Bun,acolo au inteles ei sa economiseasca,no comment.Bine,multi ii schimba furcile cu frane si roata cu unele de pe gixxer-ul de 600 si au rezolvat problema.
TL-ul in partea cealalta a fost un motor ce a devenit legendar.Pur si simplu crazy.Nota 15.
Shiver-ul mi se pare o moto foarte ok,da,intr-adevar,exista prejudecati,nu toate neindreptatite,despre Aprilia.
@WickedassHell :
Asta ziceam si eu mai sus,ca Rom nu exista pe piata motoretelor noi.
Compar MT-07 cu SV-ul si cu Monster-ul (dar si cu Er6),pt ca ele sunt etaloane pe aceasta clasa.Sunt motoretele "de batut".
Amandoua,si Sv si Monster,sunt motociclete icon care au generat cluburi specifice,etc,etc.
Gladius e o evolutie a SV-ului,cu acelasi motor.Arata mai bine,are cateva chestii in plus,dar nu mai e asa de pura,de clean ca SV-ul,si de aceea nu a fost primita cu acelasi entuziasm ca SV-ul.Gladius e cam girly :P
Rostul in a compara MT-07 cu aceste motoare e faptul ca acestea sunt alegerile pe care le poti face pe acest segment de piata.Ori daca MT-07 pica prost cand e comparata cu o amarata de motoreta veche de 5-6 ani pe care o poti lua cu 2000 si ceva de e,are o problema,pt ca nu vad de ce ti-ai lua-o.
Aia am inttrebat,ce aduce nou pe piata???
Fiecare din motoarele pe care le-am enumerat mai sus a adus ceva nou pe piata la data aparitiei lor.MT-07 ce aduce?Nimic,e un Er6 care arata mai bine si are sigla Yamaha.Slab.
Iarasi,MT-09,nu am mers,dar cel putin pe hartie nu ma impresioneaza cu nimic.Am vazut testul celor de la mcn,nici pe ei nu i-a impresionat cu nimic,ba dimpotriva : http://www.motorcyclenews.com/MCN/News/newsresults/videos/2013/October/oct1613-yamaha-mt-09-takes-on-rivals/
Regele ramane acolo Street Triple,Kawa e si el foarte bine reprezentat...
Brutale 800 chiar a avut parte de pareri foarte bune prin teste http://www.motorcycle.com/manufacturer/2013-mv-agusta-brutale-800-review-91633.html
Esti primul pe care il aud ca se plange de finisajele unei Agusta,eu am servit un Brutale 910R si mi s-a parut perfecta din toate punctele de vedere,in fine,fiecare cu parerea lui.
Cu MT-09,Yamaha a vazut ca se dezvolta foarte mult aceasta clasa a naked-urilor de mijloc si a vrut si ea o particica din tort.
Nu cred insa ca va avea mari vanzari pt ca,la fel ca la MT-07,nu a venit cu nimic nou si/sau mai bun decat adversarii.
Ca sa intri pe o piata unde pana acum nu ai avut un cuvant de spus,trebuie sa vii ori cu inovatii ori cu aceleasi solutii constructive ca adversarii,insa cu performante mult mai bune.MT-09 nu vine cu nici una din aceste treburi.
Bine,faptul ca au venit cu un 3L este o inovatie pt ei (bine,au mai avut 3L dar foarte demult),nu si pt restul pietei.
Parerea mea este ca Yamaha s-a cam inmuiat rau de vreo 4-5 ani incoace,in ce sens :
La clasa naked-urilor mici FZ6 e un model foarte slabutz ce niciodata nu a reusit sa concureze cu Hornet-ul.
La clasa naked-urilor mari,FZ1 la fel,motor bunicel de altfel dar nu are famecul CB 1000 (bine,si el copiat dupa Brutale,dar deh) si nici succesul lui Z1000.
La clasa sbk,R1,altadata un icon si motocicleta revolutionara care a schimbat regulile jocului,acum este tot timpul undeva la coada.
Doar la clasa ss mai misca Yamaha cu R6-le,dar si acolo are mari probleme mai ales cu Triumph Daytona.Bine,R6-le ala saracu a fost si este o motoreta ff buna,dar e aceeiasi de hat din 2006,cat sa mai tragi de ea...
Vanzari bunicele mai au pe TDM si pe FJR din cate stiu eu,pe touring-uri,dar acolo sunt altii care emit pretentii mult mai mari.
Iarasi,la choppere mai mere treaba cat de cat,dar si acolo concurenta e acerba.
Si acum venira cu modelele astea 2 cam rasuflate si care nu aduc nimic nou...
Ce mi-a placut la ei e faptul ca au testat nsite nise interesante de piata cu MT-01,o motoreta intr-adevar fantastica,care ar fi fost perfecta daca avea cu vreo 40-50 de cai in plus.Si la fel cu V-Max,ii mai trebuia putina forta,sa dea de pamant cu hipersport-urile,Busa si ZZR-ul.
In opinia mea,ar cam trebui ei sa puna mana si sa-si improspateze gama pt ca altfel risca sa piarda foarte mult teren.Si sa vina cu motorete revolutionare,si carismatice,pt ca asta era mai demult smecheria la Yamaha fata de ceilalti japonezi : aveai o motoreta cu fiabilitatea unei japoneze dar cu sufletul si pasiunea demne de o italiana pur-sange.
Aia era smecheria,si de aia (inca) imi place Yamaha.Dar dupa cum vad,directia in care au luat-o,numa motociclete pasionale nu mai scot astia...
