Gata Cu Comunistele!
mishu_canishu
Gata cu comunistele!!
Mi-am luat si eu un motor adevarat!! :finger:
Am achizitionat un B.M.W. K 75 S, fabricat 1996.
Detalii tehnice:
BMW K75 Specifications
Start of Production: 1985
End of Production: 1996
Numbers Produced: 18,485
Price: 11,990 DM
Engine
Motor Type: Four-stroke horizontal three cylinder in-line engine, liquid cooled
Bore x Stroke: 67 x 70 mm (2.63 x 2.75 in)
Displacement: 740 cc
Max Power: 75 hp (55 KW) at 8,500 rpm
Max Torque: 68 Nm / 50 ft lb at 6,750 rpm
Compression Ratio: 11.0 : 1
Valves Per Cylinder: 2
Valve Control: DOHC, using drive chain and cup tappets
Carburation System: electronic injection, Bosch LE-Jetronic
Engine Lubricating System: Wet sump
Power Transmission
Clutch: Dry single plate
Number of Gears: 5
Gear Selection: Dog type gearbox (ratchet foot lever)
Gearbox Ratios: 4.50 / 2.96 / 2.30 / 1.88 / 1.67 : 1
Rear Wheel Ratio 1 : 3.20 or 1 : 3.36
Bevel/Crownwheel: 10 / 32 teeth or 11 / 37
Electrical System
Ignition System: Electronic ignition, Bosch LE-Jetronic
Alternator: 12 V 460 W
Starter: 0.7 Kw
Spark Plugs: Bosch X 5 DC / Beru 12-5 DU
Chassis
Type of Frame: Tubular space frame, engine serving as load bearing component
Front wheel suspension: Telescopic fork with hydraulic shock absorber
Rear wheel suspension: BMW Monolever swinging arm
Spring Travel Front/Rear: 185 / 114 mm (7.28 / 4.48 in)
Wheel Rims, Front: MTH 2.50 x 18 E
Wheel Rims, Rear: MTH 2.75 x 18 E
Tyres, Front: 100/90 x 18 56 H
Tyres, Rear: 130/90 x 18 56 H
Brakes, Front: Dual disc brake 285 mm / 11.22 in diameter. Brembo 2 piston caliper
Brakes, Rear Single disc brake 285 mm / 11.22 in diameter
Dimensions/Weights
Length x Width x Height: 2220 x 900 x 1300 mm (87.40 x 35.43 x 51.18 in)
Wheel Base: 1516 mm / 59.68 in
Fuel Tank Capacity: 21 litres / 4.61 gal / 5.54 gal US
Unladen Weight with Full Tank: 227 Kg / 500 lb
Max. Permissible Weight: 450 Kg / 991 lb
Ground Clearance: 175 mm / 6.88 in
Seat Height (Unladen): 810 mm (31.90 inches) or 760 mm (29.90 inches) for low seat model
Fuel Consumption (at constant 90 Kph): 4.2 litres 100 Km / 67 mpg / 56 mpg US
Top Speed: 200 Kph / 124 mph
Acceleration: 0 - 100 Kph / 62 mph 4.6 seconds
Sa ai bucurii maxime cu ea :finger:
Dar ,am si eu intrebare mai carcotasa asa:cum de ai renuntat tu la niste motociclete "pline" de personalitate cum sant comunistele si ai trecut pe una care "nu se aude"? :10: ...scuze ,dar nu am putut sa ma abtin ;)
Sa stii ca este chiar foarte silentioasa! Cel putin la relanti de abia se aude!!
felicitari mishule, sa-l calaresti sanatos si fara probleme
PS
deci tu esti ala care ai luat bmw-ul de la noul magazin din pitesti....
ca am aflat pe alte cai...
sunt curios cum e, ca si pe mine m-a interesat, dar ... am o durere...in buzunar :finger:
bravo! sa te poarte sanatos! catzi km are "fiara"? e luata de afara sau de la un motociclist roman?
m
45.000 km si sunt primul proprietar in RO :finger:
PS
sunt curios cum e, ca si pe mine m-a interesat, dar ... am o durere...in buzunar ;)
Cum ai aflat?
De fapt nu l-am luat de la mag din Pitesti, mi-la adus Dl Adi de la brasov cu ocazia unui transport de moto la Pitesti!
stiu ca motorul a fost in pitesti, pe urma a ajuns la brasov (de fapt la codlea) si urma sa ajunga inapoi la pitesti la noul magazin de la intrarea in oras...
in poze arata cam....neingrijit
cum e in realitate? cum merge? cum e cu actele ?
Felicitari pt achizitie ! Astea-s motoare fara moarte, o sa cam duci dorul cheilor si patentului :10: O sa iti para rau dupa vremea comunistelor, ai sa vezi! Si nu ma refer aici la PERFORMANTE SAU FIABILITATE ;)
Hai sa ne vedem sanatosi pe sosele si al intruniri :finger:
Mi-am luat si eu un motor adevarat!! ;)
Detalii tehnice:
Price: 11,990 DM
Engine
Power Transmission
Number of Gears: 5
Electrical System
Starter: 0.7 Kw
Chassis
Dimensions/Weights
Sa o stapanesti sanatos ! Are ceva nerv ?
Sa auzim numai de bine si sa ai grija de motor ! :finger:
