X-Eleven
Noldy
nu demult am alcatuit o pereche, las pozele sa vorbeasca:
post-21482-1246269187_thumb.jpgpost-21482-1246269210_thumb.jpgpost-21482-1246269222_thumb.jpgpost-21482-1246269245_thumb.jpgpost-21482-1246269263_thumb.jpg
post-21482-1246269292_thumb.jpgpost-21482-1246269309_thumb.jpgpost-21482-1246269318_thumb.jpgpost-21482-1246269333_thumb.jpgpost-21482-1246269349_thumb.jpg
pozele le multumesc lui midnight_rain :disappointed:
Editat de Noldy
F frumoase pozele si motoreta. x11 este 3 in linie? :D
Sa-l stapanesti sanatos ! :P
Foarte misto motoreta! O prezenta mai rara pe la noi :D (saua aia rosie parca totusi nu-i de acolo). Ma uitam cu admiratie la ea cand aveam Hornetu, stiind ce muschi are. :P Am inteles ca e supranumita (neoficial) Super Hornet?
Am o curiozitate: care-i legatura cu XX-ul? Are acelasi motor sau cadru? Desi mie personal mi se pare ca se trage din XX, am citit pe MCN ca defapt nu e asa. Da-ne mai multe detalii tehnice.
Oricum ar fi, cat mai multi km de drumuri frumoase, fara accidente, iti doresc!
Editat de paul_biker
4 in linie :P
Scuze,am vazut doar 3 tevi si mi s-a parut ciudat,stiind ca doar Triumph fac 3 in linie... :D
Displacement: 1137.00 ccm (69.38 cubic inches)
Engine type: In-line four
Stroke: 4
Power: 140.00 HP (102.2 kW)) @ 9000 RPM
Torque: 116.00 Nm (11.8 kgf-m or 85.6 ft.lbs) @ 7000 RPM
Starter: Electric
Cooling system: Liquid
Gearbox: 5-speed
Physical measures
Dry weight: 222.0 kg (489.4 pounds)
Seat height: 810 mm (31.9 inches) If adjustable, lowest setting.
Wheelbase: 1,500 mm (59.1 inches)
Chassis and dimensions
Front brakes: Dual disc
Rear brakes: Single disc
Speed and acceleration
Top speed: 230.0 km/h (142.9 mph) aici cre ca si aia din fabrica se amuzau :P)
Power/weight ratio: 0.6306 HP/kg
Other specifications
Fuel capacity: 22.00 litres (5.81 gallons)
Color options: Black, red, blue
Comments: The X-Eleven's engine is a tuned-down version of the one found in the XX.
are cateva in comun cu XX-ul dar sunt diferite, nu m-am dat cu XX sa vad ce si cum doar din auzite.
putere are de jos(2-3mii) nu prea e de joaca cu ea, rupe aderenta daca o bruschezi si nu esti atent sau se ridica fara sa stea pe ganduri :rose:
saua nu e originala, trebuie sa o umplu putin ca apasa la 00 si la drumurile lungi e naspa.
multumesc de urari asfalt uscat va doresc :D
Editat de Noldy
Frumos motor, impresionante specificatii tehnice dar nu vad ce ce nu i-au pus 6 viteze.
Bafta! :D
sincer, dc sa-i puna 6 viteze? sa am io de pedalat? :D) eu zic ca a fost gandita bine... si asa zboara de te ia naiba :) :laugh:
  • 10 months later...
nenea midnight, cand imi scot vaca de la service e posibil sa te intreb de sanatate intru realizarea unui book de mare angajament artistic... undeva la munte sau la mare, preferabil amandoua :D
PS: crezi ca sunt sanse sa iasa asa ceva si cu un Sony H9?
@Carturaru'
:laugh:
Pentru sedinta cu X-Eleven am folosit doua blitzuri mobile pe stative, declansate radio si respectiv un DSLR. Luminile aditionale plasate strategic intr-o scena sunt cele care dau toata sarea si piperul.
In plus, pentru multe din fotografii am ajustat manual balansul de alb, iar pentru aia e nevoie de prelucrare din RAW, iar H9 din pacate nu trage decat JPG care limiteaza destul de mult paleta de lucru.
Daca ai ceva in minte, da-mi de stire. :D
nu are raw, e adevarat, ca m-a mancat undeva sa imi dau Nikon-ul, dar la fel de adevarat este ca H9 produce o deloc neglijabila rezolutie de 3264 x 2448. Sigur, nu aveam pretentia sa ajung din urma un SLR adevarat, dar macar asa, la nivel de amator, fara sa fie nevoie sa apelez la eternul Adobe :D
Ref. la ce ma intrebai tu, in primul rand am in cap intrebarea chinuitoare "cat?", ca locatii stiu destule :laugh:
Faina motoreta. Nu prea am vazut pe la noi. Cand am vazut-o prima data am zis ca e ceva VTR decarenat... dupa care am vazut motorul de 4 in linie.
Impozanta si impresionanta, dar nu prea vad ce poti sa faci cu asemena monstru. Pe viraje cred ca e cam greu si lat. Prin oras nu cred ca e foarte agil. Are multi cai, dar nu prea poti sa ii folosesti, ca e naked si peste 140-150 km/h te zboara vantul grav... gresesc?
