Am nevoie de piese DE CALITATE pt. reconditionare IJ Planeta 5
Vizitator MosRahao
Vizitator MosRahao
Am nevoie de urmatoarele piese pentru IJ Planeta 5. Rog frumos seriozitate. Sunt interesat de piese de origine, nu chinezarii. Unele pot fi si second, dar in foarte buna stare. Cu exceptia celor de motor, ce ma intereseaza doar NOI si de BUNA CALITATE. Sunt interesat de livrarea lor in cel mai scurt timp, in special a celor trecute la ETAPA 1.
Rog seriozitate. Asadar:
ETAPA 1: REPARATIA MOTORULUI
REZERVOR BENZINA MODEL NOU, CU CAUCIUCE, ORNAMENTE SI EMBLEME
BUSON PT REZERVOR CU CHEIE
ROBINET BENZINA REZERVOR
CARBURATOR K68 PEKAR
SET GARNITURI MOTOR SET COMPLET CU TOATE GARNITURILE
SET SEGMENTI cate UN SET COMPLET PT COTELE 1, 2 si 3
AMBIELAJ COMPLET TOT ANSAMBLUL, NOU
PINIONUL DE ATAC PINION 16 DINTI
FOAIA DE SPATE ORIGINALA !
LANTUL DE TRACTIUNE VREAU UN LANT BUN ! + BURDUFURI LANTZ
SET SURUBURI INTINZATOR LANTZ STANGA-DREAPTA
SET PLACI DE AMBREIAJ
LANTUL PRIMAR (DE DISTRIBUTIE) RUSIA
AXUL DE LA MELCUL DE PORNIRE
PEDALA DE PORNIRE CU TOT CU SISTEMUL DE PRINDERE SI CAUCIUCUL DE PE EA
SETUL DE SEMERINGURI MOTOR INTREG SETUL DE SEMERINGURI
PEDALA SCHIMBATOR VITEZE MODELUL CU CALCAI
FILTRU AER complet INTREG ANSAMBLUL, CU CARCASA CU TOT
CAPACE MOTOR STG-DREAPTA, CELE CE ACOPERA CARB+FILTRU AER, MODEL PLANETA 5
PLATINA
SET CARBUNI ALTERNATOR
TOATE CABLURILE DE COMANDA ACCELERATIE, KM, FRANA, AMBREIAJ, INCL. SURUBELE, BURDUFURI, ETC.
COMENZI COMPLETE STG + DR COMPLET - INCLUSIV SOC, DECOMPRESOR, CABLURI SI LEVIERE MANETA DECOMPRESOR CU TOT CU SISTEM PRINDERE MANETA SOC CU TOT CU SISTEM PRINDERE
BORD PLANETA 5 COMPLET
CONTACT CU CHEIE CU TOT CU CARCASA NEAGRA PLASTIC, SCRISA IN RUSESTE
TOBA ESAPAMENT COMPLETA INCLINATA, CU TOT CU COT SI FLANSA ORIGINALA DE PRINDERE
ETAPA 2: REPARATIE ROTI, FRANE
AMORTIZOARE, FURCA
SABOTI DE FRANA
KIT REPARATIE TELESCOAPE SPATE BUCSE, SEMERINGURI - 15 LEI PT AMBELE TELESCOAPE SPATE SISTEM ORIGINAL "FRANA DE MANA"
AMORTIZOR ATAS DE CARE?
BUCSI BASCULA CU AX CU TOT
CAUCIUC 3,50-18
CAMERA 3,50-18
"FUSTA"/"Pantaloni" PT FURCA FATA
? JANTA CU TAMBUR ? DUPA VERIFICARE VOM STI CATE TREBUIE: 1, 2 SAU 3 BUC ? ? FURCA FATA ? SET COMPLET, INCLUSIV SIMERINGURI, TOT - ? DUPA VERIFICARE
ETAPA 3: REPARATIE CAROSERIE
CUTII+CAPACE LATERALE COMPLET, STANGA-DREAPTA, CU CHEIE, CUTIE+CAPAC+ORNAMENTE OGLINZI ORIGINALE IJ PLANETA 5 SEMNALIZATOARE MOTO ORIGINALE IJ PLANETA 5 SEMNALIZATOARE ATAS PENTRU ATAS DE PLANETA 5 CU CAPACE RABATABILE STOP SPATE COMPLET, CU RAMA, OGLINDA SI CARCASA SET SCARITE FATA RABATABILE SET SCARITE PASAGER RABATABILE ARIPA FATA PENTRU FURCA CLASICA INCLUSIV CU SISTEMUL ORIGINAL DE PRINDERE HUSA IJ PENTRU SHEA MODEL NOU; 1 BUC VREA PEDROS SET "PRESURI" CAUCIUC
BANDA ORNAMENT ATAS CEA DE CAUCIUC, DE JUR IMPREJUR, DE LA JUMATATEA ATASULUI PARBRIZ ATAS REZOLVAT. CONFECTIONEAZA DL. BOGDAN HAREA BARA ANTIRASTURNARE ATAS INCLUSIV CU SIST DE PRINDERE CRASH BAR
toata lista se refera la piese ij planeta 5, cu atas, an fabricatie: 1990. poate fi trimisa pe e-mail o lista sub forma de tabel cu toate acestea din lista prezentate mai organizat. multumesc!
Editat de Festina Lente
Vizitator MosRahao
Salut! Toata lista de piese este chiar sus, intreaga... Astept PM-ul tau, cu o oferta, fireste cu ce ai din lista. Vad cate ceva in poze dar poti sa mi le detaliezi in PM, sau public, nu ma deranjeaza, inclusiv cu preturi? Fireste, ma voi sfatui cu Pedros... Multumesc frumos! :cheers:
Rulmentii de ambielaj sa fie cu colivie de bronz fiindca sunt mai durabili decat ceilalti. Costa aprox. 50 de lei bucata si iti trebuie doi. Ii gasesti la orice magazin mai bine aprovizionat.
Placi de ambriaj, vezi ca se gasesc de doua feluri: unele maronii, inchise la culoare - astea sunt standard(sunt bune si ele) si altele mai deschise la culoare, cu ceva pluta am impresia, cu materialul de frecare mai lat, potrivite pentru o motocicleta cu atas care duce greutate.
Spor!
Editat de Andrei_D
vorbeste cu Gaspar ca el are tot timpul stoc mare, nu te stresa piesele de Ij sunt fabricate la Izmash - poate nu toate cablurile, pistoanele sau segmentii - dar nu-ti face griji.
Vizitator MosRahao
oare cum dau de Gaspar? ai un link ori un telefon al lui, te rog?
Spor!
merci! de rulmenti se ocupa Pedros, ca stie de care sa ia...
Vizitator MosRahao
am vb cu dl Gaspar azi, i-am trimis lista. Multumesc Aleko, Pedros, Dany si Robert. Sper ca pana la urma sa reusesc sa cumpar piesele necesare...
pare un challenge sa cumperi piese de Ij... :D parca le-as cere de pomana, asa ma simt. in fine. multumesc.
problema e calitatea nu piesele...eu de multe ori ma feresc sa aduc anumite piese, ca stiu ca nus de calitate si ca motociclist stiu cum e cind pui un lucru si te tine 2 zile...cind dai un ban ai si o pretentie.
ti-am spus ca sint tone de piese acolo dar nus de caliatate din pacate...cererea este mica si nu se mai fabrica mai nimic pt.ele..doar mici particulari care au 2,3 hale, ceva scule si fac ei acolo piese..dar fabrica in UCRAINA ce face piese de ij nu exsita..doar particulari pe care nui mai verifica nimei de calitatea pieseleor,se face la numar nu la calitate, ai sa vezi si tu ce ambelaj frumos primesti,cu stanta pe biela IJ si alta serie ca dupa cel original..diferanta ai so vezi destul de bine...
apropo de ambelaj, de la cel de la care il cumperi, sal masoare cu sublerul sa fie centrat bine ca altfel nu poti inchide carterele,am patito si eu de aia iti spun prieteneste.
pun ceva poze unde trebuie verificat ambelajul.
Vizitator MosRahao
sa inteleg ca-l cunosti pe dl. gaspar? ce opinie ai despre el si calitatea pieselor livrate?
nu conetez nimic,ma stiu cu el, ca ne intilnim periodic in bazar :)
cumpara omul ce gaseste in bazar si el...si vinde mai departe,fiecare are politica lui..
sint avantaje si dezavantaje legate de fiecare..el stie doar cite roti are o moto...la mine e alta treba ca ma ocup in general numai cu motociclete..vind, cumpar,colectinez,reconditionez..le expolatez..fiecare cu pasarica lui..
:cheers:
aduce si omul piese bune daca chiar vrea si stie unde sa caute,dar deeobicei la piesele ieftine se cistiga cel mai bine.
piesele de calitate costa duplu sau de multe ori triplu la pret si bienteles ca nu mai poate pune omul acelasi adaus, ca nu mai vinde...cum spuneam mai sus fiecare cu politica lui..legata de piese.
iti dau un mic exemplu sa vezi ce inseama o piesa de calitate in UCRAINA:
anul trecut am avut un motor de jupiter5 nou nout cu aprindere electonica de la mama lui,lam pus la vinzare cu 250 de euro,il lasam si la 200...multe persoane au comentat pretul lui mare cica...am dus motorul in ucraina si sa vindut cu 700 de dolari moment,daca aveam 5 motoare le dadeam imediat...deci trage o concluzie cam ce inseama o piesa de calitate sau originala si acolo. ;)
am vindut acolo multe piese carate de la noi, la niste preturi super bune..
Editat de dany_oldmoto
Vizitator VULPOIU
Pentru că: ucrainianul este OM DEÂŞTEPT: foloseÂşte cu succes Âşi recondiționează ceea ce ARE, ...pe cînd idiotul de romîn, la un salariu de 500-800 de lei face credit în bancă ca să cumpere o panaramă japoneză veche de 30 de ani, la care plăteÂşte 5-7 ani Âşi pe care dă mii de ioro. Pe cînd în IT aceiaÂşi panaramă costă cîteva sute...
Să mă contrazică cineava. ÂŞi cine se simte jignit, să fie sănătos.
din pacate in IT lucrurile ce trec de 20 ani au valoare in special moto, mai ales de 30 ani. au cultura de vechituri nu ca noi,sunt vechi,rable etc.
Vizitator VULPOIU
Daca tu imi spui ca un cb 500 costa cateva mii,si e praf,inseamna ca habar n-ai despre ce vorbesti.Un cb in romania daca dai pe el undeva la 1300-1500 , si il intretii cum se cuvine,te tine mai mult decat orice comunista vrei tu.In IT normal ca sunt mai ieftine,dar se pune problema de transport-inmatriculat si ai nevoie de omul care sa o aduca,sa o verifice inainte sa o cumpere inainte sa o aduca ma rog intra in ecuatie mai multi factori,dar la cateva mii de euro in nici un caz NU poti spune ca este o rabla . :cheers:
Vizitator VULPOIU
BRAVO! exemplul excelent de... romîn.
Sau, MĂMĂLIGĂ, cu care se fac boieri MUUUHUHULĂI Âşulfari.
  • 11 years later...
si acum tot aceleasi nevoi sunt,ca si atunci,ca nu se gasesc,dăcât di pi stoc)
si cine are n-are de dat,de ce le-ar da ..?
ahhhh ... pt pretul corect,era sa uit ..
(ala din obor)
dusu s-au acele vremi
PS.
eu vanez un 56 cu atas din 1999.
Periodic merg cu speranta pe acolo ca poate ..
Bunicul s-a dus,a ramas bunica (si ea bolnava)
am fost si alaltaieri,acelasi rezultat
Motoreta sta in garaj neclintita de vreo 30 de ani,nici odata n-am vazut-o pornita,dar e bine conservata si are potential.
Noul termen cica ar fi acum dupa sarbatori. (consultatie cu familia)
cata motorina am ars din '99 pana acuma,mergand periodic pana acolo cred ca am cumparat-o deja de  doua ori 😁
Editat de shui
eu nu inteleg pasiunea asta pentru mizeriile astea de ij-uri nici sa ma bati! hai, un 49 mai merge, ca e dkw practic, da' in rest??? gunoaie depasite la vremea lor, piese facute intre doua sticle de vodka (si nu ma refer la cele de cooperativa), urate cu spume... in tinerete a avut asemenea blesteme de motociclete, pusesem aprinderi electronice, rulmenti skf (pe atunci erau cei mai buni pe care-i gaseai in rromalezia), carburatoare de pe jafoneze, tot felul de nebunii. si tot niste mizerii erau. si atunci, ca si acum, le-as da foc si uitarii!
