Jump to content
Sign in to follow this
geobibicu
Bucuresti-vitan
Recommended Posts
aha si de unde sti cat sa regleze? sau de unde stie cat sa regleze? hai ca rulmentii conici sant interesanti!deci, cum se regleaza rulmenci conici care nu stiu unde sant???sau poate stiu!
Share this post
Link to post
Share on other sites
Bearing setting
The term “setting” indicates a specific amount of end play (axial clearance) or preload in a bearing. Unlike other rollingelement bearings, tapered bearings don’t require close control of shaft or housing fits to obtain an accurate setting. Because they are mounted in pairs, their setting depends mostly on the location of one bearing row relative to the other on the shaft.
Bearings can be set to achieve one of two conditions:
• End play — Axial clearance between bearing rollers and races, which allows axial shaft movement when axial (thrust) force is applied.
• Preload — Axial interference between rollers and races so there is no axial shaft movement.
Generally, a setting ranging from near zero to slight preload maximizes bearing life. Some applications use moderate preload to increase rigidity of highly stressed parts that would otherwise be adversely affected by excessive deflection and misalignment. Excessive preload, though, can drastically reduce bearing fatigue life or cause high temperatures that can quickly lead to bearing damage.
Manual setting
Production-line assembly workers often set bearings manually for equipment that is manufactured in low-tomoderate volume, and where a non-exact and wider-than - normal range of end play is acceptable. No special tools, gages, charts, or fixtures are typically required. In a truck nondriven wheel, for example, manual setting consists of tightening an adjusting nut on the end of the shaft while rotating the wheel until a slight bind is felt. Then the assembler backs off the nut 1/6 to 1/4 turn to the nearest locking hole or enough to let the wheel rotate freely. The adjusting nut is then locked in position.
Share this post
Link to post
Rulmenti care se "aseaza"? Ce pacatele mele se deformeaza, rolele alea de otel calit? caile de rulare fac santuri?
Share this post
Link to post
”Mestere”... Confunzi asezare cu setare.
» Post actualizat in 04 Oct 2016 10:07
recomand cu incredere si din tot sufletul un mecanic care lucreaza la un motor ca si cum ar fi al lui si are preturi foarte modeste.RAZVAN(0724012375),complex axxa,vitan.
Salut,
Dupa mult timp mai intru si eu pe forum, dar acum doar sa va spun despre Razvan. Il cunosc foarte bine. A lucrat 12 ani in Italia(Napoli) ca mecanic moto.
Bine ca exista oameni ca Razvan. Felicitari!
Share this post
Link to post
"Bunicule", pai tradu dumneata ce intelegi prin "bed in " in situatia de fata daca nu "asezare"? Daca rulmentii nu tin prestangerea in timp e o problema undeva (piulita se desface, se brineleaza, etc), nu se uzeaza in 500 de mile daca sunt montati ok.
  • During the first few miles, new or freshly repacked bearings may bed in slightly and go slack. This is perfectly normal, so be sure to keep your eye on them. Double-check the preload after your first road test and again at the 500-mile mark, readjusting them as necessary.
Edited by einstein1984
Share this post
Link to post
”Profesore”... concentreaza-te pe asta: Bearing setting. The term “setting” indicates a specific amount of end play (axial clearance) or preload in a bearing.
Edited by Dan Nastase
Share this post
Link to post
Am fost iarasi la Razvan cu Transalpul meu cu probleme la kilometraj. M-a rezolvat pe loc. Credeam ca s-a dus melcul, eram pregatit sa scot iarasi suta din buzunar. Dupa cateva verficari a depistat ca cablul era desurubat din bord. Nu a vrut sa ia niciun ban!
Share this post
Link to post
concentreaza te pe kerosen. da mi traducerea exacta in 5 cazuri si ai sa vezi ca difera. nu te mai tine atat ca ori cat iti doresti sa fie ca tine nu ai sanse. nu exista reglaj.
Felicitari Razvan, am auzit ca faci treaba buna.
Edited by Florin -v
Share this post
Link to post
Florin, sincer, esti pe un topic unde-i de bonton sa incepi cu prestatiile bune ale mecanicului Razvan, nu sa te bagi in fata ca in piata Moghioros....
Nu stiu de unde crezi tu ca ai capacitatea de a-i sugera unuia ca e slab la semantica... sau altuia sa se concentreze pe apa, zaibar sau kerosen.
Daca te intereseaza, poftim: file:///Users/manue.labulat/Downloads/STEMCO.BearingAdjust.571-2902.r1%20(1).pdf
Dar eu totusi insist sa ramanem on-topic la... Razvan, am auzit ca faci treaba buna.
E cea mai buna formula pentru noi.
Share this post
Link to post
Nu vreau sa fiu rau,dar am vrut si eu sa imi regleze amestecu la o honda hornet acest Razvan. Omu zicea ca surubelele alea de sub carburatoare (pilot jet screw) sunt pentru aer.. Asa ca mai usor cu lauda :)
Share this post
Link to post
eu sunt foarte multumit de acest razvan! mi a rezolvat problemele de fie care data ,de cate ori am fost la el! poate nu ia placut de fata ta!
Share this post
Link to post
Ala e..nu I-A placut fata mea..d aia m a amanat 2 sapt pana cand nu a mai sunat deloc..hai sictir :)
Share this post
Link to post
Salut! As vrea sa schimb un chit de lant pentru un GSR600 din 2006. La tipul respectiv se pot comanda si piese sau le iau eu si ma duc cu ele? Multumesc!
Edited by TOURING MOTO
Share this post
Link to post
poti sa sun si pe el sa intreb! dar intresazete si tu cat costa chitul!
» Post actualizat in 17 Oct 2016 08:05
Chitul de lanti pentru suzuki gsr este la 480 lei did daca te intresaze! Si 70 lei manopera!
Share this post
Link to post
Bai frate, eu nu il recomand ma pe acest Razvan. Tot timpul amabil cu clientii, iti raspunde la intrebari tehnice fara interese financiare, mereu politicos la telefon, preturi vai de mama lor, va zic sincer, de-a dreptul enervant.... ba eu nu il recomand ma ca dupa aia nu mai are timp de motocicleta mea.
Share this post
Link to post
cred ca in afara de bogdan padure si tng nu are adversar ...
Share this post
Link to post
Se dovedeste o data in plus in relatia motociclist-service... ca benefica este ingineria... nu alte speculatii.
Din punct de vedere ”mecanica moto al lucrului bine facut”... ce bine ca exista oameni ca Razvan. Felicitari!
post-882-0-87164800-1510488697_thumb.jpg Ma mandresc cu prietenia lui, un adevarat caracter, doctor chirurg in motociclete.
La multi kilometri frumosi!
Share this post
Link to post
numarul nu mai este valabil? Stie cineva un alt numar? Sau o alta recomandare?
Am un zx6r care sare din treapta 2a :(
Share this post
Link to post
E in concediu !
Share this post
Link to post
Rog actualizare . .
Program lucru, adresa, nr telefon
Multumiri .
» Post actualizat in 05 Oct 2018 10:09
Rog aici pe forum actualizare . .
Multumiri .
Share this post
Link to post
habar n-avem ma programu...de pe la 8-9 pana pe la 19-20...pune mana si suna-l 0724012375.
Edited by Ribo
Share this post
Link to post
. . Mă, faptul ca ti a dat Dumnezeu bavarez k1200s nu te scuteste de o minima buna cuviinta .
Si eu am de un car de ani RGS1200 si mai nou un GT 1600 6 cilindri in ograda personala si nu ma simt cu mult mai falos de asta
Nu s a mai actualizat ce am intrebat despre Razvan aici si cine stie ar face un mare bine comunitatii moto indiferent ce mobra are fitecine . .
Hai pa!
Multumiri .
Edited by Dan Olaru
Share this post
Link to post
Doamne, nu te pisdifica acum stai linistit.
Lucrurile astea sunt deja cunoscute , mai putin programul care e flexibil.
Credeam ca ai nevoie mura-n gura.
O sa actualizez buna cuviinta cu tine ca sa nu te mai superi nextime.
MA, nene MA !
Share this post
Link to post
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
