8. ARAGON GoPro Grand Prix of Aragon
Cavaleru
Vineri 06.06.2025
10:00-10:35 Moto3™ Free Practice Nr. 1
10:50-11:30 Moto2™ Free Practice Nr. 1
11:45-12:30 MotoGP™ Free Practice Nr. 1
14:15-14:50 Moto3™ Practice
15:05-15:45 Moto2™ Practice
16:00-17:00 MotoGP™ Practice
Sambata 07.06.2025
09:40-10:10 Moto3™ Free Practice Nr. 2
10:25-10:55 Moto2™ Free Practice Nr. 2
11:10-11:40 MotoGP™ Free Practice Nr. 2
11:50-12:05 MotoGP™ Qualifying Nr. 1
12:15-12:30 MotoGP™ Qualifying Nr. 2
13:50-14:05 Moto3™ Qualifying Nr. 1
14:15-14:30 Moto3™ Qualifying Nr. 2
14:45-15:00 Moto2™ Qualifying Nr. 1
15:10-15:25 Moto2™ Qualifying Nr. 2
16:00MotoGP™ 11 Laps Tissot Sprint
Duminica 08.06.2025
10:40-10:50MotoGP™ Warm Up
12:00 Moto3™17 Laps Race
13:15 Moto2™19 Laps Race
15:00 MotoGP™23 Laps Grand Prix
Track by category
Category    Laps    Total Distance      Finish in case of red flag
MotoGP™    23         116.77 Km            17
Moto2™       19          96.46 Km            14
Moto3™       17           86.31 Km            13
Circuit Specs
Total length 5.08Km
Total Width  15m
Longest Straight 968m
Right Corners 7
Left Corners 10
Diiii calutzuuu!
  • Răspunsuri 145
Acum 12 minute, frigider a spus:
nu vreau sa par nu stiu cum dar cred ca e momentul sa mai bage MM o dubla, incepe sa para ca si-a cam iesit din mana.
De dragul suspansului, sa ne ferim de așa ceva. 😄
Acum 20 ore, MirceaB a spus:
Toate sansele. Ii place circuitul. Singurul care poate sa-l incurce e frati-su
tinand cont ca a castigat de 7(sapte!!) ori aici, inclusiv anul trecut, nu vad cum s-ar dezalinia planetele sa nu castige acum....
PS. victoria de la Moto2 din 2011, nici n-am mai pus-o la socoteala :) :)
:rusinica:...stiu,slabe sanse sa castige altcineva....
...in alta ordine de idei,se ridica tot mai multe voci impotriva ride-height device :
Alex Márquez’s crash at Silverstone wasn’t just a racing incident — it reignited MotoGP’s biggest safety debate.
 "Without the crash, Álex Márquez would’ve won with one hand behind his back." – Francesco Bagnaia
The culprit? MotoGP’s controversial height adjustment system, aka the holeshot device. Once hailed for its performance gains, it's now under fire — and Alex Márquez’s high-speed fall may be the tipping point.
 At Le Mans and Silverstone, riders reported the system failing to disengage quickly enough. When the bike stays low in fast corners, it compromises front-end grip and control, leading to dangerous scenarios — especially in the chaos of race starts.
"We need to stop using it at Le Mans – it’s just not safe." – Johann Zarco
Even Marc Márquez, once a defender of tech advancements, now calls for limits, saying the device "makes our job easier but also more dangerous."
Poate ar fi bine sa le interzica chiar mai devreme de 2027.
Acum 40 minute, Method a spus:
asta era declaratia lui MM din cate stiu eu, dar in fine, nu conteaza
Daa...Marcel le-a dat o secunda la toti. 🤦‍♂️
Hai frate,deci chiar toata lumea doarme acolo?wtf...
Quartararo : "Aragon's going to be an important moment for us"
Descrie perfect "problemele" - low grip,high track temperatures,big straight line"....aici isi da Yamaha examenul - daca merge bine (nu cred ca vor avea fata de podiums,dar macar un loc 5-8),atunci putem intradevar vorbi despre un reviriment.Altfel,totul ramane la stadiul de un mic foc de paie datorat temperaturilor scazute si configuratiei tehnice a circuitelor trecute.
...si inca in FP1 a fost elegant - 24 grade in aer /38 la sol.In quali va fi probabil 35/50,atunci sa vedem.
Fingers crossed.
Dupa FP1 sunt (toti) departe oricum de timpii de pole - 1.45.8 (2024),mai trebuie sa rada o secunda.
Să nu uităm că, în plus, este un "circuit de mâna stângă". Pe astea antiorare se simte oricum ca peștele în apă.
Anul trecut, pe cotețul din 2023 a făcut record de circuit, pole, și a câștigat și cursa mică și cea mare.
Acum 2 ore, Kagemusha a spus:
nu era murdara pista atunci?
stiu ca a fost un gp murdar si acolo a facut dubla.
*mai mereu morbi sta dupa Peco, da pare ca niciodata nu deranjeaza chestia asta.
FP...52 grade la asfalt..."revirimentul Yamaha" s-a bashit....as expected din păcate...
Low grip 50gr+ și Yamaha e pa.Quartararo pierde gripul spate în a4a...
Si ce e cel mai nasol e ca de acum încolo toată vara cam astea vor fi temperaturile.
Yamaha e motoreta de primăvară/toamnă :D
Așa zicea lumea, dar a fost atât de murdară încât Marc Marquez a stabilit un nou record al circuitului.:P
Numai segmente reduse de pistă au fost inundate și s-a lucrat pentru a fi curațate cum trebuie.
legat de teoria asta cu plecatul lui Peco la Yamaha - ceea ce mie mi se parea f aiurea
englezii au emis o teorie:
MM bate mereu colegu, e un fapt. Anu asta o demonstreaza, istoria o confirma.
La anu sunt sanse f mare sa fie la fel.
Nu il poti bate pe MM cu aceeasi moto, dar poate pe alta?
Ca managementul lui Peco ar trebui sa faca bine sa-l extraga.
acum ca au zis-o chiar are sens.
degeaba e italian si protejatul ducati daca pur si simplu nu se leaga efectiv nimic.
totusi, ok il bate MM dar de ce il bat si altii asa usor? clar ceva nu e in regula. si eu ma asteptam sa fie MM 1, Peco 2 mai mereu.
sa fie doar faptul ca mm e mereu mai rapid si peco a dat totul peste cap incercand sa ajunga la aceiasi timpi?
asta pe langa faptul ca moto s-a schimbat in rau pe intrarea in viraj cica, da e mai buna pe iesire.
traim si vedem.
tot de la englezi:
aceeasi experti care spun de toprak ca nu se va potrivi stilul cu GP-ului+cauciucurile au zis si de MM la momentul venirii in GP ca daca vine in GP cu stilul sau de la moto 2 nu va face nimic.
Editat de frigider
Acum 15 ore, frigider a spus:
Pai sunt colegi de academie mai...Morbi ala e așa un bashit...din toate punctele de vedere.E pe Gp24 acum nu?Super motoreta,și el e lemn acolo.Il bate Aldeguer cu ceasul de la gara,și nu e ca și cum Aldeguer ar fi venit campion din moto2 precum a venit el samd...
Din toată școala italiana din toată Academia (un gest dealtfel foarte binevenit și bun din toate punctele de vedere al lui Rossi) doar Pecco e intradevar un talent confirmat.
Bezz și el mișcă so and so,Diggia e sporadic.
În rest,spaniolii dau ora exacta - e oarecum normal pt ca în Spania statul e implicat direct în trainingul lor cu scoli din astea de ii iau din generala,e un sistem f bine pus la punct în timp ce în Italia strădania lui Valentino e singulara,nu știu sa aibe statul vreun amestec.Pacat,pt ca,avându-l pe Valentino care e interesat sa promoveze pilotii italieni,dacă se implica și statul putea ieși ceva f bun.
Asa doar cu Pecco printre mareea spaniola...cu o floare nu se face primăvara.
Acum 13 ore, danypop a spus:
Yamaka ca yamaka, da aprilia, aprilia aia castigatoare unde s-o fi dus? O fi pus-o de-oparte pentru cand vine Martin 🤣🤣🤣🤣🤣
La Aprilia se știa clar ca va excela pe Silverstone...si pe încă vreo 2 circuite.Si atat.
Cu toate astea mie mi se pare ca Martin greșește vrând sa plece de la ei...
Acum 12 ore, frigider a spus:
Asta e strategia Zarco - HRC dacă îți aduci aminte : curtat de Puig și momit sa vina lângă MM la Honda care pe atunci mergea atza,Zarco a refuzat pt ca ii era frica sa se bata de la egal la egal cu demonul încercând sa se ducă la o motoreta care sa ii dea un edge în fața lui - ne aducem aminte cum a decurs strategia măreață a lui Zarco : refuz HRC mers la KTM după 1 an plângând retragerea unilaterala din contact și luat de mila pe la un privat Ducati parca?
Pecco ar trebui sa tragă învățăminte din asta - tot timpul trebuie sa urmărești best bike on the grid.Chiar dacă e demonul acolo.Macar ai arme egale,asa cu Yamaha ai arme sa te sinucizi nu altceva,uită-te la Quartararo.
Asta e situația,Pecco trebuie sa persevereze cu MM lângă el,iar eu cred ca Pecco e destul de inteligent sa înțeleagă asta ,iar mutarea la Yamaha mi se pare doar zvon.
Mai ales cand Q a zis zilele trecute ceva în genul ca "Dacă asta nu merge voi cauta o moto care sa fie ready pt a ma bate la campionat" dând oarecum un mesaj gen "ori o faceți cum trebuie ori ma car".
Nu,eu zic ca Pecco nu e atât de prost incat sa se mute de la Ducati.
tot de la englezi:
Sa nu uitam totuși ca Toprak a făcut un test la motogp unde a fost...chiar slab.Adica nu e o mare necunoscuta ce se va întâmpla - moto slăbuța pilot puriu și deloc din filmul asta cu motogp,deja făcut un test și ieșit la aproape 1s  în spatele lui Chel...crezi ca la următorul test va ieși pe 1?Sau?
MM la primul test a ieșit pe 1.Scurt.In 2013 era Lorenzo era Pedrosa era Rossi era lume de lume în gp,piloti extrem de rapizi.Si a venit ala și boom - 1 direct in presezon.Ok - și moto de locul 1 dar un rookie a bătut niște nume grave da?E o mare diferență - s-a vazut din primul contact ce avea sa vină.
Și la Toprak se vede dar ne place noua underdog'ul, hype'ul și nestemata din țărână.Ar fi de povesti sa vina turkish delight din alta disciplina la 30 de ani și sa dea mucu lui Memelu,dar astea sunt basme cu zâne.
Realitatea (dura) e ca probabil MM ii va bate în cap iar și iar pe toți câțiva ani buni de acum încolo pana ne va exaspera pe toți (pe mine după jumătate de sezon m-a obosit deja,visez la tensiunea și intensitatea dintre JM și Pecco din 2024).Csf,asta e...anul asta vedem defilarea.Sa nu fie la fel și în urmatorii 3-4 ani...
1 oră în urmă, Method a spus:
Hmmmm
Adică q a băgat atâta timp și nervi (și multi bani în buzunar) ca sa renunțe la tot când da semne bune moto?
Când se sch și regulile în curând?
Cam mare riscul.
Înțeleg sa declari asta dar sa o și faci.. Acum s o fi saturat și el..plm.
Mai ales dacă are planu de retragere dpdv financiar făcut..
Irelevant.
Omu nu e mm da plm și dacă nu te pricepi îți dai seama ca omu e special.
Da i timp.
Si au mai zis ceva Englezii:
Ești Yamaha, ce faci? Miller sau riști cu Toprak?
Miller într un an bun termina pe 7.
Oau. Super.
Toprak? E un risc, dar dacă face clic?
Cu cat își asigura titlul mai repede cu atât mai bine,pentru ca nu va mai merge la rezultat.
Va fi show. Va fi cox.
Vor fi și căzături :)
Ce stupide sunt "animațiile" alea cu piloții.
Acum 18 ore, Method a spus:
Nu stiu ce asteptari ai si nu prea iti inteleg logica, in ceea ce priveste evolutiile Yamaha. Anul trecut si acum 2 ani, Yamaha NU EXISTA pe nici un circuit. Anul asta, cu "motocicleta de primavara/toamna", Q reuseste trei pole-uri si obtine niste clasari foarte decente in curse. Ar fi avut (foarte probabil) si o victorie, daca nu s-ar fi blocat hole shotul vietii. Toata lumea, de la experti, la forumistii vorbesc de un progres evident la Yamaha, tu esti singurul gica contra din peisaj. La Aragon, ce asteptari ai de la Quartararo???? Pe circuitul asta, Q a fost mereu (sub)mediocru, INDIFERENT PE CE MOBRA A CONCURAT. Pur si simplu este un circuit care il depaseste. Pana acum. Poate ma contrazice weekendul asta. Repet, imi este greu sa inteleg hate-ul asta gratuit si lipsa de obiectivitate, in analizele pe care le faci. Ai decretat ca oamenii de la Yamaha (si Honada) sunt japonezi, deci tampiti, si ca lucreaza haotic, slefuiesc suruburi si alte bull shit-uri de genul asta si te incapatanezi, in ciuda tuturor evidentelor, sa sustii aceleasi teorii.
Indivizii astia de la Yamaha, au dormit pe ei timp de 2-3 sezoane. acum sunt in plin proces de reconstructie, la ce te astepti??? Sa mearga perfect pe toate circuitele, in toate conditiile. Ca sa ajunga la nivelul ala, este nevoie de timp, nu se poate recupera 3 ani de somn, in doua trei luni de sezon.
Acum 16 ore, frigider a spus:
Pecco nu il poate bate pe MiMi pe nici o motoreta, insa una este sa fie batut pe alta motocicleta, decat Ducati si alta sa fie batut sistematic de colegul de echipa, pe material de concurs egal. Discrepanta de performanta este foarte evidenta, astfel ca s-ar mai estompa, daca ar concura pe alta motocicleta.  Unde mai pui, ca este batut si de alti piloti Ducati, pe motociclete de client, asa ca plecarea la alt constructor pare foarte logica. Si este foarte posibil ca nici atmosfera din jurul lui sa nu mai fie ceea ce trebuie. Intrebarea care ma macina, este: daca pleaca la Yamaha, isi ia si maturile cu el? :scratch:
Un motiv in plus, sa nu te mai increzi in experti. Asculta-ti instinctul! :)
Acum 26 minute, xt600 a spus:
se spune ca echipa ducati face tot posibilul sa ii dea lu peco ce vrea.
mai e si cealalta abordare "asta e moto, descurca-te".
atmosfera nu mai e ok pt ca e mereu departe.
mereu a fost el miezu, acum nu mai e.
unde pui ca il bat si alte moto ducati, si mai de neimaginat.
numa el  sa nu fii.
Acum 3 ore, frigider a spus:
Și eu tot la asta ma gândesc.
Acuma,cum să îți zic...candva trebuie sa tragi linie si sa zici destul,la un moment dat trebuie luata o decizie dacă rezultatele nu vin...
Da i timp.
Aia vroiam sa subliniez și eu - sa nu ne excitam și sa îl confundam cu un pilot cum e MM.
Eu ii dau timp 20 de ani :)
Și asta e drept,decât duda de Miller...
Acum 59 minute, xt600 a spus:
Eu am așteptările pe care cred ca le are și Q - ca în aproximativ 1-1.5 ani sa ii dea lui Q o moto cu care se poate bate la podiumuri.
Nu vad asta insa la ei.
Ai tot zis de revirimentul Yamaha,am spus încă de la Jerez "hai sa nu ne excitam încă,pt ca sunt condiții si temperaturi speciale care nu se regăsesc pe majoritatea circuitelor",lucru cu care m-ai contrazis.Iata însă că la primul circuit mare și  cu temperaturi normale de vara s-a dovedit (din pacate) ca am avut dreptate...nu ca as fi vrut.
Faptul ca tu te lansezi acum într-o întreaga pledoarie cum ca am eu probleme cu Yamaha sau etc nu schimba cu nimic the facts și anume - Yamaha merge pe circuite tehnice mici și cu temperaturi de sub 30 grade,în rest grip oha - deci n-au rezolvat absolut nimic,astea sunt rezultatele indiferent cât scrii tu ca vad eu trunchiat faptele lor de arme,rezultatele lor sunt zero.
Doamne ajuta sa gresesc si sa fie ca tine,insa Ii mai vedem la Missano dacă e răcoare.
Actualul contract al lui Q a intrat in vigoare la inceputul anului, sezonul a inceput acum 4 luni, motoreta a inceput sa livreze oarece rezultate in ultimele trei etape. Eu zic ca s-au miscat un pic, iar pana la 1,5 ani mai este. Vedem ce va fi peste un an si jumatate. La banii pe care ii ia, Q ar trebui sa aibe rabdare si sa puna osul la treaba.
