13. AUSTRIA Grand Prix of Austria
Vineri 15 August 2025
09:30-09:45 MotoE™ Free Practice
10:00-10:35 Moto3™ Free Practice Nr. 1
10:50-11:30 Moto2™ Free Practice Nr. 1
11:45-12:30 MotoGP™ Free Practice Nr. 1
13:35-13:50 MotoE™ Practice
14:15-14:50 Moto3™ Practice
15:05-15:45 Moto2™ Practice
16:00-17:00 MotoGP™ Practice
18:00-18:10 MotoE™ Qualifying Nr. 1
18:20-18:30 MotoE™ Qualifying Nr. 2
Sambata 16 August 2025
09:40-10:10 Moto3™ Free Practice Nr. 2
10:25-10:55 Moto2™ Free Practice Nr. 2
11:10-11:40 MotoGP™ Free Practice Nr. 2
11:50-12:05 MotoGP™ Qualifying Nr. 1
12:15-12:30 MotoGP™ Qualifying Nr. 2
13:15 MotoE™  7 Laps Race Nr.1
13:50-14:05 Moto3™ Qualifying Nr. 1
14:15-14:30 Moto3™ Qualifying Nr. 2
14:45-15:00 Moto2™ Qualifying Nr. 1
15:10-15:25 Moto2™ Qualifying Nr. 2
16:00 MotoGP™ 14 Laps Tissot Sprint
17:10 MotoE™ 7 Laps Race Nr.2
Duminica 17 August 2025
10:40-10:50 MotoGP™ Warm Up
12:00 Moto3™20 Laps Race
13:15 Moto2™23 Laps Race
15:00 MotoGP™28 Laps Grand Prix
Track by category
Category   Laps     Total Distance    Finish in case of red flag
MotoGP™   28         121.74 Km           21
Moto2™      23         100 Km               17
Moto3™      20          86.96 Km          15
MotoE™        7          30.44 Km           5
Circuit Specs
Total length 4.35Km
Total Width 12m
Longest Straight 810m
Right Corners 8
Left Corners 3
Am inclus si moto, pt iubitorii de electrice
  • Răspunsuri 236
Chiar acum, apriliacluj a spus:
AMR=?? :))
dupa pofta inimii matale :D
cuiva ii era dor de familia Marquez?
Acum 54 minute, Ovidiu M a spus:
Doar 3 viraje de stanga. Poate (macar) tura asta o sa avem alt podium.
mergi pe mana mea: sa nu pui la pariuri :)
Acum 4 ore, frigider a spus:
Ar fi o idee foarte proasta. Tot cine stim noi castiga... ;)
Cand imi aduc aminte ca anul trecut am fost acolo... Duamne ce frumos e acest circuit si unde e situat, chiar intre munti. Daca as avea bani si timp chiar as trage o tura si pana acolo!!
Dar toate au o limita.. daca vreau sa raman insurat! :D
diiiiiii!
#hastagrezistincaunpic#
_____________
PS. de fapt stau si ma intreb, de ce ne agitam, oricum stim rezultatul, cine castiga :)
Acum citeam si eu :
Stability control is a system that reduces engine torque when/if the bike slides, reducing that slide. It’s slightly different to traction control, which instead reacts to the tyre spinning.
Deci intervine asupra motoretei la fel ca si TC reducand cuplul motor (probabil inchide gazul ca altcuma cum sa reduci cuplul motor?...)
Intradevar TC monitorizeaza wheel speed sensor si cand percepe de la semnalele lor (facand o comparatie intre viteza celor 2 roti) ca o roata a luat-o razna,intervine asupra clapetelor de accel.
Asta face acelasi lucru...dar cum?Ii spune IMU cand motoreta aluneca?Un fel de ESP/DSC rudimentar (pt ca nu are voie sa le angreneze frana)?Dar face acelasi lucru ca si TC...chiar nu pricep.Ok - din moment ce l-au introdus in mod clar ajuta la ceva ca probabil au facut n teste inainte,dar nu inteleg - poate o moto sa alunece fara sa ii alunece rotile?Aa,sau TC e atat de rudimentar (sau setat atat de loose la cererea pilotilor) incat nu mai intervine?
Ciudat.Sa vedem daca le foloseste la ceva.
Acum 47 minute, apriliacluj a spus:
diiiiiii!
_____________
Asta vroiam sa scriu🤣🤣🤣🤣🤣. De fapt voi așteptați o altă dezamăgire🤤🤤
Acum 45 minute, Method a spus:
Acum citeam si eu :
cred eu ca este vorba de alunecarea cu ambele roti. adica IMU in functie de intertie, inclinare simte si deplasarea in laterala, si probabil intervine cand motoreta pleaca in derapaje cu ambele roti. Poate e si suplimentar peste TC care doar simte diferenta de rotatie dintre FW si RW ...
sau poate chiar de la toata aerodinamica de pe motoreta care a crescut fortele asupra cauciucurilor, mai ales in viraje, e posibil ca asta sa intervina pentru a scadea uzura lor...
zice ca previne highside, deci cand aluneca spatele si brusc gaseste aderenta.
mintea mea in gandul ei nu poate intelege cum poate ajuta ca reduce cuplul cand spatele ala prinde aderenta si e lansare de pilot.
vb aia si cu bicicleta face urat cand re-gaseste aderenta.
nu e niciun motor al carui cuplu sa ajute /incurce in cazul ala.
*acest sistem va rezolva toate problemele lui Peco, acesta va recupera si va castiga campionatul in mod spectaculos, inchizand gura pe vecie celor care il numesc campion de carton.
Acum 42 minute, Cavaleru a spus:
Iti dai seama cata diferenta face daca iti pleaca aia in slide de AMBELE roti si ECU inchide gazul....si roata fata?cum o opreste?ca hai sa zici ca roata spate are o reactie la inchiderea gazului,dar fata?
Cum opreste el fata din ecu daca nu are voie sa intervina asupra franei?
Ciudat.
Acum 7 minute, frigider a spus:
4sure :bounce:
Acum 18 minute, Method a spus:
Ciudat.
4sure :bounce:
daca spatele nu mai impinge asa tare, fata isi recapata aderenta, pam pam, black magic
Acum 19 ore, Method a spus:
Acum citeam si eu :
Sunt sisteme diferite.. TC controleaza pe acceleratie, cum ai zis calculand viteza dintre roti. rolul principal al TC este sa nu faca overspin...
Sistemul asta pare mai mult catre Slide control, ce a pus prima data Yamaha pe r1 in 2015 si ulterior mai toti producatorii.
Citeste mai multi parametri printre care si parametri din IMU, ceea ce ar tb sa insemne ca poate sa citeasca si cand motocicleta aluneca, in special roata spate.
Cred ca o sa aibe un impact major la ducati, care se foloseste de acest slide...ramane de vazut cat de configurabil este (adica pana la posibilitatea de a fi oprit)
Acum 17 ore, Cavaleru a spus:
nu cred ca are treaba cu roata fata...ei zic ca vor sa reduce high-side-ul....deci se concentraza pe roata spate.
daca ai pierdut fata, inchiderea gazului nu te ajuta, doar MM si ridicarea motoretei din corp poate sa te salveze.
Uite cum are R1 :
SCS detects rear wheel slides during acceleration out of corners, using the IMU to sense lateral slippage
Editat de damager
Postat (editat)
sfarsit de FP1
MM domina cum ne puteam astepta, Peco il urmeaza dar la 0.3sec...
Imi place ca e si Bez acolo in ceafa lor.
Editat de Cavaleru
cica fiind circuit stop&go e ciudat ca aprilia e asa sus.
lu peco ii place mult aici, oricum impresionant ca e asa sus de la prima sesiune.
se anunta ceva ploaie, sambata nu pare ca afecteaza sprintul.
dar duminica pare ca da.
Acum 54 minute, frigider a spus:
Castiga BB, nu al nostru, ci sud-africanu :D
